Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Changing from 720 to 1080 dpi
Our neighbor's 18 month old decided to reconfigure the remote and now we are lost. How do we reprogram the tv to be in 1080. I can pull up the device screen, but the top two options (Video/TV and Audio/TV or something like that) are not accessible and we need to switch from the Audio side to the video side. Anyway, any help would be much appreciated!
  • 944 Answers
The tv should select the resolution automatically depending on the input - if you have an input from a pc and you wish to change the resolution then page 58 of the manual (link below) tells you how to change this on a common pc. all other inputs are usually set - although some newer devices may have their own menu that allows you to also adjust their resolution. http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf page 67 describes how to switch items in the device menu if the appropriate actions are not working then i suggest you get the remote serviced or replaced - ask again if you need help sourcing a new one. Hope this helps :)
Posted on Mar 14, 2007
I need to reprogram my old LiftMaster opener, after 15years my neighbor who claims he hasn't had any changes to his garage door, now can open mine. I can reprogram a few different remotes but they all...
Not sure if you have deep switch or smart learn button. In first situation you need to change the sequence, in the other, pressing the learn button for more then 30 sec should reset and erase all remotes from opener memory..
Oct 21, 2013 | Chamberlain 950CB Remote Control
Lost commuication between the remote and the TV, I changed the remote's batteries and reprogramed the remote and still not working can you assist.
This is tough to diagnose because it could be the remote or the television. There are no listings for the remote. Check to see if there is a light on the remote that comes on when you press a button to show that it is sending. Check and see if there is a light on the monitor that shows if it is receiving a signal from the remote. Usually the remote fails first. You might want to try a universal smart remote to see if it can be programmed to activate the television.
Sep 23, 2012 | Advent 15" LC-15Y3A HD Ready Flat Panel...
Hi there I have a 20" Humax IDTV - LU20-TD2, it
Look for any jammed buttons on the remote or on control panel. Try changing the input device to something that you are sure, works.
Jul 29, 2012 | Televison & Video
Techinka lcd tc
The owner manual may help if you have it--look to see if the set has a feature that locks out the remote control---other than that pray if you have to try to call Technika concerning this issue.
Apr 30, 2012 | Televison & Video
Hi bought a 42 inch aoc tv two months ago. yesterday the remote control stopped working will not turn tv on or off or alter channels it will not work at all. I changed batteries but still same. the...
Normally, these remotes are programmable, I suspect that your remote lost it's programming maybe due to low battery condition. Look in your manual as how to reprogram your remote.
Dec 28, 2010 | AOC A20S431 Television
We have two tvs connected to 1 main thing...2 diffrent remotes for each tv....but now as we change a channel on one tv, the other one changes channels to when not touching the remote.....Please help
Hey there! My name is Becki Barned, and I am with Dish Network customer service. What you have going on here, if it has not already been resolved, is that the remotes are interfering with each other, or you are getting interference with a nearby remote, such as a neighbor's remote. Here are some simple steps to reprogram your remote! http://www.dishnetwork.com/SupportSection/remote-control and also, make sure that your main receiver box is in dual mode (it should have 3 lights- yellow/green/blue.) Hope this helps! Happy troubleshooting!!!!
Dec 15, 2010 | DISH Network 135899 Remote Control
I can't program my Toshiba TV to the CT 91507 remote
change battrries and select our old remote control codes
Jan 19, 2009 | Toshiba CT-90157 Remote Control
Remotes no longer work
I had this exact same problem. After a week or so it started responding to the remote control again. Then after a couple of days it stopped responding. This problem came and went for about a month, then one day the entire TV went dead. When I powered it on, the green light appeared for 2 seconds followed by a sequence of 6 flashing red lights that repeated. I brought my set in to a repair shop and they replaced the power supply board. That fixed the problem and now the TV powers up and responds to the remote control again. Total charge was $250. That was very disappointing for a $1,500 TV that was only 18 months old. I'm going to let Philips know how disappointed I am in their product!
May 28, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
18 Mo old Samsung CXM2785TP made high pitched noise and lost power
The high pitch sound could have been the flyback transformer. check the horzontal output transsitor if is gone the tranfomer is sure to be gone . Tranformers are varying in price are the transistors can also vary you could be looking at around 150.00 plus labour.
Apr 17, 2007 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
639 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
