Question about Samsung TV Remote Control
My remote does not work for my Apex TV
I noticed that the red light on the front of the tv, that was normally lit all the time is no longer lit. I tried unplugging the tv for a minute that didn't work. When I turn the tv on manually, the red light comes on for a couple of seconds then goes out. The tv itself seems fine, the batteries in the remote are fine. I also made sure none of the buttons were sticking. Any other suggestions?
    Genius:
  • 2,920 Answers
It may be a time to buy a new tv. it would cost more to fix that one than to buy another tv
Posted on Dec 06, 2008
Apex dt502 digital tv remote was lost
Go to Remotes.com - Or - you can call 1-800- remotes to get a replacement. The new recommended replacement remote sells for $19.95 and has a large red mute button on it. The old one is no longer available unless you wish to do a good web search or try ebay.
Feb 02, 2014 | Car Audio & Video
Apex model #AT2704S front panel buttons stop working? Menu, channels, volume, and power? Also has a red key in lower left corner and the screen is blue. I have tried mute and function buttons on univ
Your Apex TV has been locked by anyway. Just try this method to unlock it.
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Feb 07, 2013 | Apex Digital Televison & Video
I need the code(s) for a GE universal remote for an Apex TV!
You can try the following codes for your APEX tv:
0214 0216 0215 0401 0156
Here's how to program your remote:
1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
2. Press and release the desired device button (TV, VCR, etc.). The red indicator blinks, then stays lit.
3. Enter the 4 digit code
Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
4. With your device on, press ON•OFF. If the device turns off, no further programming is required. Note: If some buttons do not operate your equipment, try one of the other codes for your brand.
Jun 11, 2011 | GE RM94930 Remote Control
3 yr old KDL-40V3000. Remote suddenly stopped working. Changed batteries twice - didn't make any differnence. Then noticed no LEDs lit on TV front pane! But TV is powered on. Also TV can be operated...
U have a Digital Camera turn it on,take ur tv remote pushes all the remote buttons on the front of the Digital Camera.One by one buttons.If all buttons of the tv remote work will register on the Camera viewing screen,because the Digital Camera able to read infer red signal output.Will figure out wright away the tv remote work or not easily.Tv remote sensor/board have no LED power light lite up might just be a lose connection or just a dead LED lamp only,because all the buttons on the remote sensor/board to the tv panel work wright?Try website Remotes.com to buy tv original remote.
Jun 10, 2011 | Sony BRAVIA KDL-40V3000 Television
I have an apex ld3249 tv with remote. The remote died a couple of days ago. I have had the tv for 6 weeks. A universal remote will not work. A new Apex remote is $60. Is this going to be an ongoing problem...
Hello
There is no warrantee for the remote control for any company's set. A universal remote should work with your Apex tv. I'll give you the model and codes for the remote that suit to your apex TV. Buy one and match it to your TV.
PHILIPS [CL 034] universal remote control.
Codes are:-
0023 0223 0123 0741
Proceedings
Direct Code Entry
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
flashes.
CHANNEL UP. If the device
responds, no further programming is
not operate your device, try one of
OK.
Feb 15, 2011 | Apex Digital Televison & Video
How do i program a universal remote control to my Apex TV
Hello
Universal remote code for Apex are:-
o516 0214 0216 0215 0401
Direct Code Entry
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. OK.
Jan 08, 2011 | Apex Digital PF2025 20" TV
Jumbo Control Code
The codes for this remote are different depending on whether you are trying to control a Sony TV or a Sony DVD player. Please post again with more information, or use the auto-search function of this remote.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Nov 18, 2009 | Innovage Jumbo Remote Control
I HAVE LOST THE MANAUAL FOR MY PHILIPS MAGNAVOX UNIVERSAL REMOTE
You don't need the whole manual for the Philips Magnavox remote fortunately.
If you want to reprogram it for the Apex TV, follow my directions exactly.
  1. Hold down the Code Search button (on the remote) until the light on it turns red and stays red.
  2. Let go of the Code Search button.
  3. Make sure to switch modes at this point to which device you want to program, I'm going to assume TV Mode since your post says "Apex TV." If you need help with Apex DVD codes, I can answer that one too :)
  4. As you Press the mode button and release it, the light should blink for a bit, so keep your eye on it because after it's done blinking it'll stay red.
  5. At this point the remote want's you to press a sequence of numbers also known as Code[s] or Code Entries. Either way these are what are in a table inside the manual that you lost.
  6. I'm going to give you two codes in case one doesn't work: 044 and 335 (one of those hopefully will work)
  7. If the code worked you'll know right away because the light will get mad and start blinking again, otherwise if it DID work, it'll just turn off (the light will anyway).
  8. That's it, I reccomend you test out your remote with the TV now and make it everything works. If something doesn't, try the other code. If it still doesn't work right, I'll give you some more codes.
Hope that helped,
-Cheers-
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
3. Enter the 3 digit code from the code tables. Note:
4. With your device on, press CHANNEL Up. If the
brand.
APEX 044
Mar 21, 2009 | Philips Televison & Video
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Aug 30, 2008 | Apex Digital ADV3800 DVD Player/VCR
Try these APEX TV codes 0023 0223 0123 0741 Thats from the CL034 Code book
May 02, 2008 | Directed 434MHZ Remote Control
Samsung TV Remote Control Logo
213 people viewed this question
Henry  Thomas
Henry Thomas
