Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Picture flickers in and out rapidly,gets blurry for about 5sec then looks like new for about 5sec then back again
About a year ago a bent bleu line showed up on tv screen,ask some friend at work and he said it was the ic convergence chips have gone bad. i never did anything till a couple week ago the picture went to a blurry double vision and it hurt to watch tv then. so i did somemore research and pulled the subboard out and located the (2) ic chips and found two open 3.9ohm resisters infront of 1,order all parts from servicemanuals.com and soldered every back in very well not to short any solder joints together,hooked it all back up and the picture like new for around 5 sec then starts flickering in and out for about 5 to 10sec at thesame it gets really blurry for about 5 sec then picture looks like new for about 5 sect then starts that cycle again ,any ideas what ive done wrong thanx
    Scholar:
  • 107 Answers
Did you replaced 2 IC convergence as well or just 2 resitors 3.9 ohms ? if you did replaced 2 IC then you might have probelm in convergence drive it is1 of the PCB mount vertical on the left side from the rear view under part BP95-00415C you need to readjust the convergence by using your remote control just follow in the servive manual
Posted on Nov 30, 2008
Hi. i have sony w120. its not new, i bought it cca 3 years ago. I didnt use is for a quite a while (but my family did), so few days ago, i realized when i take pictures, pictures are somehow blurry,...
Please go to Setup menu and select Initialize option to reset camera to default settings that might solve blurry picture problem, if that does not help then its technician job to adjust focus of camera.
Thanks.
Aug 02, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
After a period of time, vertical lines appear on the screen. Looks like jail bars. Sometimes turning the TV off, then back on will clear it. All channels. I replaced the projection bulb about 6 months...
no solution, same sounding problem though. last year we were getting lines through the screen and flickering and then the bulb burned out. had it replaced, 2 months later it did it again (they wouldn't stand behind the bulb so we had to buy a whole new one) this time had the bulb and ballast replaced because the repair guy said usually you have to replace both (why didn't they replace them both in the first place?) .. a year later and it's doing it again.. we get the flickering of the screen going on and off and horizontal lines that flicker across it. after turning the TV off and on a few times it seems to go away (or after it warms up)
i know know if i should order another bulb and ballast and spend the money for it to happen again or if it could be something else
let me know if you find a solution.. carolynspranger@gmail.com
Sep 07, 2010 | Samsung HLP5085W 50" Rear Projection...
Horizontal line pictures
am getting experience the same problem - horizontal white lines on blurry still pictures - after 2 years. But the video is working properly.
Aug 03, 2009 | Canon PowerShot A430 Digital Camera
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
When picture has alot of white it shutters and flickers reallybad
My color wheel went out on mine and it looks to be the same on yours'. RCA cannot find a replacement for my model and there are none available on an on-line search. RCA may end up replacing my set.
Jan 04, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
I get coarse blurry lines across the picture.
Your Canon A75 camera has problem of bad CCD Imager and this part will to be replaced.
Canon offers free of cost repair of such problem in A75 models. Click Canon CCD Advisory to see details.
Thanks.
Nov 19, 2008 | Canon PowerShot A75 Digital Camera
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Blurry / runny picture
This is a CCD problem It is known about. Checkout Canon customer support for replacement or discount on a new one
Aug 05, 2007 | Canon PowerShot A85 Digital Camera
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
95 people viewed this question
Henry  Thomas
Henry Thomas
