Question about Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
E2 error in smeg dishwasher
it s me again.Thank you for the solution you gave me,but tell me please what do you mean with "bottom front panel"-sorry,but i am from Bulgaria and this might be a language problem
    President:
  • 1,462 Answers
Your english sounds fine to me - far better than my bulgarian!
literally - in the front of the machine down at the bottom there is a panel about 10 cm high which can be unscrewed to give access to the base of the machine
tresilla
Posted on Nov 22, 2008
Kettle does not heat. What does the E2 message mean
SMEG DISHWASHER ERROR CODE E2? - How To Mend It
howtomendit.com > Kitchen Appliances, Electric Kettles
Free repair help - smeg dishwasher error code e2. ... Q & As - mend, repair, fix kitchen appliances, electric kettles, kettles, water, not, plug ... Search for - error, e2 ...
Oct 15, 2015 | Oster 1.7 L Variable Temperature Electric...
My candy CDI45 is not working, it just keeps beeping and saying E2. Any tips on getting it working again would make me a happy lady again.
Hi.
E2 is called water safety level error. Unfortunately the problem is often caused by either a defective pressure switch or by a defective control board. The problem is quite common in SMEG built dishwashers like your Candy.
All you can do is disconnecting power for a couple of minutes, by either tripping circuit breaker or disconnecting power cord. That will reset control module. While power is off remove water (if any) from the bottom of the appliance.
If that does not do the job the parts must be tested and the appliance must be repaired replacing defective part.
Regards.
Ginko
Aug 18, 2011 | Dishwashers
My smeg dishwasher stopped during a cycle and warning lights E2 come on. suggesting that it has drawn too much water and to contact customer technical services, any idea what i need to do
E2 shows that the water level switch has been tripped or its faulty,interupt the programm and switch off the dishwasher then switch it on ,programm it again and start the washing cycle again,if the problem persist then test the water level switch for possible replacement
Jan 10, 2010 | Smeg Dishwashers
Error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
May 24, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Hi our dw 1612 integral dishwasher has thrown a fault code E2 which according to the book is a tripping of the water level switch. unfortunately the book dosent tell you where the switch is located or how...
I don't mean to make you sound stupid but it isnt a switch that you can use.
It is used in a dishwaher to make sure that the water doesnt over fill and spill over out of the dishwasher and electricute someone. it cuts off the water (when working corectly) and washes as normal or if it over fills it tells you and in your case it is error E2
you need to speak to a appliance repare shop to see what needs to be fixed or replaced.
Hopefully this has givin you some help
if you have any questions plese dont hesitate to ask
Dec 02, 2008 | Smeg 24 in. DWD612SS Built-in Dishwasher
e2 is overfill or flooded base.
take the bottom front panel off and see if there is water in it and if so, mop it out. if it reoccurs, then you have a leak.
you will see a float device in the front approx middle and this is what actuates e2. if fault is intermittant, try putting a small weight on this - a washer for example.
if e2 is being caused by overfill and not a flooded base, then the water intake moulding needs replacing
Nov 20, 2008 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Dishwasher Smeg DWD409SS
Hi
Please go to www.smeg-service.co.uk/support
Jun 22, 2008 | Smeg 18 in. DWD409SS Built-in Dishwasher
Error message on Smeg dishwasher
i have error 1 on our dishwasher any clues ?
Apr 23, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Smeg 24 in. DWD1SSE-1 Built-in Dishwasher Logo
653 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
