Question about Singer 2662
Locked up sewing machine
I have a singer 20u33 commerical machine . I was just sewing and it locked up . I can't get it to move either way . I took the bobbin case out , it seems fine It's done this before but I don't know what I did to unstick , Seems like it finally just did .
  • sksskygram Nov 25, 2008
    I had pulled out visible thread before I emailed you with my problem . After your reply I thought there must be a thread I can't see . I loosened the bobbin case and found more thread . After I put back togather I had a hard time setting the timing of the needle . Is there a easier way to set that ? It's working now
    Thanks
  • hgrunenwald Dec 23, 2008
    I was using my 2662 model to sew fancy stitching on some denim squares when my machine jammed / locked up. I removed the cover over the bobbin and noticed that a lot of fuzz from the denim had built up, so I cleaned it out with my brush.
    After it was still jammed, I even unscrewed and removed the cover over the needle area and re-cleaned the bobbin area several times.
    The last thing I thought of was re-oiling the machine per a suggestion in the user guide. When I turn it on, it just hums and remains jammed.
    Any suggestions? It's quite expensive to repair! Thank you!
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
Posted on Apr 08, 2009
  • 20 Answers
SOURCE: needle hitting bobbin case model 750
This is a timing problem the hook timing needs adjustment, and possible the needle timing also
Posted on Oct 13, 2009
  • 18 Answers
SOURCE: How to replace the bobbin case in a singer sewing
If you go here and search for 9005, you can find a free downloadable instruction manual.
http://www.singerco.com/accessories/manuals.html
Posted on Jul 22, 2010
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
  • 1788 Answers
SOURCE: The bobbin case on my Singer CE-150 embroidery
It must not be inserted right, check your manual and if you do not have it handy, go to singerco.com and download one for free. You can cause real damage if it is loose, so be careful that something isn't broken and not letting it seat right.
Posted on Sep 11, 2010
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
My zigzag 20uid.sewingmachine is locked cant turn the balancewheel I ve cleaned both the wheel and the bobbinassembly but still remains d dame
if it has been sit use sum oil if there is rust on the parts use a scott pad to clear see if that will help
May 24, 2016 | Singer Sewing Machines
How to make straight on singer 20u33 machine it just zig zaging
Owners manual are usually quite clear.
no manual? try http://www.manualslib.com/
Mar 08, 2015 | Singer Sewing Machines
Singer error codes
I just downloaded and took a look at the user's manual at the singer site--I recommend you do the same, the manual is invaluable. On page 29, it says the the bobbin winder is in operation. Typically, you engage the bobbin winder by moving a shaft over--move it back into sewing position.
Aug 18, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
Singer 20u33
it would be a good idea to have the machine serviced at a sewing machine shop since it's been in storage for years
Nov 04, 2013 | Sewing Machines
Bobbin is not moving at all. I have taken it out of the case and took the case out and reinserted it and still nothing. I have also checked for lint broken needle and ect. The total case is not moving...
it possible that there is something wrong with the hook or hook race or even the sewing machine could be out of time,, it would be a good idea to have the machine checked..
Sep 07, 2013 | Singer Featherweight 140Q
Hand Wheel Won't Turn
The "Bobbin stopper" is in the incorrect position. It moves from side to side in a switch like motion. In one direction, it locks up the machine. That is, you can turn the wheele backwards, but not forward.. The bobbin stopper can be found in the book that cam with the machine. In our book, it is item #9.
Mar 12, 2009 | Singer 3116 Simple
Singer 2662 Logo
748 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
