Watches Logo
A
Anonymous Posted on May 14, 2012
Thre3 watch manual/instructions
Dial band,3atm water resistant,quartz,japan movement,nana-digi,u.s.f8024,black wristband
4 Related Answers
Anonymous
  • 43 Answers
  • Posted on Jan 05, 2009
SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Apr 04, 2009
SOURCE: Adjust watch band for Seiko 7T94 Stanless Steel Band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Anonymous
  • 1970 Answers
  • Posted on Jun 27, 2010
SOURCE: I need user manual/instructions for Slazenger, model not known
mcdevito75 here, You can visit a small watch repair shop in your area for info, as some watch makers only deal with their watches commercialy.
Anonymous
  • Posted on Dec 18, 2010
SOURCE: Ozon japan movt quartz watch manual
I have a Japan MOVT watch given to me by my daughter. The battery died and i have not worn it in some time. I got the battery replaced now i can't set the digital time or the date, etc. What is the procedure?
2answers
Wenger Watch. I am looking for the right attachment that connects the wrist band.
Do you have a model number? Most watches use a spring loaded pin that slots through the strap at the watch end. The two pairs of 'legs' at each end of the watch have dimples on the inside flat surfaces that the spring pushes the ends of the pin into. You mount one end into a dimple then push against the spring until it's short enough to drop into the opposite dimple. A real pain in the tailbone to do as the bits are so small but you can do it yourself.
Pulsar watch model number 161392
It looks like the Pulsar model number 161392 is a men's watch with a stainless steel case and bracelet, and a black dial. The watch has a Japanese quartz movement and a date function. It is water resistant up to 50 meters. It is a classic, stylish timepiece that would make a great addition to any collection.The value of a watch can depend on a variety of factors, including its age, condition, rarity, and demand. In general, Pulsar watches are considered to be affordable and are not considered to be high-end luxury timepieces. However, the value of any particular watch can vary depending on the specific model and its individual characteristics.
How do I wind my Invicta 1805?
My very brief research shows that the Invicta 1805 watch is driven by a Japanese quartz movement. That would certainly explain why you're having trouble winding it.
The easiest check for quartz vs. mechanical is to observe the second hand. If it pulses only one time per second--i.e., jumps one second at a time--then you're looking at a quartz movement (I'm ignore the rare and expensive mechanical jump movements). If it looks like the hand takes 4 or more little jumps to get from one second to another, you have a mechanical movement.
I need an instruction manual (user's manual)
Hello James,
I couldn't find an online documentation of the manual you are looking. But I did find instructions with a video on how to set the date/time of your watch here:
http://www.keepthetime.com/blog/instruction-guides/how-to-set-the-timedate-on-a-cartier-tank-francaise-quartz-chronograph/
I hope that will help you.
1helpful
Hi, in my seamaster 2221.80 quartz most of the clicks of the seconds hand does not align with the second markers.is this normal & can it be re-calibrated. its a little out of character from an...
A competent watch repair technician can remove and reset the second hand on your watch so that it more precisely aligns with the seconds markers on your dial. However, it may not be possible to get the hand to perfectly align with all 60 markers around the dial. It is not uncommon in cheaper watches for this misalignment to occur, either because the dial has shifted slightly from its original placement on the movement (for glued-on dials) or because the second hand was not carefully aligned when it was initially installed. This problem is less common in watches where the watch dial is more precisely attached and aligned with the movement via screws.
To perform this service, the movement is typically removed from the watch, so this is not a 10-second job. Sometimes, the watch crystal is removed instead, but this may take more time and reduce the water resistant properties of the watch. Either way, if your Omega is still under warranty, this may be a valid claim for service.
Once the second hand is properly aligned, this problem should not re-occur.
May 06, 2011 • Watches
I need replacement screws for my band lds philip stein teslar
mcdevito75 here, Best Bet, visit a small watch repair shop in your area for these screws.
Can't get my croton watch to work.
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Watch Expert? Answer questions, earn points and help others
