Question about Canon Office Equipment & Supplies
I have a Canon Pixma MP750, which I've had for a while. The print function isn't working properly - it's not printing colours correctly, and now the grayscale printing is faint, too. I've tried to do a 'maintainence check, but it doesn't give me any clues as to what to DO about the problem. And the 'auto head align' comes up with two black blocks either side and blank inthe middle, and a message telling me that the 'Align Head Failed'. What now?
SOURCE: Cannon Pixma skips when it prints black
hmmm..can you do a test page to see if it's also the case?
http://tinyurl.com/6qcpgy
Posted on Aug 19, 2008
Inkworks
  • 87 Answers
SOURCE: OfficeJet G85xi cartirdges will not align
Could be one of two things....
1 - you may have bad cartridges (usually the color)...when the machine does an alignment it looks for specific marks on the paper...ie..green check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...first replace color cartridge with a HP Brand cartridge
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Inkworks
866-381-0541
Posted on Nov 06, 2008
hashchathy
  • 246 Answers
SOURCE: Canon Pixma MP750 Printer
try to reinstall the printer cartridge
Posted on Jan 15, 2009
  • 421 Answers
SOURCE: printing problem with my canon pixma mp630
Run the alignment test page from the software on your computer and check and adjust the alignment.
Posted on Jan 08, 2010
Douw
  • 91 Answers
SOURCE: canon Pixma IP4200 started printing regular
Hello first of all are you technical
I have taken the printer head out
boil some water and pour in a cup
take off the 2 screws at the bottom
gentley open the head from the casing**** note if you not gentley it wil brake and U can through the hole head away
then let the white block lie in in the water until the water is cold the trough that out and repeat this step.Boil water again....Wait for 4 to 5 minutes to pass..... then use high copressed air and blow from the underneth so that the presure will force the **** out on the white block side also force some hot water from the litle sifes at the top down and make sure that holes are open
replace the ruber perfectley and the head pease an make sure every thing is propeley dry.Replase the scews .and put it back in the printer.Remember it is also a very filthey and inkey job.Good luck
Posted on Feb 15, 2010
How do i clean the printhead on my pixma mp750
If you open the preferences option for your printer there should be a maintenance tab with easy options for cleaning and checking the results. The alternative is to use the menu directly on the printer: 1. Press Menu twice to show "2. Maintenance" 2. The first option is NOZZLE CHECK 3. Press OK This should give you a print showing the current state of each colour. If there are any missing lines in 3eBK or lines in any colours then perform the head cleaning below. 1. Press Menu twice to show "2. Maintenance" 2. Press + to show "CLEANING" 3. Press OK Repeat the nozzle check after each clean. If not improved after three attempts try a deep clean as below (cleaning uses up ink) 1. Press Menu twice to show "2. Maintenance" 2. Press + twice to show "HEAD REFRESHING" 3. Press OK Repeat the nozzle check. If still not printing correctly there are various external solutions available to clean the print head such as http://www.printheadhospital.co.uk/canon-hp-printhead-cleaning-kit.html
Oct 17, 2012 | Canon PIXMA MP750 All-In-One InkJet...
Colour ink not printing - just black
Try to clen the print head,go in the driver of the printer,next maintenance and clean the print head.If the problem persist you need to replace the print head.The print head is under the cartridge.If i have been useful please give me a vote :).Thanks
Apr 13, 2011 | Canon PIXMA MP750 All-In-One InkJet...
Words are not printed clearly in black ink. strokes through them
Your black ink has finished, try and get a new black ink catridge, remove the black ink to get the no on the catridge. good luck
Aug 24, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Black ink not working
increase the colour back and if this doesnt work try deep cleaning and if that fails its the cartridge ........i have had the same problem and deep cleaning on the printer via the computer program for printers solved it .
go to start..then to control panel look for printers and faxs icon right click it then gpo to properties and look for advanced and in you go direct the computer to printer deep cleaning and then try that first cheers... tids2u@ hotmail.com
Jan 21, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Canon MP750 not printing
I had a similar problem. I put in a new ink tank but did not seat it properly. When I tried to print nothing came out. Worse yet, apparently it burned out those jets in the print head! A new print head fixed my problem. I got it on eBay and am very satisfied.
Aug 12, 2008 | Canon PIXMA MP750 All-In-One InkJet...
MP 750 WILL NOT COPY ON BLACK AND WHITE
Sailor,
Does MP750 print in black and white?
Does Scanner work in black and white?
May 29, 2008 | Canon PIXMA MP750 All-In-One InkJet...
Will not print in black
Sounds like a driver configuration. Go to control panel, then printers and right-click properties on the Canon icon, try reverting to default print settings or make sure you are not forcing color printing. Lastly, try printing from a simple program such as notepad - maybe your software inputs color to the printer.
Oct 23, 2007 | Canon PIXMA MP750 All-In-One InkJet...
old marine
old marine
