Question about Lenovo 3000 Y410 Laptop
DVD slot not working
When put a cd or dvd it shows no disk why
  • 1 more comment
  • kapil_bhonga Dec 04, 2008
    my laptops dvd slot is also shows no disc it doesn't read dvd but reads cd i would like to know solution for this
  • chris grams
    chris grams May 11, 2010
    need to go to control panel and system devices and find the dvd-rom device, write down the model of the dvd drive, then google for the driver for it. windows should have loaded a generic driver for it but you'll need to find the appropriate firmware driver too.
    i can't be mroe specific without knowing the drive model name.
    good hunting
    chris
  • neeraj9451 May 11, 2010
    when put a cd or dvd it shows blank disk why
  • 565 Answers
Try to update the firmware of your dvd drive its here
Posted on Dec 27, 2008
Cd does not work. Will not show movie.Please replace
There is a difference between a CD "music usually or data" and "DVD". Some players/computers only play CD's. Some are DVD/CD players/writers. Which is yours. If you have a CD player, it will never play a movie. Put in #1.a CD and try. If it works good. Then put in #2. a DVD it might not be a DVD player. Past that it would be a defective player. Get a lense cleaner disk at y computer/variety store". Insert it in your computer and run the program.lay a movie. If it is scratched or dirty. Clean and try again. No luck, You have a bad player of software issue. The Disk player can be slid out and replaced at any computer store. $59? Good Luck. John
Feb 11, 2015 | Computers & Internet
Purchased a Gear Head webcam WC745blu 1.3mp, it came with a mini disk to install software. I have a standard cd-rom for standard size disks so I cannot install drivers with this disk.The website does not...
Well the disk actually works on most standard CD-ROMS. paper_bag.jpg If its cd-rom that is used in laptops (extremely thin) it should also work but you can always find a computer with one of these trays and then copy the contents.
Apr 03, 2011 | Computers & Internet
Won't reconize disk in player
Well here is your resolution for your problem.
As you saying that when you insert any CD or DVD in Player its shows NO DISK.
Well Sometime what happen is if a CD contains are not compatible with Player than it wont work with it.
Or if you had burn that CD or DVD from your personal computer or laptop but it is not burn in proper format than also it wont work in PLAYER.
Well even if CD or DVD is having any scratches on it or it is Used uncounted enumerable times than also sometimes this things happen and it wont work in PLAYER.
Well before Inserting any CD or DVD in Player Just check the above mentioned points.
If everything is ok with the CD or DVD but than also its shows the same problem than get the CD or DVD cleaner liquid spray or even you can use Spirit to clean the CD or DVD and than Insert it.
After doing all this but if its shows no result in it than go to the company dealer and ask him to change the head of the player and you wont face this problem afterward for sure.
if you still have nay quarries regarding the same or any other you may reply me.
Naiven
May 23, 2010 | RCA DRC233N DVD Player
Place DVD in any slot and it says "reading disc" then "no disc"
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
May 04, 2009 | JVC THC5 Home Theater System with 5-Disc...
Will not play disk comes up no disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 12, 2009 | Mintek MDP-1770 Portable DVD Player
Screen comes on, disk turns, loading starts, and doesnt stop
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
How to install a cd/dvd burner to T 320 Acer computer
1-remove sides covers away.
2-remove the plastic cover of cd slot from the front side(the place where you want to put your dvd.
3-insert your dvd in the slot above.
4-connect your power plug and data plug to your dvd.(same as normal cd diver).
5-put your cd driver and install your dvd software.
6-restart your system.
Jul 04, 2008 | Audio Players & Recorders
No disc error showing up-takes 20 tries to bring up dvd
Maybe the laser is unable to focus on the smaller pits and lands of a DVD disk but can see the relatively large pits and lands from a CD just fine. This may be solved by using a CD/DVD cleaner disk. It's a disk with small brushes on it that attempt to brush dust from the laser's lense. They don't always work but that's what I'd try.
Dec 27, 2006 | Apex Digital AT2014DV 20 in. TV/DVD Combo
Disk not playing
Visit the website for this product, http://www.1800customersupport.com/venturer Call or email them for assistance.
Jun 18, 2006 | Venturer SVP580 Multi-disc DVD Player
Lenovo 3000 Y410 Laptop Logo
29 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
