Question about Procom QL300TYLA Heater
Combustion fumes I've had my ProCom heater for a few years with no problems. Now I'm getting strong combustion fumes that I didn't have before. The flame looks ok, nice color. Even the pilot has a strong combustion smell. I've checked everything and it appears ok. Help!
  • elizabethlut Dec 13, 2008
    Charmglow gas heater (QL300TYLA). Has a bad smell,I would guess carbon dioxide.Even the pilot light.
I have the same problem but I am on Natural gas and it will go out sometimes.
Posted on Jan 13, 2009
The professionals at Pro-Flame in Colton, California, told me it was probably the residue that builds up in the bottom of a propane tank over a number of years of use. They asked me when my tank was last tested and certified for safety. Since I couldn't remember, they suggested I bring it in for them to empty and certify next time I needed to refill. They did, charged me about $30, certified it as safe, and I haven't had that odor since.
Posted on Dec 13, 2008
My blueflame gas heater won't stay lit
So we are talking about the same won't stay lit I will describe both ways. One is when you lift your fingers off the knob it goes out that instant which is probably the thermocouple needs replaced,look to make sure the tip of the thermocouple is in the flame of the pilot light first. The secound version of it is it goes out in a few minutes up to a few hours.The second version is most common.There is a part called a Thermocouple that is mounted next to the pilot light, it is around 3/16 of a inch diameter 1 to 2 inches long and should be mounted so the tip is in the flame of the pilot light. This is what tells the gas valve the pilot light is burning. If any dust ,cat hair ,dog fur what have you gets around the base of the hole the gas from this pilot light comes out of it will bend the gas, which move the flame so it does not hit the thermocouple like it should, this is below the flame so what ever is in there diverting the flame dose not burn up.A draft from a fan or door could do it also.I have used a procom ventless heater as my only heat for 7 years and have to blow it out twice a year. I bought a new thermocouple at the same time I bought the heater to have in the closet in case it went bad some night, it is still hanging there .Because it sucks air in from the bottom past the flame and out the top everything in the air gets burnt into a fine ash dust. So if you use compressed air to blow out your unit you might want to hold a wet towel up in front of it hoping a lot of that white powder dust will stick to it instead of flying around the room . My flame always looks so much better ,less orange and more blue after this .
Feb 10, 2014 | Procom Heating & Cooling
Runs an shuts off
Feb 09, 2014 | Procom ML300HGA Heater
I have a procom NM300TBA heater -- in the past 3 weeks the flame just randomly goes out. It will not relight without a match but it does spark if you push the igniter button.... once lit it will go to a...
There could be several things that case the problem, you mentioned. However, if the unit has been not cleaned and serviced at least once a year, since you have owned it, I suspect that is problem.
Vent-free gas appliances are very safe and very efficient. They use interior air for combustion and have several safety features that will shut them down if something goes wrong. One of the these safety features is the Oxygen Deletion Sensor (ODS). Since the heater uses interior air for combustion, what every floats in your household air (dust, lint and/or pet air) will eventually get into the eater and clog the ODS, the burner air intake or the blower, if you have one.
Rather than go into a lengthy explanation on how to clean your heater (it will involve removing the front of the heater cabinet), I have provided a link to a pdf format of the Owner's Manual for your heater.
http://www.usaprocom.com/product_category.php?choice=1&sid=1&prod=21
Look on page 22 for directions on how to clean & maintain your heater.
If cleaning doesn't help solve your problem, the other things that could possibly cause it are low gas pressure to the unit; insufficient air for safe operation, Thermocouple may be loose where if connects to the Control Valve or Thermocouple may need replacing.
In any event, cleaning the unit is a must, under any circumstances.
Hope this solves your problem Please let me know.
Feb 13, 2011 | Procom MN300TBA Heater
Bad odor, burning eyes from fumes.
It sounds as though some Plastic part is being heated up to Fuming Point, being melted, and releasing toxic gas, I would advise not using it until you can get it looked at by a professional.
Feb 20, 2010 | Procom ML300HGA Heater
Lead emitted from heater?
contact consumer safety. Lead fumes are toxic
Oct 17, 2009 | Procom (177653) Utility Heater
I just replaced the heat exchange unit. It ran ok for a while then after it got up to temperature and shut down it wouldn't turn on again by itself. Fumes. I took off the cover for the burner and could see...
Be careful opening combustion chamber with fumes present. The soot means the gas, or fuel to air mixture is incorrect. The inlet of the burner should have an adjustment that slides. That is an air coke . It may be closed or completly open. Adjust it to a blue flame. Close the combustion chamber when lighting.. If fumes build up, Ther is an explosion hazard when working on heaters. Any type . good luck
May 29, 2009 | Heating & Cooling
Looking for: ProCom Model MNO60HBA (about 3 years old) 6000BTU-Natural Gas-Serial#3620775. I want 3 of the plastic like adjuster knobs on top of the heater. Not the igniter button but the one to allow gas...
Control knobs can be purchased from Procom customer service at 877-886-5989. If you can't find them there, call Kozy World's customer service department at 800-776-9425 and tell them you need a control knob for a KWN109 (same size heater, manufactured by Procom, so same control knob).
Mar 07, 2009 | Procom ML060HPA Heater
Ventless gas heater smells like kerosene
It is posible that your heater is burning fumes from paint, varnish or stain and some times carpet cleaners or other household cleaners. I work for a utility company. We get called to homes for a lighter fluid/kerosene smell quit often. Most of the time it is from the fumes burning off on a standing pilot gas oven. The odor collects in the oven and is released in the customers face when they open the oven door. This will happen with any open flame appliance when exposed to these fumes.
Feb 05, 2009 | Procom 10K BTU, Vent Free, 2 Plaque...
Getting fumes in home while heater is running
The pressure regulator can very well be the problem if you had the device three years with out a problem.
Is the devise vented? if so then maybe there is not enought draft to completely combust the fuel, if it is NOT vented then it very well could be the regulator sending more fuel to the devise that it is able to combust properly.
Jan 29, 2009 | Procom Heating & Cooling
Procom QL300TYLA Heater Logo
162 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
