Question about Samsung RB2155 Bottom Freezer Refrigerator
NO ICE ICE MAKER NOT MAKING ANY ICE. WATER LINE IS OK.
  • MEBANE Nov 22, 2008
    TEMP FOR FREEZER IS 8 DEGREES - ICE MAKER LEVEL IS IN THE DOWN POSITION. NO LEAKS IN THE TUBE TO THE ICE MAKER.
    Model of the refrigerator is RB215LABP.
    Genius:
  • 1,550 Answers
Check your water line and make sure the unit itself hasn't worked loose from the power connector.
If that doesn't do it, you can try emptying your freezer and letting it all thaw then seeing if that helps. Sometimes there can be an ice chunk keeping it from moving
Posted on Nov 22, 2008
    Brigadier General:
  • 3,614 Answers
May i know the model/maker of the fridge..?
for initial info. just check the thermostat selector. it is better to clean the unit to meet the better performance.
    Genius:
  • 2,035 Answers
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
G16farxxqo7 ref wont make ice where is water valve
So you want it to make ice water. And it comes out not frozen.
Is the water cold? if it is cold then it is making ice water ok.
Ice water is never frozen, only ice is frozen.
Dec 21, 2013 | managemylife.com
Not making any ice.
Hello there:
here is a couple of things to check ok
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Dec 23, 2009 | Refrigerators
U-line combo not making ice. Have cleaned
bad water valve, thermostat, freezer not cold enough, make sure the ice maker metal rod is at down position or on back of the ice maker plastic water line is frozen. also depends what year combo you have, there operation is a little different.
Nov 15, 2009 | U-Line Refrigerator Ice Maker
Not making ice
check to see if the water line is frozen where it enters the freezer, this is the most common cause if the water valve is ok.
Sep 09, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker not making ice. Water is in the supply
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Refrigerators
Kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
Jan 02, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice maker not making ice after replacing water line.
Ice makers are a common problem. On many brands there is a reset button behind the plastic cover. However if you physically see Ice clogging your water inlet to the ice maker, this will without a doubt prevent the ice maker from making ice. Use hot water or a steamer to unclog the ice or you can leave the unit unplugged for a few hours to defrost the freezer. You should be able to hear when the ice maker cycles and lets in water. Note: if you're getting plenty of water out of your in door water dispenser, then it's NOT a water supply problem. You may need to check the solenoid that controls water entering the ice maker.
Nov 29, 2008 | Refrigerators
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
Samsung RB2155 Bottom Freezer Refrigerator Logo
29 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
