Question about Microwave Ovens
Removing the lamp fro replacement
Model WM 101 M, Goldstar Microwave Oven. The Lamp is not budging, is it a screw in type OR push-in type? Thank you, Ken
  • Microwave Ovens Master
  • 9,098 Answers
It may be a whole assembly - the bulb and socket all in one.
Or the bulb may be tacked in with hot glue. If so, heating it up with a hair dryer will help loosen it.
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Posted on Nov 24, 2008
How do I change the lamp in my Kenwood Simplicity microwave?
The lamp is accessed by removing the outer cover of the microwave oven. Hazardous voltages are exposed by removing the cover. Remove the lamp and install the replacement.
Feb 15, 2015 | Kenwood Microwave Ovens
Change the bulb
Remove the top cover by removing the side screws of the top cover. The chamber lamp is mounted within the slit of the top and will be visible. You can remove the covers to get to the lamp. replace with the same type and thread. if the lamp has not blown it can be due to faulty switch or relay.Trace the lamp circuit to confirm the fault
Jan 10, 2013 | Panasonic NN-S769 Microwave Oven
How do i change the light in my MS-133SE GOLDSTAR MICROWAVE
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Feb 16, 2011 | Goldstar MV-1501 Microwave Oven
How do i replac the interior light on my frigidaire fmv156dc microwave?
We have the service manual and have uploaded it to our site here to help you.
From page 33:
OVEN LAMP and Lamp Socket REMOVAL
1. Disconnect the power supply cord, remove the oven from
the wall and remove the outer case. (Refer to procedure
of "Removal of Oven from Wall" and "Outer
Case removal ".). And proceed as follows.
2. Open the door and block it open.
3. To discharge the high voltage capacitor, wait for 60
seconds.
4. Remove the three (3) screws holding the hood intake duct
R to the oven cavity top plate, the oven cavity front flange
and the fan duct. And remove the hood intake duct R.
5. Turn the lamp socket and release it from the magnetron
duct.
6. Screw the oven lamp off from the lamp socket.
7. Now, the oven lamp is free.
8. Pull the wire leads from the oven lamp socket by pushing
the terminal hole of the oven lamp socket with the small
flat type screw driver.
9. Now, the oven lamp socket is free.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 10, 2011 | Frigidaire FMV156DC Microwave Oven
How do I replace the light bulb ? \r\nI try to open in rear but saw 3 warning lables, plug I don't have tool to remove those screws. What can I do ? Please help thanks ian
There is no mention of lamp replacement in the manual. You should be able to access the lamp IF you unplug the oven and let is sit for 30 minutes or longer before removing the screws. Since there is no info on the lamp, it may be of a type that is not user replaceable (simple push in or screw in type), or is not readily available.
You may end up having to contact Samsung (number is in the manual) to obtain the lamp - or they may not wish to sell to the consumer - which would require a service man perform the work. You'll also need to buy the tool to remove the screws, too. Maybe you can live without the light.. or get it fixed or replaced entirely. A service call may cost more than it's worth.
Sep 14, 2010 | Samsung MW1080STA Microwave Oven
HOW TO CHALGE LIGHT BULB
disconnect the oven from power supply. If the lamp of your microwave is in the most common location, you will need to open the oven by unscrewing the screws on the rear. You will see the lamp behind the control panel. remove and replace the bulb
Jan 12, 2010 | Goldstar MA-1011 Microwave Oven
Changing light blub of oster microve oven
The lamp is located under the stainless top cover of the microwave which unscrews from the back and sides, the bottom corners in the back have special torx screws which are meant to thwart you from removing them but a pair of locking pliers does the trick. Then under the cover on the top of the microwave there's a black elliptical shaped base with only 1 screw holding it down, that is the lamp. Pull the female spade connectors from the lamp, unscrew it and take it out. Oster has about the worst customer service around so i have not verified that they will sell a replacement lamp but if you can find a 20W 120V replacement with spade connectors that will do.
Jan 15, 2008 | Microwave Ovens
Bulb replacement
WAIT!!! Before you just take the lamp cover off and try to replace the bulb that way, which would MAKE SENSE!!!, stop! All you'll do is snap the bulb off, leaving the metal screwy end of the bulb in the socket. Believe me - it happened to me. Twice.
The only way to ensure that you'll be able to get the entire bulb out, because the only way you can actually SEE what you're doing, is to remove the bottom cover of the microwave. It's about 6 screws along the underneath surface of the unit. After removing the screws, the front of the cover will hang down and the rear will stay nested in a groove at the back. At this point, you'll be able to see the backs of the light sockets. Remove the two screws on either side of the sockets, and you can gently pull the bulbs out of the housing so you can actually see and work with them.
Chances are, the bulbs have been GLUED into the sockets with silicone, which GE says it does to prevent moisture from getting into the sockets. Right. Then why is it that the replacement lamps work just fine without being glued in?! Anyway - GE actually instructs in the manual to "run a knife around the edge of the socket" to break the silicone seal. Hmmm..Sounds safe to me.
So, after you've eliminated the silicone one way or another, just gently unscrew the lamp like you would any other.
Trust me - you do not want to try to remove the lamps without removing the bottom cover. Oh, yeah - most importantly, unplug the microwave first! Good luck.
Jan 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Advantium SCA 1001HS
Should be able to get to the lamp by removing the grill.
Oct 04, 2007 | GE Advantium SCA1000H Convection /...
Microwave Ovens Logo
48 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
