Question about Sennheiser RS130 Headset
Intermittent power?? I just got the RS140 for use with my laptop. I've got it plugged into the wall and into my PC. The headphones are on the transmitter and charging. The green Power light comes on for a minute or two and then goes off. It just keeps going on and off every few minutes. Is that normal? This is the first charge. Also, I've not seen anything about using these with my laptop but I'm assuming they're compatible, right? Thanks! Larry
Larry, The green power automatically detects the source when you plug it in. If the volume is too low or non-existent (under-modulation) the green light automatically switches off in 10 minutes after you've plugged the transmitter into the source. At least that's what the manual says. It should work with a laptop.
Posted on Jan 07, 2007
Speakers not working but headphone ix ok.
Open volume control - headphone and speakers are a separate control.
Jul 26, 2013 | Dell Inspiron Computers & Internet
Broken headphone jack on dell d630
Yes! if the plugin is not secure the connection will be poor causing unstable reception in the audio department.
May 10, 2012 | Dell Latitude D630 Laptop Computer PC...
Dell Inspiron 6400 E1505 audio not working.
Try system restore to straighten out registry to play audio..
Apr 01, 2012 | Dell Inspiron 6400 Notebook
How do i use my infared headphones and can i use them on my laptop
You should be able to use infrared headphones with your laptop. You don't give a brand or model, but they're all pretty much the same. The transmitter connects to an audio source (and to a power source as well, so you'll need an AC outlet nearby) with the appropriate cable, and you just put the headphone on and turn on the power. Some headphones take regular batteries, while others have a rechargeable battery like a cordless phone; those are recharged when you hang the headphones back on the transmitter.
The couple of infrared headphone systems I've used both had RCA input jacks. The headphone jack on a laptop takes a 1/8-inch mini-stereo plug, so you'll need an adapter with a regular stereo patch cord (RCA plugs at both ends) or a cable with the right plug on the computer end and RCA plugs at the other. Radio Shack sells both.
If you have questions about your headphones, you can usually find a downloadable manual at the manufacturer's website.
Jun 21, 2011 | Computers & Internet
I have a Latitude D600 laptop. When I plug in my headphones, the sound still plays through the built in speakers. When I twist the plug in the jack I can sometimes get sound in the headphones but it still...
I dont think the JACK is the problem, I suspect a bad headphone wire (intermittent) or an incorrect driver, headphone jacks in laptops are software controlled, (no mechanical switch inside) if you hear sound in both the headphones and the speakes it is a driver issue, try updating the driver, if the headphone wire is erratic it can fool the software that controlls the input and do crazy things also...
May 26, 2011 | Dell Latitude D600 Notebook
Brand new Sennheiser RS140 headphones stopped working
Mine is a bit older (2yrs), but I have exactly the same problem. Absolutely no sound from the headphones (no beeps). I also tried new batteries, but still nothing.
If you have a solution, let me know!
Tanks
Nov 24, 2009 | Sennheiser RS 140 Consumer Headphones
No sound from RS130 headphones
I'm having the same problem with the RS140. Only a few weeks old, and no sound at all coming out (not even the beeps). Have replaced batteries and tried a different audio source. Base station lights are on and indicating it is receiving an audio signal, but nothing is going go the headphones.
Jun 25, 2009 | Sennheiser RS130 Wireless Headset
My laptop stop charging.
Batteries get old and wear out. Be use AC outlet is working. Check for power light on AC/DC charger box between laptop and AC.
It is common for Laptop charging/power connectors to get worn and/or loose(intermittent). Try to get charging light on PC by wiggling power connection to PC.
If not, if you have a VoltOhmMeter(VOM). check for 5V on barrel power connector on the charger side, that plugs into PC, Outside conductor is GND and Inner connector is (+5V). VOMs are cheap at RadioShack or AutoParts stores and are a handy tool to have around the house. Book shows you how to measure. PC is 120V AC on Wall side of PC Power Supply from Wall Outlet, and 5V DC on PC side of Charger.
Charger may be defective. Cheap on Ebay.
Feb 23, 2009 | Acer Aspire 3680 Laptop
Headphone jack on Inspiron 1300 intermittent- suspect software
Check mixer on pc to ensure all levels are maxxed. Suspect moreso that plug on side of pc is bad. If this is helpful, please post as such
Jan 14, 2009 | Dell Inspiron 1300 Notebook
Hissing and poor sound quality
Well it could be interference from the TV, computer, or other 900Mhz device (some wireless routers run on this frequency).
I'm currently dealing with the same issue myself, if I find a solution I'll post back.
Jan 02, 2008 | Sennheiser RS 140 Consumer Headphones
Open Questions:
Sennheiser RS130 Headset Logo
212 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
