Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
Need a freezer for garage in the Dakotas
I need to purchase a small freezer and the only space I have for it is in an unheated, insulated attached garage. I recently moved to the Dakota's where the weather can get quite cold. I am receiving conflicting information from friends, some say it is OK, others say the cold weather will cause the freezer to stop running because lubricating oils and/ or compressor will fail and others say only a manual defrost is OK. I have checked manufacturer's sites and cannot find this problem addressed. Your opinion? Thanks.
    Problem Solver:
  • 11 Answers
Refrigeration units don't care for the most part how cold it gets with exceptions. The oil is not a concern, neither is manual or auto defrost. Refrigeration units that are required to operate in cold temperatures, say below 30 degrees F. have crankcase heaters on them to heat the oil which keeps freon moving out of the oil and the bottom of the compressor. Otherwise when the compressor starts the cold freon will we sucked out of the bottom of the compress with a large quantity of oil which can destroy the compressor. Another item used for cold weather application is a fan control sensor which keeps the condensing temperature up or the unit will again remove the oil from the crankcase. It may work fine for a quite a while, but it will fail in continuously cold temperatures.
Posted on Nov 29, 2008
Can I use my freezer in an unheated garage?
No. There are units designed to operate in a garage. These units are pretty expensive. The drastic change in temperature tricks the sensing components. You have a good chance of loosing your food product in the unit. As a former service technician, if the call was for a unit in a garage, we would contact the customer, explain the situation and cancel the call.
Nov 17, 2013 | Westinghouse Freezers
Freezer in unheated/unairconditioned garage it stays cold in winter time but it is not freezing when the temperature is hot in the garage
The first thing is to find out if there is a fan that runs next to the compressor. If not then in the summer the machine is overheating and passing the heat up to the machine itself thawing or preventing the freezer from operation properly
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 17, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Can a chest freezer be used in an unheated garage where the temeprature falls below freezing for an extended period? The garage is insulated so it doesn't get as cold as outdoors but it does drop below...
why not then when its down to zero shut the unit off and open the lid and free freezing...no electricity required....remember pop machines sit out in all types of weather
Sep 15, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
Whining sound from motor on Frigidaire upright freezer
Hi: It sounds like you bought a frost free freezer as it has a fan. The fan will come on to circulate the air. It will not necessarly run continuosly. The noise is most likely coming from the fan. I sold Frigidaire freezers for years and they are noisy compared to a refridgerator. If you think it is louder than it was when you bought it, I would replace the circulating fan. Also look at the back wall for frost as it could be a bad defrost heater blocking it with ice. Most likely just the fan though. Since it's in a detached garage,and you won't have to put up with the noise inside your house, it could run a while before failing. The fact it's getting cold is a very good sign.Also as you asked 2'nd, a freezer is ok in an unheated garage. Don't put a refrigerator in there. Unless It is a Whirlpoll Gladiator that is designed for such applications. Use www.searspartsdirect.com to find out where the fan is if you feel it is necessary to replace it. Its not a tough job if you are handy. Their shipping is expensive so you might want to buy it locally.
Jun 22, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
Can a chest freezer be put in an unheated garage?
yes you may encounter problems come sumer depending how hot it gets where you live but during the winter you should have no problems.
Jan 20, 2009 | Haier Chest Freezer HNCM070E
Door
If the door is not sealing because of frost build up or product blocking it it won't make the noise. Is it still cooling ok? If you haven't defrosted it you might do this now. Is it in a cold location, i.e. unheated garage up north? This can cause it also. Check the door and the cooling first if it's not right I would call for service. You should have a one year warrany.
Apr 01, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
211 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
