Question about Toshiba Satellite A135-S4527 Notebook
Hard drive screen
My power button comes on but the hard drive does not and the screen does not eith
  • Anonymous Jan 07, 2009
    My computer is running, but the screen is black
  • leiserbunch9 Jan 10, 2009
    My laptop does the same thing
  • 93 Answers
Hi, it means that your equipment not power on, that is to say, the electrical fluid works appropriatly but the this damaged system board, you must go to an ASP in order that they offer to you technical qualified support.
Posted on Jan 10, 2009
Msi vr600x won't start.
Remove power unit, battery, RAM and hard drive. Press the power button to discharge any energy that is left.
Insert the power plug and press power. If the laptop goes to the start screen, the motherboard is probably OK. remove the power supply. Add the RAM and repeat. Then do it again adding the hard drive.
There will be a point when the faulty item is identified or it will now boot.
Nov 11, 2013 | MSI MegaBook Computers & Internet
Maxtor 40 gb hard drive showing 0.0 gb
simply repair your hard drive or replace eith new one
Jan 22, 2011 | Maxtor Hard Drive
My brother wiped the hard drive on his Sony Vaio PCG-4F1L notebook and gave to to me, because he was upgrading. The power button lights and I hear the dvd drive spinning if I put a disc in, but the screen...
he has formatted the hard drive
press the start button and hold down the delete until the bios screen comes up
select the boot tab and select cd as first boot preference
save yes and press esc
install the operating system disc and the hard drive will load the os
you will still have to load drivers from microsoft driver downloads as well
Sep 19, 2017 | Computers & Internet
Possible hard drive failure
Does the splash screen come up? Most of the time if it is your hard drive the ACER splash screen will come up and then a Hard disk 0 error after that. If nothing appears on the screen then you have a bigger issue.
Is there any noise at all (Fan, hard drive spinning)? If so try hooking it to a external monitor to see if there is any movement. You might have a problem with your LCD.
Apr 20, 2010 | Acer Aspire One PC Notebook
Screen does not light up
disconnect the power cable and remove the battery nad then press nad hold the power button for a minute. then connect every thing back and then see if the screen comes on.
in case it does not then again remove the battery nad power cable and remove the hard drive nad ram and put it back in again.
nad then check still does not work see if the screen comes on an external moniter, still if it does not come on call HP if it is under warrnty they would give you free repair.
Apr 12, 2010 | HP Pavilion dv2000t Notebook
Gateway T-1625 Laptop won't boot up - screen blank
Yes, if the CPU/motherboard will not POST (Power On Self Test), then changing the CPU is the only thing that you have not tried.
Sep 10, 2009 | Gateway T-1625 Notebook
Toshiba Satellite A215-S7437 will not boot up...
Take out the hard drive completely and then see if you hear the clicking noise, if you do then that means the hard drive is bad. Also if it goes right to another message and you don't see the blinking cursor then that also verifies that the hard drive was bad and causing the system to hang.
Jun 12, 2009 | Toshiba Satellite A215-S4747 Notebook
The power light comes on but thats it
You may have faulty RAM or it is not making comtact properly. Remove your RAM and insert/reseat it again, try borrowing some RAM to test your laptop.
Your CPU may be faulty.
Can you hear the hard drive spin up?
If nothing works, you have a piece of junk, if the hard drive is OK you can put into a USB case/adapter and use it as an external hard drive for backups and data transfer.
Dec 03, 2008 | Gateway MT3705 Notebook
No power-up
See if this helps-
Unplug the power adapter. Remove the battery. Plug in the power adapter. Attempt to power up.
If that doesn't work-
Power down. Remove the hard drive and CD drive, also floppy drive if you have one. Disconnect the cables to any external devices that you might have attached. Remove all of the memory cards. Replace 1 memory card in the main slot,only. This will reseat the memory card. Power back up and see if the system comes up to a BIOS screen. If not, and you have more than 1 memory card, try swapping to the other memory card. If BIOS comes up, start reinstalling each item (Hard drive first) one at a time, attempting to bring the system up after each item is installed. If the BIOS screen doesn't come up with everything disconnected, you'll need to disconnect the LCD screen (internally) and hook up an external screen. If BIOS shows up on the external monitor at this time, you have a bad LCD screen.
If nothing in this process seems to work, you probably have a bad mother board.
If you have any questions, please ask.
Nov 09, 2007 | Toshiba Satellite M105-S3004 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
18 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
