Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Locking mechanism for jennair
Why won't the self-cleaning locking mechanism unlock? The "lock" light is off, it is cool. Is it the temp sensor?
  • 5 more comments
  • margoklane May 23, 2008
    have jenn air doulble wall oven cleaned top and it will not unlock this has been going all nite the fan won't shut off either help please
  • rkheil1 Aug 05, 2008
    I cleaned my oven and the oven locked. Now the lock is still on and the oven door won't release. I've tried unplugged the oven, hitting cancel. Nothing works. The fan is still running and it has been 1.5 days since the end of the cleaning.
  • rsw4 Sep 21, 2008
    I cleaned the oven and now the auto lock will not auto unlock and the fan is running. I tried flipping the breaker overnight without success as well. Please help!
  • Anonymous Oct 30, 2008
    Same basic problem. Oven was set to clean. Door wouldn't unlock, no fan running after cool down though. Reset to clean, waited for cycle same result. This problem happened a year ago, we vacated the house then and it's been on the market for several months now, but after several people trying to unlock, including tripping the breaker, something happened and now the sliding mechanism came loose from a pin/pivot inside the door. Any way to get the door off of this slide in door/oven?...Gene
  • photran Jan 02, 2009
    I have the Jenn-Air JJW8530C, does anyone know how to fix the door locking problem on this model oven?
  • maryholder Jan 08, 2009
    Jenn_Air wont unlock after cleaning giving F1 code on digital screen. HELP !!!
  • Anonymous Feb 09, 2009
    Jenair oven same problem as rkheil1 aug 05 2008
  • 3 Answers
I have Jenn Air oven S136-C with a locking bar. After cleaning cycle wait for the oven to cool down and the lock light will go out (but the oven is not yet unlocked.) Set SELECTOR knob to OFF Set TEMPERATURE knob to CLEAN Press CANCEL button (on right) twice. Slide the locking bar to the left and the oven door will open.
Posted on Aug 15, 2007
Thank you very much so simple????? thanks
Posted on Feb 29, 2008
Peut etre trop. chaud, attendre qui soit froid..
Posted on Feb 08, 2008
Awesome! thanks so much. your solution worked perfectly.
Posted on Oct 03, 2007
The lock light is on and i can't unlock the oven.
Posted on Apr 12, 2007
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
How to unlock oven Door frigidaire?
Usually the door locks during a self cleaning cycle for safety reasons. If the self cleaning cycle did not finish properly (over temp sensor trip, etc.) it could end up with the lock deployed or it could be that the locking mechanism failed in the lock position (unlikely!). Turn off the power to the oven by finding the correct circuit breaker in your electrical distribution box. Keep it off for some 30 seconds. If the oven is ok it will reset and unlock the door. If it has a failure in the locking mechanism you should be able to access that part from the top or you may have to call a repair person. Hope this helps!
Jan 20, 2016 | Ovens
Oven will not unlock after self clean
Unfortunately, the high temperature limit sensor probably failed during the self-clean cycle. The oven control unit will not receive the signal that the oven is cool enough to unlock the door without the sensor.
If the oven is cool, you can try unplugging the oven for a while and then see if the oven unlocks after power is restored. Pressing the Cancel button several times (or pressing and holding Cancel, depending on the model) may also work. Sometimes, starting a new cleaning cycle and then stopping it (and waiting for the oven to cool) will work.
However if the sensor has failed, the above steps are unlikely to work. You can try to move the lock manually. On some models, you can use a bent coat hanger to slide between the oven door and the frame and push the lock over. On other units, you might open the back panel and rotate the lock mechanism cam.
The oven will not work until the high temperature sensor is replaced. Sometimes the lock mechanism fails and that is what needs to be replaced. If the oven works, then look at replacing the lock motor.
I hope this helps. If your oven is under warranty, contact GE for the repair. Please add a comment with the model of your unit for specific information on the parts you may need.
Dec 29, 2013 | Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
Started to self-clean, locked the door, etc. Had
Hi.
The appliance door is probably locked in consequence of the self cleaning cycle.
Unplug power cord, and allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged the door latch, or the electronic control.
Parts must be tested to discover the fault.
Call Frigidaire at the number listed on the owners manual.
Regards.
Mar 03, 2010 | GE Ovens
My oven door will not unlock after cleaning
It will take some time for it to unlock. The lock after self cleaning is controlled by temp. The temps during self cleaning are over 900 degrees and after self cleaning it will take several hours before the oven lock will release. Don't try to force. If after 3 hours it has not unlocked you can try disconnecting power for 2 minutes then reconnecting to activate the self cleaning motor assembly. Good luck and thanks for using Fixya
Feb 23, 2010 | Kenmore Ovens
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
Self cleaning oven
Pheo,
Turn Breaker/Fuse for the stove, your electrical panel, “OFF” and then “ON”, wait 20 - 30 seconds and the door should unlock.
It may be that the temp sensor is going out and you'll need to have that looked at soon.
Bill
Nov 21, 2007 | Whirlpool GBD307PDS Electric Double Oven
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
870 people viewed this question
Top Jenn-Air Ovens Experts
Craig Butler
Craig Butler
Sal De
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
