Question about Mustek PlugnScan 1200ED Flatbed Scanner
1200ed after installing dont work error
Ok after installing the software and before restarting i get this error.
"driver installion aborted, scanner may not work properly".
and than when i restart i cant get the scanner to work??
please help.
i have tried to install the driver without hooking the scanner and with while installing the driver and still getting this error.
i have win xp sp2, amd 3200.
and strangely it was working fine until i believe i had windows problem
  • 4 Answers
SOURCE: Installation problems
Did you plug the scanner in before installing the software? Common mistake... Disconnect the scanner, uninstall the software completely, re-boot, open up the Device Manager, Click View-->Show Hidden devices--> Look for any scanner related drivers that are still installed for the scanner (they will moste likely be grayed out since it is unplugged) and uninstall them (Right click-->Uninstall). Re-boot again, install the software, wait for the software install to prompt you to plug in the device. Follow the quick start guide if it came with one. Check the manufacturers web site for updated drivers, software for you model.
Posted on Nov 29, 2007
  • 238 Answers
SOURCE: Problem while installing driver for BearPaw 1200cu
hi, get the scanner driver for win xp compatability, try driversguide.com, let me know
Posted on Dec 19, 2007
antiochpc
  • 1314 Answers
SOURCE: WERE DO I GET ANOTHER MUSTEK 1200ED INSTALLATION CD
Download your drivers from here.
Posted on Jun 17, 2008
frcs68
  • 1605 Answers
SOURCE: How to instal Mustek cu 600 scanner with win xp
there is not drivers or software made for Windows XP.
however, you can use the win98 or WinME software. as long as the Windows Xp is running at 32 bits. I have done that with HP flat bed scaner.
don't worry about the non-certified software with MS.
Posted on Oct 31, 2008
SOURCE: mustek 1200 ub plus scanner will not work on xp it wont even let me install software
you need to install the windows 2000 drivers under xp - I did this and finally got mine working :D Hope this helps
Posted on Feb 04, 2009
Exact same problem
firstly I hope the model number is correct. if yes try once again the following steps.
disconnect the Docketport from usb. go to device manager and see there devices marked with yellow exclamation mark. remove them and restart the windows.
1. download the driver and install it
http://www.docucap.com/drivers/DocketPORT465_v1_1_4_setup.exe
2. secondly Docketscan application is needed ..download it too and intall
now try connecting the dockerport
I hope this should make things work.
Aug 07, 2009 | Syscan DocketPORT 465 Scanner
My pc doesnt recognise the scanner
OK.
The first thing I would try a different cable between the PC and scanner just in case it's faulty. Use a 6-foot USB) cable.
If this doesn't fix the problem:
Disconnect the scanner.
Remove the scanner driver so that we can start from scratch.
Go to http://www.mustek.com/mustek/supportdrivers.php and select your scanner model.
Download the twain driver and panel zip file.
Extract the file and install the driver
After installation, restart your system.
Once the system has restarted, reconnect the scanner.
Check the scanner icon on the control panel to make sure that it has installed successfully and that the red X is not shown.
If this does not work let me know.
May 18, 2009 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Hi i need your help i loss my backup 4 my scanner model no : 1200 ub plus
Go here:
http://www.driverskit.com/freedownload/Scanner/Mustek/1200_UB_Twain_1_0/1200_UB_Twain_1_0/get14642.html
Wait 90 sec, then insert the code and Hit download and you will have the driver to install your scanner (Dont select DriverPro)
Nov 13, 2008 | Mustek PlugnScan 1200ED Flatbed Scanner
Smartbase MP360 Scanner Not Identified by MS Vista
One thing to check and be sure of is that your printer cable (USB) is definately a USB 2.0 cable. Canon have an issue with their printers with scanners in that the data flow sometimes isn't sufficient when an older USB cable is used. The slightest drop of data on startup or during scanning will cause a stop.
Worth trying and has sometimes solved the problem for my customers.
Aug 23, 2008 | Canon SmartBase MP360 All-In-One InkJet...
No install disk
Install disks for hardware get stale really fast.  You download a current driver for WinXP from http://www.mustek.com.tw/Download/driv_scanr/english/1200ed.html
  If you want to install on Linux, I think there might be a couple of compatible drivers for that too.  Otherwise it's not too bizarre, things all riff off the same TWAIN-II spec so you don't have a lot of rewrite to do.
  If you work in a Mac environment, there might be some SilverFast drivers for that family of scanner.  They cost money and are worth it (if you use the scanner.)
Jun 16, 2008 | Mustek PlugnScan 1200ED Flatbed Scanner
HOW DO I GET THE MUSTEK 1200 TO WORK ON MY WINDOWS 2000 XP
Go to mustek.com and search for the TWAIN drivers by model number.
If that doesn't work, you might be able to salvage the CD by getting a resurfacing machine.
Jun 13, 2008 | Mustek PlugnScan 1200ED Flatbed Scanner
Drivers for my scanner
click here to download driver and install instruction from Mustek website.
Apr 24, 2008 | Mustek PlugnScan 1200ED Flatbed Scanner
Mustek PlugnScan 1200ED Flatbed Scanner Logo
53 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Mike
Computer Links
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
