Question about Indesit W 123 Front Load Washer
Help!! Indesit WM12X - cold wash only
Maybe you can help me with this one...
Our Indesit WM 12X washer only seems to wash with cold water now...
It gives 3 quick flashes of the on/off red light when it's switched on...
Is the thermostat or heating element faulty & are these easy to replace.
Regards
Mark
  • Indesit Master
  • 3,463 Answers
Yes, they are easy enough to replace, but you need to test them with a multimeter to see if they are faulty..
There could be other things wrong.
Posted on Dec 04, 2008
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
I have a indesit wm12x washing machine and i was told it is a dryer but i can not get it to work please help
I have been looking at your machine on internet and found out that the indesit model you have is not the washer dryer version it is a washing machine so has no dryer function. hope this helped.
Sep 19, 2010 | Indesit W 123 Front Load Washer
Does no drain
This could be a easy problem, check your drain hose is not kinked or blocked. put your mouth on out let of drain hose and blow hard if you can not blow stick something up to unblock if it unblocks from blowing great hope this helped
Jun 02, 2010 | Washing Machines
Manual for intergrated indesit wm12x washing machine
To obtain the instructions for washer, go to,
WWW.INDESITSERVICE.CO.UK
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Indesit W 123 Front Load Washer
Indesit Washing Machine WM12X... Were Should The Water Level Come 2 On A Wash Cycle..
The water level will never go above the lower part of the door bowl. Can you be a little more specific on your question?
Regards
Sussex Engineer
Oct 22, 2009 | Maytag MAH6500 Neptune Front Loading...
IDL40 only washes in cold water now.
YES IT SOUNDS LIKE IT'S THE ELEMENT OR MAYBE A WIRE HAS COME OFF THE ELEMENT FROM VIBRATION,
May 29, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit wm12x wont finish cycle just clix through dial,can u help me ?
i suspect that you may not be draining water,if you watch the light flash it will flash at 1 sec interviles it will then stop for approx 3 secs and then start flashing again at 1 sec int,if you wait for it to stop for aprox 3 secs.when it start flashing again count how many flashes til it stops again for the 3 sec,thats is your fault code,if it is 10 or 5,then its will be your pump blocked or inop.
Apr 05, 2009 | Indesit W 123 Front Load Washer
Indesit wm 12x
Sounds like the pump is blocked. Lost a sock lately?
Mar 13, 2009 | Indesit WA 115 Front Load Washer
Wm12x drum stopped
It's probably the bearings. The drum have probably get so loose from the bearing, so the belt have snapped off.
Jan 28, 2008 | Indesit W 123 Front Load Washer
INDESIT WM12X
brushes in your motor almost certainly, put your meter across the motor you will find a open circuit failinf that your control module could be damaged
Apr 21, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
295 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
