Question about Microwave Ovens
I have a GE Adora Mircrowave only 3 months old. It does not start although all other functions seem to be working. When I hit sensor cooking and then start is says I cannot press pause during sensor cooking. If I hit time cooking the timer starts but the microwave does not. ????????????????????
  • Microwave Ovens Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Otherwise, it sounds like you have a problem with a door switch or door switch mount.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
Posted on Nov 23, 2008
I HAVE A GE MICROWAVE/BROWNER NODEL WES1384SM2SS. IT HAS STOPPED RUNNING. I CAN SET IT UP TO COOK BUT WHEN I HIT THE START BUTTON NOTHING HAPPENS.
Re: GE JES1384SF Mine quit working so I unplugged it and put a pot of boiling water in it and let the steam dissolve whatever was gumming things up. I used an electric hot plate to keep the water boiling. I let it boil for a couple of hours. I left the door 2/3 open. The microwave is working again. It is four years old and has been used every day, many times a day before it stopped working.
Jan 08, 2011 | GE JES1384SF Microwave Oven
GE Spacemaker JVM 1631: Starts working and stops 3 sec later??
your magnetron is leaking RF do not use until you replace the magnetron, it is interfering with the pc board
Feb 05, 2010 | GE JVM1631 Microwave Oven
Touch control failed on GE Spacemaker Microwave HVM1540
If you want to order a touch pad, (it has the micro computer built in it!) and fix it that way, you'll still have a 2-3 year old machine.
I would say it would be quicker and cheaper to buy a new one.
Jun 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I cooked a frozen breakfast in my microwave this morning, it took 3 minutes, then it signaled me it was done and stopped. I took it out of my microwave and shut the door and when I did that I started...
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Doorswitch or mount trouble can be caused by slamming the door or byopening the door while it's cooking without hitting the Stop pad first.
Thereare plastic mounts inside the microwave which hold the door switchesand onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimesit's a broken tab on the switch holder, allowing the switch to rotatejust out of position. Other times, it's a broken tab on the switchholder, allowing the switch to rotate just out of position. This tabcan be hard to see, since it is under the bottom edge of the switch.
Ifyou or someone you know decide to look into it, we have criticalinformation on safety, disassembly and door switches at our site, andour link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 06, 2008 | GE Microwave Ovens
Microwave Ovens Logo
83 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
