Question about Whirlpool Duet GHW9150P Front Load Washer
DOSN T DRAIN
Hello I have a WHIRLPOOL front load model# LHW0050PQ4 that would not drain after wash cycle. Once I drained all the water out the spin cycle works just fine.
Thank you Eduardo
  • 55 Answers
Possibly debri in your pump you should need no tools the face twist off and comes apart.your catch could be clogged too.
Posted on Nov 23, 2008
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
LHW0050PQ4 whilpool washing machine goes through wash cycle but wont rinse,spin or drain
According to the service manual, if the washer won't drain or spin the drain may be clogged.
http://www.searspartsdirect.com/partsdirect/user-manuals/27552/lhw0050pq4-whirlpool-parts-residential+washer-manual
Apr 04, 2014 | Whirlpool LHW0050PQ Front Load Washer
I have a whirlpool duet front load washer. the spin cycle did not complete and their's water still left inside. i've tried to shut off the washer and restart it, it will spin once and then stop...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer (model #LHW0050PQ4) will not drain the water or spin. What parts do I need to look at.
look at the drain pump. to remove nay water in the machine use a wet dry shop vac,attach it to the end of the drain hose.then remove the hoses from the drain pump and look fro any obstructions.if you do not find any thing then you may need to replace the drain pump or door lock mech,
Nov 03, 2010 | Whirlpool LHW0050PQ Front Load Washer
WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN CYCLE MODE. FILLS , WASHES BUT WON'T SPIN OR DRAIN WATER.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool sport, won't drain water on spin cycle
heatman101
Sep 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The drain/spin cycle always adds water
It's normal if it just adds a little bit of water. It does this so your drain pump impeller doesn't run dry which could damage it. If it's filling right up, there could be a malfunction with the control board, the pressure switch or the inlet valve .
You could try shutting off the water supply at the taps before you start the drain/spin cycle.
Feb 08, 2009 | Whirlpool GHW9400 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
473 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
