Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
Properly installed electric baseboard heater won't work.
Baseboard electric heater installed properly, yet won't work.I have added a subpanel off the main service panel to add more capacity to my house. I have a 50Amp breaker and 8 guage wire going to the sub-panel, which is a Siemens. I have installed a 20 Amp 2pole breaker in the sub-panel and have run 12/2 heater red-sheathed wire to the wall thermostat, which is a Dimplex 2 pole thermostat. I have wired everything in accordance with the wiring diagrams. The Black and Red wires from the sub-panel are connected to the two red ''Line'' wires on the thermostat. Then I have run the 12/2 wire from the ''Load'' lines on the thermostat to the basedboard heater wires. The heater is a small 500W heater. I have tested all the wires with my neon tester and each power wire at every location shows that it is carrying 120 volts (240 total for both wires). However the heater will not go on. I have used a continuity tester to ensure the heater is working. I have even changed heaters and thermostats to rule out defective heaters and thermostats. I have even bypassed the thermostat and hooked up the 12/2 wiring directly to the baseboard heater and still no heat. I have moved the 20 Amp breaker on the sub-panel. Nothing seems to work. Any suggestions would be most appreciated.
  • 1 more comment
  • alanxtar Nov 23, 2008
    I hooked up a baseboard heater directly to the main service panel in the house (via the dryer outlet) and the baseboard heater heated up instantly. This leads me to believe that the reason the heater will not work off the sub-panel has something to do with the relationship between the Main Panel and the Sub Panel. The Main Panel is a different brand, but it should work fine. I also have installed other 15 Amp branch circuits for lights in the Sub Panel and they work fine.
  • Anonymous Jan 16, 2009
    110 volts to each side of the heater,but the heater does not heat up
  • Allen Neal
    Allen Neal May 11, 2010
    are any other 220volt loads being run off the new sub panel that are woking properly
    Problem Solver:
  • 10 Answers
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
Posted on Mar 16, 2009
Hi ,my name is Ravin,I wanted to know that the two hot wires white and red,you can use both of them in any sence on the left of soket up or down it will not make any contact.
Posted on Mar 07, 2009
    Problem Solver:
  • 7 Answers
Do not forget the G ground.
Posted on Jan 23, 2009
  • 417 Answers
I would be looking at the connections on the 20 amp 2 pole breaker in the sub panel.
Is it a 'wire in' breaker' or a 'snap in' onto rails? If its a 'wire in' which terminals have you connected it to? The heater would never work if you have a wrong connection here. Make sure one pole is connected to the live or hot and one connected to the neutral or return.
Posted on Dec 03, 2008
  • Robert Jones
    Robert Jones Jan 20, 2014
    heater works fine. I haced moved it to different circut and cord sill gts hot
  • Robert Jones
    Whenyou unplug the heater after it has been running, you can actually get burnt touching th plug in tip
4 Suggested Answers
  • 92 Answers
SOURCE: dimplex baseboard heater wiring
no does not matter but you must have a ground leg
Posted on Feb 24, 2009
muttandjeff
  • 359 Answers
SOURCE: Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Posted on Dec 23, 2008
mohammed387
  • 1952 Answers
SOURCE: I need to install my Dimplex baseboard heater
homeappliance.manualsonline.com/ex/thread/view/idThread/1430162 - 30k -
Posted on Jan 10, 2009
My electric baseboard heaters make a pinging sound which drives me nuts when I am trying to sleep! Any suggestions other than changing the unit? Thanks
Electric baseboard heaters heat by radiant heat. This mean the heater is heating the metal of the heater first which causes expansion of the metal. This will cause popping metal sounds becouse it is heating up. When it kicks off, by the thermostat, it starts to cool which causes contraction of metal. This will also cause noise. Most all base board heaters I have installed and worked on does this. Sorry there is little to nothing you can do. :)
Jan 25, 2011 | Marley HBB1004 Electric Baseboard Heater
Electric Hydronic Baseboard Heater, 240 Volt: WHEN I TURNED ON MY ELECTRIC BASEBOARD HEATER THER...
My PLF504 detonated this morning (11-25-2010). It worked fine for two years then BANG. Room was lit by flame coming from center (left to right) of unit. I wrote Marley asking them to honor the 10 year heater element warranty. Also, no burnt wires at thermostat connection, no dust bunnies on the fins. Source of fire was the fluid filled encapsulated heater core. Thank God, circuit breaker tripped and wall was tiled.
May 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
IS A HYDRONIC ELECTRIC BASEBOARD MORE EFFICENT THEN THE STANDARD ELECTRIC BASEBOARD HEATER
I have some confusion about what you are asking......
There is no such thing as "Hydronic Electric Baseboards"......
I am assuming you are referring to the oil filled baseboard heaters. If so....
The same amount of btu's required to heat a space remain the same whether the elements heat a liquid to warm the air or whether they heat the air directly, the same amount of wattage will be consumed. So, their is no more or less efficiency between the two.
If you are referring to "Hydronic Baseboard Heaters" (these baseboards are fed from a boiler with a pump) Then....I will assume that it is a gas boiler. In which case, the gas boiler would be more cost efficient to operate. If it is an electric the same rule applies as above......the cost is the same.
Oct 04, 2009 | Fahrenheat FBE15002 Baseboard Heater
Honeywell HZ517 Electric Baseboard Heater not powering up
first.... did they work in the past?? if so... you may have a defective thermastat. if not, usually it is a incorrect wiring problem. wiring in two baseboard heaters to one thermastat can be tricky if you do not know what you are doing. baseboard heaters by design seldom go bad.... if wired correctly the problem could be a defective thermastat or safety limit switch.
Feb 09, 2009 | Honeywell HZ517 Baseboard Heater
Installing hot water baseboard heater
IF THEY COME WITH THE COVERS SET THEM AGAINST THE WALL WHERE TO BE INSTALLED, THERE ARE MOUNTING BRAKETS INSIDE THE WALL PLATE AND THE PIPE SHOULD SIT ON THE BRACKETS,, APROX 3-4 INCHES OFF FLOOR,
Jan 04, 2009 | Marley Electric Hydronic Baseboard Heater,...
How far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
Electric baseboard heater hums while running
is a 60 cycle hum, resonating with the power. check screws that mount it nothing to really worry about
Dec 31, 2008 | Fahrenheat Built-In Baseboard Thermostat...
measure the room, then multiply the length by the width to get the square feet you want to heat. multiply this by 10 and that is the watts you need to heat the room assuming you are using standard 220/240v baseboards.
Dec 25, 2008 | Marley Electric Hydronic Baseboard Heater,...
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
2,532 people viewed this question
Top Fahrenheat Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
