Before its working. last night i restart that pc. at that time its not working.
SOURCE: intel DG31PR mother board hanged after bios update
Try this and read the "Instructions for Recovery BIOS Updates" section.
http://downloadmirror.intel.com/17084/eng/BIOS%20Update%20Readme.pdf
Good luck.
SOURCE: Boot up beep codes, intel d845glly
here is a list of all beep codes : http://www.cas411.com/ShowArticle.aspx?ID=54
try to identify the beep pattern, it should tell you what's wrong. Most of the time, it's a bad memory stick.
Alex
SOURCE: current system is not an Intel(R) Desktop Board. -(A044412A)
Does'nt your MB CD have the drivers. Otherwise ask the supplier to provide you one....sodeep
SOURCE: Won't boot, display stuck at Intel desktop board, can't go to BIOS
I had this exact same problem, turns out i just needed to unplug a couple USB devices that were conflicting with the startup. It worked inexplicably well. If you have an external HD i'd start by unplugging that, then other accessories.
