Question about Canon PIXMA MP830 All-In-One InkJet Printer
My fax is jammed and not printing does sender get an OK?
I wondering if senders gets message I received even though machine needs repair. I do hear when someone is trying to send...but then nothing prints?
    Genius:
  • 2,035 Answers
IF your scanner is working then you can send faxes it will stored in the printer memory and then send the fax..
Good luck...
Posted on Nov 22, 2008
Cannon Fax Machine Super G3 Unable to send. Phone rings but does not send. No error message.
In order to send, the recieving machine and the sending machine need to handshake (agree on setting, etc.)
If, as your description says the phone is ringing, I presume your are the sender.....what you need to hear is the other machine pick up, and then fax screech noises..... Test by calling the receiving fax by regular phone, and you should hear a pickup and fax noises....if not, your machine would never send.
Mar 26, 2011 | Computers & Internet
Fax reception fails
Hello Dear,
The error message 242 appears in HP Photomart C7180, when the remote machine (the fax machine at Fax Sender side), is having problem, and it is trying to receive fax instead of sending. So actually both these machines try to receive the fax at the same time.
On many fax machines it is possible to accediently initiate the fax reception when:
1. The paper is not loaded in the machine
2. Or The paper is not correctly loaded.
You may contact the fax sender to check the above things. There is absolutely no problem with machine at your end.
Thanks
Mar 10, 2010 | HP Photosmart C7180 All-In-One InkJet...
Can't receive faxes, I can send faxes and print reports though. messages says "Receiving Error - ask sender to send again". Any ideas?
Have you gotten and old telephone and plug it in where the fax goes and see (hear) if you have any problems with a good dial tone and phone line? Does your phone line go near any high power a/c units big motors, mite think about a ferrite core for the fax/phone line. hav ATT or other carrier check your line. Also check your own line when ATT does it there check is only to the location not inside the house. Does your sure protector protect your phone line, really good sureg protectors protect Power lines fax lines!!! and in some case network lines
Aug 10, 2009 | HP 1040 Plain Paper Inkjet Fax
BLANK PAPER
If you receive a fax with blank pages , nine times out of 10 the answer is that the sender fed one or more of the sheets into the fax machine upside down or backward. You can confirm that this is what happened by noting whether the header (lines of sender information) is present.
You could also be experiencing a technical or mechanical problem, such as a need to fix or change parts. You can test whether your machine can print at all by using its “copy” function, or print an activity report. If all is well on your end, the problem must be with the sender’s machine.
If, by any chance, you’re using an old thermal fax machine, check to see if the roll of paper has been put in backward, because if that’s the case the heads won’t print on the side that isn’t heat-sensitive.
Thanks for using Fixya.
Apr 16, 2009 | Office Equipment & Supplies
Receiving Problem
Do you have a DSL or any other digital phone line?
Are you set to "AUTO RECEIVE" ?
Call the fax machine from a regular phone and listen for fax tones.
Sep 29, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother Intelellifax 2820
On some fax there are reports that you can print out, it is in the setup for printing out received message, sent messages etc. Try that, if you have a book it will explain how if not ask again and I can talk you through it...
Aug 22, 2008 | Brother IntelliFax-2820 Laser Fax
Intermittent problem of faxes not being rec'd from various areas
After a detailed discussion on chat, we got disconnected before accepting payment. This is not a problem with your fax, as it seems to be receiving most calls fine. I suggest printing out a report - Menu/Set, 2, 0, 2 - of caller ID history and having the phone company look into it further. Either there is a problem with your phone line, or someone is prank calling your fax from outside of your caller ID service area. Both are problems for the phone company to fix.
Aug 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Canon PIXMA MP830 All-In-One InkJet Printer Logo
old marine
old marine
