Question about Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532
Idle is off??
HI,
I used the saw for about a month now.(newbie here) Noticed that the chain was moving in idle. Called tech support..what a big joke. She said to tighten screw all the way down and then unscrew like 2 1/2 times. That wasn't right? Chain still moved in idle
The saw starts/runs and will go into high idle..will cut for a few momments and then shuts down. The saw cuts out when I release the high idel trigger..It should just go into idle mode right?
I played with the idle screw..got the chain from moving while in idle..but chainsaw has a hard time going into high idle..shuts down immediately???
Cuts out like it is out of fuel,
I'm thinking I still need to fine tune the idle screw...they say one should start the chainsaw, adjust the screw accordingly, take the saw into high idle and it should readjust itself...is this correct
The chainsaw is like a month old..I used it to cut some black walnut..which is did pretty well. I can't believe the saw would be messed up so soon?
thanks
  • 211 Answers
Hi leobowdy
disassembly the carb and carefully clean it.Check the air filter,the fuel line and fuel filter,check the needle,lever,small spring and the screen filter from the carb.Check the sparkplug.
high speed H=2 turns,low speed L=2 1/2 turns,adjust T
When chain saw starts adjust H,L and T accordingly.
cheers savumihai71.
Posted on Dec 03, 2008
How to set idle on model 2150 turbo jonsered chainsaw is idling high and chain is moving when not in use !!!!
You adjust the T screw at the carburetor. Don't adjust the L or H unless your having performance problems.
Dec 12, 2014 | Garden
Chain saw chain won't move when engines on
Do you know if your saw has a safety device called a chain brake? If it does you move the lever just in front of the front hand grip towards the back of the saw to release it.
Oct 17, 2013 | Garden
Carb ajustment
Only Info I see is "Homelite Chain Saws" - not much to go on.
Most saws have two carb adjustment screws, Hi, and Lo.
Assuming the saw will start and run enough to warm up, then
adjust the Lo screw in, clockwise, until the motor starts to slow down,
turn only about 1/8 turn at a time. From the point where it starts to slow down, turn it out about 1/4 turn. This should give you a decent idle. Now pull the throttle, and see what happens.
A - Saw runs up to speed, but dies off, or starts to slow on it's own.
turn Hi idle screw out about 1/4 turn.
B - Saw speeds up, but runs sluggish, fat - not real hi end.
Turn Hi screw IN, about 1/8 or so, and try again, or adjust
while running at full throttle. (best way)
IF it won't run well, try turning both screws all the way in to seat them, then come back out about 1-1/2 to 2 turns. this should get you in the ballpark to set things up as above.
Once the saw is running well, adjust the idle screw to a smooth idle but slow enough that the chain stops moving.
Stay safe
Jul 01, 2012 | Homelite Garden
I use my chain saw infrequently. After being idle for a few months i have just tried to use it and eventually got engine to run and could rev up and down. BUT the chain does not move. I ensured that both...
Its quite possible the chainbrake has activated, grab the hand guard and pull it fully back to the top hanle until you here it click off, now try again.
Aug 23, 2011 | Garden
Hi, I just cleaned my Poulan Pro. Changed out the gas, opened the carb and flushed it out with fresh gas, cleaned the fuel lines, the spark plug and air filter. I didn't replace the fuel filter though. ...
The fuel pick up or filter should be changed every year but if your saw will start and run good but just not idle then adjust the screw marked T counterclockwise slowly until chain starts to rotate without you depressing the throttle.At that point back it off about 1/16 of a turn until saw will idle but chain doesn't move.Thank you. P.S. If you want to you can go back to factory setting by turning H & L fully closed then open 1 to 1 1/4 turn and very slowly adjust for smoothest operation. Do not adjust H anymore then minimum off factory to avoid engine damage.
If you need further help I would suggest you have a trained tech.service it. Good luck.
Feb 14, 2011 | Poulan Pro Chain Saw 46cc 20"
Can't get chain to move. Engine starts ok but seems to be burning clutch. Has not been used for 18 months.
Hi there, I suspect that the chain brake has been activated. To release it, pull back the front guard (in front of the front handle) until it clicks. The chain should now be free to move. Happy sawing !
Nov 06, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have stihl chain saw it runes full throttle
After you let off of the throttle it dies instantly or just kind of quits slowly ?
It could be :
- 1 ) Your clutch is hanging up and not allowing the engine to idle while the chain is not moving.
- 2 ) You need to set the idle higher. You will need to remove the air cleaner, and find the small idle adjustment screw, and turn the screw clockwise, until it idles.
Please let me know.
Feb 08, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan pro 46 cc 20 will not start, have had for 1 month, 3rd time I will use....any suggestions
Most starting problems with chainsaws are caused by flooding. Read and follow the start up procedure in your manual. Probably similar to this:
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
All new saws regardless of maker are set to run extremely lean to meet EPA mandated air quality standards. They are also fitted with a device to restrict richening the carburetor beyond initial factory settings this too required by the EPA. Most big box stores put them on the shelf and sell them to the consumer with no thought of how elevation may impact saw performance or longevity. Homeowners usually aren't concerned about changes in the saws performance until it quits operating. This combination results in many destroyed saws and homeowner saws of most brands being called trash!
I don't know what the elevation where you are located is but I'll wager it is different than where the saw was set up. If my saw I'd visit a good (Stihl in my case) saw shop, and pay a couple of $ to have the carb adjusted (fresh fuel mix (1.5 months or less) 40:1 (3.2oz/1gal Husqvarna or Stihl 2 cycle oil) oil/fuel ratio, and the clean air filter). Any money spent is worth less than the aggravation when the saw won't start and you might spark a mutually beneficial relationship with a local merchant. HTH
Lou
Oct 31, 2009 | Poulan Pro Chain Saw 46cc 20"
It starts up, but when trigger is pulled, the
Most saws have a safety or anti kickback brake. Yours might have tripped. There is a guard in front of where your left hand holds the saw. With the saw NOT running, pull the guard HARD towards the back of the saw. It should move a bit ant you may hear a click. The chain should now move. If the chain moves easily when the saw is not running, but doesn't move when you rev the saw up, the clutch is broken.
Sep 10, 2009 | Garden
Chain keeps turning while in the idle position . Poulan Pro 2075 chain saw.
There will be an idle (Low) speed adjustment screw somewhere on the saw (look in your manual). Adjusting this setting lower will prevent the chainsaw chain from turning in the idle throttle position. Basically you want to set it so the chain has just stopped moving... but you need to set this after the chainsaw has warmed up a little.
Mar 13, 2009 | Poulan Garden
Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532 Logo
772 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
