Question about Whirlpool Duet GHW9150P Front Load Washer
Spin cycle If I have one to two items in the machine on drain/spin or rinse/spin my clothes always come out sopping wet. Other cycles seem to be fine. I've had my machine for about 3 years.
  • miltary Nov 26, 2008
    MY WASHER WILL NOT SPIN ALL THE WATER OUT OF THE DRUM (GHW915OPWO). PLEASE HELP ME FIX THIS PROBLEM.
    President:
  • Whirlpool Master
  • 2,651 Answers
The machine has sensors within it that detect off balance loads, very possible that the 1 or 2 items are not enough to correctly balance themselves, so the machine will never achieve full speed spin.
Posted on Nov 23, 2008
Why is my whirlpool auto load sensing washing machine spraying water while in final spinning cycle?
you could have a bad temperture sensor bad are water valve but first check an make sure the washer drain alway check your drain hose for clog are lint are trash in pump an last you could have a bad timer if you dont know how to check these call a applince service for repair ok
Dec 13, 2017 | Washing Machines
Stylemaster 909278: The spin cycle is slow and the clothes are sopping wet after the cycle is finished. Didn't see any obstructions. No unusual noise coming from the machine. It ejects water fine after...
Is it a new or old machine?
If old, could be a loose drive belt or the tub overloaded. Is there a heavy load or lite load in it?
A loose belt is usually easy to tighten,...but hard to get access to the motor.
Jul 18, 2011 | Washing Machines
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
When the wash is done the clothes are sopping wet. I tried putting fewer clothes in and they are still very wet. Checked the drain hose for a kink and it seems to be fine.
motor coupler-to test restart the washer in it's spin cycle, let the washing machine run for one minute, then open the lid and check to see if the tub is spinning. if it's spinning the coupler is fine. if it is not then the coupler needs to be replaced, can be purchased at any appliance parts store. good luck!
Jan 04, 2011 | Kenmore Energy Star 44092 Front Load...
Front loading washer - water is not spinning out, clothes are sopping wet
Hi- Depending on the model the drain pump filter may be clogged; sometimes the drain pump impellers get damaged as well and do not pump out the water efficiently. If it seems to be coming up to full spin speed it is likely an issue with the pump. I'd run a Rinse cycle without any clothes in it and see if all the water drains out. The washer will not got up to full spin if it senses that there is too much water in the clothes (too heavy) to prevent damage to the machine. Probably best to get a Tech to come out an look at it. Good luck.
Sep 24, 2010 | GE Washing Machines
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Can I reprogram a front load GE washer so I can add a drain and spin cycle that this machine does not have?.Sometimes my clothes come out too wet and it would be nice to spin and drain them again without...
just add another drain and spin cycle and start it up again with the completion of the first cycle. Washing some items like sleeping bags takes forever because they are so darned absorbent and hold more water than a tiger's sieve of a bladder. Another drain and spin cycle should solve the problem.
Apr 20, 2010 | GE WBVH6240F Front Load Washer
Have a quiet pak4 kenmore elite. the spin cycle seems to not wring out the clothes well. In some cases, the items are dripping wet. I tried running an empty cycle, (rinse and spin setting), and it seem to...
Try this: remove the front lower acces panel(below the door going acroos the lower portion of the washer)
by removeing the attaching screws and pull off, then inside you will see a cylinder shaped unit with a cap with a twist handle on it,this is the filter pump, unscrew the cap to remove the trap and clean out completely, there will be some water in it when you open it so have a towel ready to sop up the water,reassemble everything and try a load of clothes, this will fix your problem. Good luck !
Jan 12, 2010 | Kenmore Elite 45986 Front Load Washer
Water not draining out w/ spin cycle
sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
409 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
