Question about Bose (321GS) System
Stuck tray I have a Bose AV3-2-1 Media Center and the DVD tray is stuck.
  • wallpd Dec 15, 2008
    Afraid I'd do more damage I sent to Bose. They have a $150 fixed price to fix anything. I'm confident that price is way high but also confident its fixed. I should have my equipment back soon.
  • Anonymous Mar 13, 2014
    Not sure if this problem is with the Media Center, Bad cable, issue with cable provider?
  • 71 Answers
Draw loading belt needs changing that is all dont do it yourself send it to bose or a good hifi shop
Posted on Dec 10, 2008
  • kirk
    kirk Dec 15, 2008
    Hi thats bose standard charge its steepthe belt kit is one belt they are a simple change so it should be long regards kirk brown
Have a Bose media center model AV3-2-1 that won't eject DVDs. Any ideas on how to get the current one out?
Your disc is stuck in the DVD ROM drive.It is recommended that you contact a qualified Bose service Technician who will be able to get your disk out without damaging other parts of the Media Center.
Jan 02, 2017 | Bose Audio Players & Recorders
Dvd stuck bose ls28
Only a Bose repair technician can get the stuck CD out of the DVD ROM.
Jan 26, 2013 | Bose Lifestyle 28 Av28 Media Center With...
Disc tray will not open?
There could be a disc jammed in the tray. The humming sound is the tray open/close motor trying to work
Jan 16, 2013 | Bose Av3-2-1 Series Ii Media Center...
Dvd stuck in media center how can I get it out
If the tray won't open then the safest way is to take the top off the media center and then the cover off the DVD player inside.
It's more than likely the tray belt has stretched. Take the old one off, measure it and get one a couple of mm smaller.
Apr 22, 2011 | Bose 3·2·1 II System
I have a lifestyle 18 bose system which only plays region 2 DVDs. How can I get it to play region 1 as well?
Hi, check below the media center/DVD player as to what region your system was fixed into (indicated by a number inside a globe). This is located underneath the unit just beside the serial number. FI the system indicates that your system indeed is set to region-2 then proceed as follows. IF it marks a different number region, then bring the unit to the Bose service center.
Steps in UNLOCKING REGION CODE of media center:
1. Load a DVD and wait for the display to show "REGION CODE ERROR, CONTACT BOSE"
2. Once this comes out, press eject button on your remote control but do not remove DVD disc
3. Press the following button commands in sequence (make sure they are in sequence and are pressed by looking into the media center display where a small green dot should blink indicating that each command is received).
4. First you need to initiate the system region change on the remote control:
a.while the tray is out and the DVD is still in the tray, press and release "RIGHT" arrow button
b. then press and release "UP" arrow button
c. after, press and release "SHUFFLE" button
d. then press and release "STOP" (black square symbol) button
e. lastly, press and release "MUTE" button and system should go on mute (indicated in the LCD display
After this, you now can change the region code by doing the following button press on your remote control:
1. While the DVD tray is out still and the DVD disc is in the tray, press and release "STOP" button (black square mark)
2. Press and release "SHUFFLE" button
3. Press and release number "0" button on numeric keypad
4. Lastly, press and release "ENTER" button on your remote control and the DVD tray should go back inside the DVD. The disc then should start loading and playing resumes.
5. Allow the DVD disc to run for a few minutes (if you want enjoy a full movie) to keep the region change resident before switching off again.
Now enjoy your Bose Lfiestyle DVD System REGION FREE!!!
Do note, this does not apply to Bose DVD system that are locked to region-1
Glad to be of service always!
Mar 03, 2009 | Bose Lifestyle 18 System
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
DVD/CD door stuck on Bose 3 2 1
On the 321 systems turn off the power and unplug the power cord from the bass module. Wait 5 minutes and plug it back in. Then, simply hit the "stop/eject" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
Thanks to Matthew O;Neil for the the tip,...Italo
On a Lifestyle system with a tray that won't open, try this: Turn off the power to the system and unplug the power cord to the back of the media center itself. Wait 5 minutes and plug it back in. Then, simply hit the "open/close" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
If this does not work, then call Bose when you are home with the system at 800-367-4008.
Nov 05, 2008 | Bose (321GS) System
Disc won't eject
Hi, to open thje the disc tray , look for a tooth pick , insert small hole in front panel push and back until disc tray out. , motor belt need to replace.
Jan 19, 2008 | Teac (DW-224E) DVD Drive
Bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Nov 13, 2007 | Bose 3 2 1 GSX System
Stuck Disc
I sould hope by now you have already taken your set to be repair your gears inside are either broken or striped .blessing from belize goodluck.
Mar 18, 2007 | Bose 3·2·1 II System
Bose (321GS) System Logo
779 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
