Question about Vivitar DVR 7300x Digital-8 Camcorder
Battery wont charge
My vivitar DVR 7300X is plugged in via the computer and wont charge up. it wont even turn on whilst plugged in. Any solutions?
  • 1 more comment
  • evinator Dec 11, 2008
    Yes! I have this same issue. I have tried a wall charging USB charger as well as my computer USB cord. The red light comes on but the battery doesn't take on a charge.
  • Anonymous Apr 06, 2009
    same thing! can't figure it out at all
  • Anonymous May 08, 2009
    Can I operate my Vivitar 7300X by putting it on a table with the display screen closed? When the display is open the recorder won't stay straight on the desk.
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Vivitar 7300X
Posted on Dec 20, 2008
Can i charge my vivitar 850hd by plugging it in?
Yes. The 850W charges the battery via the USB port. You can charge it by connecting it either to a powered USB port on a computer or a wall outlet by using the supplied adapter (or equivalent).
Apr 12, 2012 | Sakar Vivitar Underwater Digital Video...
Hi, my vivitar 550 wont turn on, ive had it on charge and just a red light shows, can you help
Hi, My guess is that the battery is no good any more. It will not take a charge any more. Replace the battery with a new one. Good luck.
Jul 26, 2011 | Vivitar DVR-550 DV Camcorder
I purchased a vivitar dvr 840xhd cant get it to turn on...
your battery pack is probly out off,try one you no is good and try it if not that let it now,its could be a battery contact fail ...
Feb 18, 2010 | Vivitar DVR 840XHD Digital Video Recorder
Most likely your Vivitar needs a new battery....if you've lost your a/c adapter-you can use a standard USB cable to charge your camera. Plug the smaller end into your Vivitar & the larger end into your turned on PC/laptop & it'll charge the battery.
Dec 31, 2009 | Vivitar DVR-550 DV Camcorder
How do you recharge camera battery? camera manual is not clear abot how to hook up battery charger or even where it is!
The easiest way is by using a standard USB cable...plug the small end of the USB cable into your camera (located under the headphone jack) then plug the larger end of the USB cable into your PC or laptop. Turn on your computer & this will charge up your Vivitar 550.
Dec 27, 2009 | Vivitar DVR-550 DV Camcorder
Vivitar DVR 545 - Is this going to work with my MacBook?
I have a VIvitar DVR 545 I can not find out how to recharge the rechargable battery
I just bought this camera and had the same problem.
How DO you charge the battery???!!!
Here goes:
Open the box the camera came in and you should find a little rectangualr black box and a 3-pin plug.
Ignore the other stuff unless you think you may need it (depends what country you're in and what your mains supply wall socket fittings are). Take a close look at the little rectangualr black box and you'll see a slot in it. That's where your battery goes! Remember the battery must be taken out of the camera and slotted into this box! Make sure you align the battery correctly to the litle pins inside the box.
The Vivitar DVR 545 uses a sort of mobile phone/cell phone battery.You must take the battery OUT of the camera. Now you have slotted the battery into the box you connect the 3-pin plug to the box and then insert the plug (attached to the box) into your wall mains supply socket. The box will light up and you'll see a red light. Once this light turns green your camera battery is charged!
The whole charging procedure for the DVR 545 is ridiculous but there it is! By the way one drawback about having to remove the battery from the camera to charge it is that you will lose all or most of your camera settings. remember to reset video and photo settings - resolution, flash etc., etc.
Also a word of caution:
The Vivitar DVR 550 is unusual in that the battery is charged using the USB port. If you also happen to have a DVR 550 do NOT attempt to charge the Vivitar 545 using the Vivitar DVR 550 USB charger cable!
You will destroy your DVR 545 in seconds!!!!
Jul 09, 2008 | Cameras
Technical support.
Sounds strange, I would try a different USB cable.
Apr 17, 2008 | Vivitar DVR 530 Flash Media Camcorder
Vivitar DVR 550 5 in 1 camers/video recorder
I use my motorola cell phone charger....they're interchangable
Mar 19, 2008 | Vivitar DVR 530 Flash Media Camcorder
Feb 28, 2008 | Cameras
Vivitar DVR 7300x Digital-8 Camcorder Logo
1,133 people viewed this question
Top Vivitar Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
