Question about Frigidaire GLMV169D Microwave Oven
Flashing or arcing when power is turned on
Sparks or flashes about two to three times per revolutin of tun table
  • Frigidaire Master
  • 9,086 Answers
Quite often this is due to grease or food particles stuck somewhere in the cavity / floor of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
Posted on Nov 24, 2008
Arcing and flashing during cooking cycle
Arcing and flashing either has to do with having metal parts inside that are not chromed perfectly (better yet only put metal in if it's a microwave convection oven on convection setting only), or some of the powder coating on the inside of the cabinet is damaged. Or a twist tie etc was inside during use. If the cabinet is damaged dispose of unit.
Oct 20, 2013 | GE Adora Over the Range Microwave....
What cause sparks to shoot inside the Daewoo KOR-1B4H Microwave Oven when it is empty?
You should never run a microwave with nothing in it!! There is nowhere for the energy to go. The oven itself has a special coating that keeps the sparks from happening. Anywhere the coating is bad will arc. If it keeps arcing it will burn out the microwave generator.
Oct 02, 2013 | Daewoo KOR-1B4H Microwave Oven
Microwave when turn on making a noise and sparks comin from fan area?
follow this steps and fix it. God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
Panasonic microwave began arcing and now shuts off after a few seconds
Your wave guide cover and magnitron need to be replaced.
Apr 10, 2012 | Panasonic Microwave Ovens
MICROWAVE WILL NOT HEAT FOOD AND TIMES OUT @ 30SEC'S
Replace the magnetron and the wave guide.
May 14, 2009 | Microwave Ovens
Sparks in oven
the burning is normally caused by a small particle of food getting stuck on the waveguide cover, this then carbonises and starts to arc. replacing cover should return oven to normal
Feb 22, 2009 | Sharp R-1480 Microwave Oven
Sparks, noise and burning smell
If it is burning and arcing at the antenna, it is probably arcing in the wave guide area. Probably will have to replace unit. I have had some success by removing the antenna, sanding and repainting the burnt areas of the cavity and sanding off any burnt marks on the antenna. Need to look at top of mag to see if also arcing there too.
Jun 16, 2017 | Panasonic NN-2555A Microwave Oven
Model GLMV169DQA: Significant ''arcing'' or ''flashing''
Quite often this is due to grease or food particles stuck somewhere n the cavity of the oven or stuck on or behind the waveguide cover.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 21, 2008 | Frigidaire GLMV169D Microwave Oven
Frigidaire GLMV169D Microwave Oven Logo
114 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
