Question about Sony Handycam DCR-HC40 Mini DV Digital Camcorder
DCR-HC42 will not load Mini DV
We have a DCR-HC42, about 4 years old, used rarely.  Recently used to record a school event.  Worked fine, but now it will not load tapes.  With the mini DV inserted, the tray will not reload (or return inside the camcorder).  Works fine empty, but not with tape.  Any thoughts?  Many thanks, John Husson
  • Anonymous Nov 30, 2008
    I have the same problem. I push on the,"Press Here" and it pops right back out. It dosn't stay in. Please help!
    Thanks!!
Have you all tried using a new battery? It happened to me before where I would try and load the tape and the motor just hung and wouldn't allow the tape to fully go in. I tried to recharge the battery to see if that was the problem and even left it plugged in but camcorder appeared to still be weak. I think went to Wolf's camera and asked if I may if a bigger batter would feel weird with my current camcorder (I just said that so I could see if I could borrow a new battery and see if it would fix the problem). When I installed the new battery, it loaded the tape with no problems.
Try it and tell me if it solves the problem.
Posted on Dec 09, 2008
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV Digital Camcorder LCD goes black purchase 4 year back. Any chance to repair LCD.
If you are able to see picture in the viewfinder (eyepiece) on closing the LCD, then the cable connecting the LCD to rest of the camera has gone bad and needs replacement. Take it to a Sony service centre. They will charge Rs 750 for service charges and about Rs 700 for the cable. You can save the service charges if you replace it yourself, but I'll advise against it unless you are conversant with these sort of precision jobs.
Nov 01, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
DVD to mini DV tranfer
Only way is Play burned DVD in dvd player and provide Audio- Video out (yellow-red-white) to mini DV camera that has AV Line Input recording facility. Or find any Mini DV recorder and record tape.
In that way you can record video again on Mini DV tape.
Apr 24, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-HC42 Partial Screen Display
Sony has had some CCD problems with this and other model I think it is important to contact Sony at 1-866-703-7669
Nov 05, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony dcr-hc42: Tape won't load
Michael - Thanks for the solution! I too had the exact same issue. I used the "whack-a-cam" technique and it now works perfectly! I am very careful with my electronics and have only recorded 8 one-hour tapes. I was surprised that the camera started to malfunction with relatively little use. This is my 4th Sony video camera and I have never had one go bad. I have only upgraded the cameras due to recording formats. Thanks again! -Kevin
Dec 16, 2006 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-HC42 makes a buzzing sound
I had the same problem with my TRV460 and the HC-40. It seems it's a motor noise that is 'normal'
Sep 14, 2005 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony Handycam DCR-HC40 Mini DV Digital Camcorder Logo
131 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
