Question about Fujitsu fi-5110C ScanMaker Scanner
Can't install scanner
Running Windows XP Professional on AMD Dual Core Opteron processor; can't get the scanner to be recognized at all. Scanner utility software has been installed. It's as if the USB ports I'm trying are "dead" (though anything else installed in them works fine). Help!
  • 490 Answers
First chek if the USB ports are working by inserting a known working device, like a pendrive. If it is working then change the USB cable. Buy a good quality cable designed for USB 2.0. This is shielded cable and this should solve your problem. Pls ensure that scanner is powered.
S. Mohan, Chennai, India
Posted on Nov 23, 2008
Connected computer via svga/component cable to TV resolution bad multiple images and rolling screen
That won't wok because the dual GBE has disengaged from the 1U Opteron processor and AMD 8131 Device.
Feb 10, 2013 | MSI Micro Star International Computer -...
Driver for amd athlon 64 x2 dual core 5600+
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya Vijay Gurkha.
I have located suitable drivers for your AMD Processor.
Click here to download the AMD Dual Core Optimizer 1.1.4
and
Click here to download the AMD Processor Driver Version 1.3.2.0053 for Windows XP and Windows Server 2003
Take care!
Nov 16, 2011 | AMD Athlon 64 X2 5600+ 2.9 Ghz Skt Am2...
I have an emachines El-1352G-41W What are my options to expand this system into "CAD" system?
If you mean AutoCAD then you need the following:
You can get more information at:
http://usa.autodesk.com/autocad/system-requirements/
For 32-Bit AutoCAD 2012
  • Microsoft® Windows® 7 Enterprise, Ultimate, Professional, or Home Premium (compare Windows 7 versions); Microsoft® Windows Vista® Enterprise, Business, Ultimate, or Home Premium (SP2 or later) (compare Windows Vista versions); or Microsoft® Windows® XP Professional or Home edition (SP3 or later)
  • For Windows Vista or Windows 7: Intel® Pentium® 4 or AMD Athlon® dual-core processor, 3.0 GHz or higher with SSE2 technology; for Windows XP: Intel Pentium 4 or AMD Athlon dual-core processor, 1.6 GHz or higher with SSE2 technology
  • 2 GB RAM
  • 2 GB free disk space for installation
  • 1,024 x 768 display resolution with true color
  • Microsoft® Internet Explorer® 7.0 or later
  • Install from download or DVD
Jul 11, 2011 | Acer eMachines Black EL1352G-41w Desktop...
I can't install AUTOCAD 2009 in my windows XP computer.It asks to install direct 3D
Most probably your hardware ie graphic card do not support software requirements.
Autocad 2009 system requirements for Win XP.
32-bit AutoCAD 2009
Running under Windows XP:
•Microsoft Windows XP SP2 operating system
•Intel® Pentium® 4 processor or AMD Athlon®, 2.2 GHz or greater
or
Intel or AMD Dual Core processor, 1.6 GHz or greater
•1 GB RAM
•750 MB free hard disk space for installation
•1024x768 VGA with true color
•Microsoft Internet Explorer 6.0 (SP1 or higher)
If you are using AutoCAD for 3D modeling, you should bump up your system as follows:
•Intel Pentium 4 processor or AMD Athlon, 3.0 GHz or greater
or
Intel or AMD Dual Core processor, 2.0 GHz or greater
•2 GB RAM or greater
•2 GB of additional free hard disk space
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, OpenGL or Direct3D capable workstation class graphics card.
Hope it helps.
Mar 22, 2011 | Computers & Internet
Will the ASUS A8V-VM Motherboard Handle DDR2 memory & AMD 64 x2 4000 cpu?
It will not support a DDR2 memory but it will support AMD 64 x2 4000 CPU see specs below..btw your usin socket 939
Memory Supported:
2 x DIMM, Max. 2 GB, DDR 400/333/266 ECC,Non-ECC,Un-buffered Memory, Dual Channel memory architecture
Socket 939 Supported processors :
Sempron / Sempron 64 (1.8 GHz - 2 GHz, or 3000+ - 3500+)
Athlon 64 (1.8 GHz - 2.4 GHz, or 3000+ - 4000+)
Athlon 64 X2 (2 GHz - 2.4 GHz, or 3800+ - 4800+)
Athlon 64 FX (FX-53 - FX-60)
Opteron (1.8 GHz - 3 GHz, or model 144 - model 156)
Dual-Core Opteron (1.8 GHz - 2.6 GHz, or model 165 - model 185)
Jun 29, 2010 | ASUS A8V-VM Motherboard
My usb port is not being recognized. I don't see
What version of windows are you running? If you are running windows 7, it is the widnwos version.
Nov 23, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Intel cpu comparable to "Dual Core AMD Opteron 1212HE"
This is an AMD 2nd generation Opteron CPU, running at 2GHz. It is a single core device. So a comparison would be against Intel business CPU - the Xeon, again compare against a single core.
Apr 02, 2009 | AMD Opteron Dual-Core 1212 HE 2.0GHz...
Lacie Silverscreen 80Gb Drive not recognised by My Dual Processor PC
Sorry for the late reply, but it may help someone else with the same problem.
Are you using a USB2 port, perhaps it's may not be getting enough power. In the orginal Lacie box was a double USB dongle - it allows you to take the power from two USB ports and send them to the Silverscreen, if the SScreen was getting quite enough power.
Or buy a double USB power cable (like: http://www.n-c.fr/webshopncrevendeurs/catalog/images/Double_Cable_USB.jpg)
Otherwise remove the 2.5" disk (remove two screws, & gently pull out) and use a caddy to check the HD disk is still working.
Aug 10, 2008 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Upgrading to Windows XPx64
The answer is no because your motherboard still only supports 32 bit drivers. Read On.
Here's what you need to use Windows XP Professional x64 Edition
Important: Windows XP Professional x64 Edition cannot be successfully installed on x86 (32-bit) systems or 64-bit Intel Itanium–based systems. 32-bit device drivers are not supported on Windows XP Professional x64 Edition.
• Computer with a supported processor: AMD Athlon 64, AMD Opteron, Intel Xeon with Intel EM64T support, Intel Pentium 4 with Intel EM64T support
• 256 megabytes (MB) of RAM or higher recommended
• 1.5 gigabytes (GB) of available hard-disk space (additional space may be required if installing over a network)
• CD-ROM or DVD drive
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• Keyboard, Microsoft Mouse, Microsoft IntelliMouse, or compatible pointing device
arrow_px_up.gifTop of page Additional items or services required to use certain Windows XP features • 28.8-Kbps modem or fax modem and service provider required for Internet access (service provider may charge a fee)
• Sound requires a sound card and speakers (USB speakers require a computer with USB support) or headphones
• Remote Assistance requires that both parties be running Windows XP and be connected over a network
• Remote Desktop requires a computer running Windows 95 or later and the two computers must be connected over a network
• DVD video playback requires a DVD drive and DVD decoder card or DVD decoder software and 8 MB of video RAM
• Windows Movie Maker video capture feature requires an appropriate digital or analog video capture device and 400-MHz or faster processor for digital video camera capture
May 09, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Max processor support
Believe the Aspire runs a 939 chip, if that is the case -AMD Athlon FX-60 Dual Core @ 2.6Ghz
-AMD Opteron 185 Dual Core @ 2.6Ghz (best Overclocker @ ~3.2ghz) LINK this is for cpu-z to see what processor id, fsb etc,
Mar 14, 2008 | Computers & Internet
Fujitsu fi-5110C ScanMaker Scanner Logo
211 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
