Question about LG Electronics LRM-519 Digital Media Recorder
Connecting a LG DVD Hardrive recorder to the TV via a freesat box
I recently got freesat HD installed on my Panasonic HD Ready TV and also bought an LG DVD Hardrive recorder. The men from comet installed the freesat box fine and it works with the TV but I can't seem to connect the DVD Hardrive to them both so that I can record freeview and terrestrial channels.
I managed to connect it to the TV but becuase the only aerial currently coming into the room is digital and goes straight into the freesat box, the DVD Hardrive could not pick up any of the channels becuase it was not connected to the freesat box.
Any ideas anyone?
Cheers,
Richard
  • rich_tite Nov 22, 2008
    The model is an LG RHT397H DVD HARD DRIVE RECORDER
4 Suggested Answers
SOURCE: dstv to dvd recorder connection
  1. Grab your A/V composite wires and insert them into the Audio/Video OUTPUTS on the back of the satellite receiver. These are color-coded connections--red to red, white to white and yellow to yellow. The red and white connections are your audio feeds and the yellow is for your video.
  2. Look on the backside of your DVD/VCR dual recorder. You will see similar connections. Connect the other end of the composite wires to the Audio/Video INPUTS on the DVD/VCR dual recorder.
  3. With a second set of A/V composite wires, connect one end to the DVD/VCR dual recorder's A/V OUTPUT and the other end to the television's A/V INPUT. Again, be sure to follow the color code. Also, if your television has more than one available input, be sure to know to which one you made the connections (A/V 1, A/V 2, etc.).
Posted on May 02, 2009
vortash
  • 431 Answers
SOURCE: LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
Posted on May 12, 2009
SOURCE: Nextbase SDV1102-B has black screeen.
I have also one liket that and had the same problem.
The connector is moving and the screen changing from black to white but sometimes nothing. I've managed to have the screen back normal but only for a moment.
Now it is dead again.
I'm sure it is he connector to the screen which is very sensitive.
Posted on Nov 27, 2010
Www panasonic com help
You will need to connect your cable box to your DVD recorder and then connect your DVD recorder to your TV to be able to record content.
Oct 06, 2013 | Panasonic VIERA Televison & Video
I. Have a panasonic DVD recorder with Freesat HD tuners built in. After a power down at the house the recorder shows F5 108 on the display and the TV screen shows NoDignal. Does anyone have any suggestions...
I had the same problem. The display is simply showing that the unit is tuned to Freesat channel 108. I connected a SCART cable (rather than HDMI) and was able to get an output. I am planning to try a replacement HDMI cable as the video quality is obviously much better than with SCART. I hope this proves to be the problem rather than there being a bigger issue with the box itself. I hope this helps...
Oct 15, 2011 | Televison & Video
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
I have a Panasonic Tx l37S10B tv set, & a PanasonicDVD recorder,DMR-EX768EB. To ensure I receive true HD i have bought a Humax Fox T2 hd Digital receiver. I use these items to receive & record HD...
You didn't fully expain how each device is connected to the others. I don't think you have this set up correctly. Your DVD cannot record in HD so there is no point sending an HD signal to it - it can't process it. This is how I would set it up:
1. Install a 2-way splitter on the input cable
2. Connect output 1 from the splitter to the Humax receiver
3. Connect the Humax receiver to the TV with an HDMI cable
4. Connect output 2 from the splitter to the DVD
5. Connect the DVD to the TV with SCART cable.
This will enable you to watch HDTV via the digital receiver and also provide an input from source (dish/cable) to your DVD player so that you can record.
If you've already set it up this way then it should work. I suspect you've connected the Humax to the DVD and TV and also the DVD to the TV.
Please try this setup and post back if you need further assistance.
Nov 04, 2010 | Panasonic Televison & Video
Can i set up my blu ray recorder DMR-BS750 without
The purpose of that freesat to bo able to record/playbak 2 channels at the same time. But you still need a satellite dish pointing to the satellite in the sky so it can work.
Jan 13, 2010 | Panasonic Televison & Video
Just bought a Panasonic TX-P42G10B 42in 600Hz Full HD with freesat HD built in. We currently have Sky +, but i was unwilling to pay the extra a month for the sky HD service. Therefore this tv seemed fine....
Use a good quality scart leads for starters.
connect oon end to tv and the other labeled tv on sky box. The other is labeled vcr. connect another lead from vcr or dvd to that connection.
If you have a hd dvd player or Bluray, then buy a HDMI lead and connect straight to one of the HDMI inputs on the tv. I know this is late but i hope it still helps you and anybody else who may read this.
Dec 28, 2009 | Panasonic Televison & Video
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Setting a new Panosonic TV
If it has no freesat tuner then you can only record what the TV is viewing/tuned to as an output from the TV.
Mar 21, 2017 | Panasonic CT-27SF36 27" TV
How to connect a humax foxsat-hd to a panasonic dmr 75eb recorder,to a panasonic th42px60b plasma tv,also will i get better result using component cable instead of scart lead. please can you...
You plug the humax into the panasonic dvd recorder and then from the outputs of the dvd recorder plug it into the panasonic plasma inputs
Is component video better than RGB? Well, yes and no, RGB provides the widest bandwidth and is the best choice for connecting audio visual devices like a Freeview box, digibox or Sky+ box to your TV, home cinema or home theatre system. DVD is however different, to reduce the amount of storage required DVDs are recorded using component video, it is therefore better to connect a DVD player via a component video cable to your TV, plasma or LCD TV etc.
Thanks if you have any questions please do not hesitate to ask
Dec 02, 2008 | Televison & Video
Record and watch different channels with freesat
I believe that the Humax can only output 1 channel and because it has no built in hdd and twin channel capabilty that is all you can record 1 channel (unlike sky +/sky HD) so that means also that unless you watch a different source (like the picture from your aerial (terrestial channels)) you are stuck with having to watch the channel you record
Oct 12, 2008 | Televison & Video
LG Electronics LRM-519 Digital Media Recorder Logo
229 people viewed this question
Computer Repairing
Computer Repairing
