Question about Goodman CLQ36AR49 Air Conditioner
Vibration when heat only is on inside and out
Model #cple36-6. a/c- emergecy heat- inside fan no noise.just when heat is on
  • 144 Answers
Is it noisy always when running in heat or only for intermittant periods? Depending on where you live every 45-90 minutes of run time the heat pump goes into a cycle called defrost. The fan on the outdoor unit will shut off. the compressor will continue to run but in actually cool mode. this heats the outdoor coil and allows any frost or ice that is built up on the outdoor coil to melt. The compressor can get pretty loud in this mode and you may actually see steam coming off of the unit. This is normal. However if it is noisy all of time in heat check/clean your coils. If this doesn't remedy it have your refrigerant charge checked by a NATE certified Service Technician. Good luck.
Posted on Jan 17, 2009
Inducer motor noise
Never trust anything that comes to you new because usually they are made in china and are not consistent, but next time make sure clean air is being supplied if impeller gets dirt build it becomes imbalanced and will draw high amps and create that vibration noise. Also vibration noise can be caused by improper combustion set up.
May 15, 2017 | Water Heaters
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
My computer is becoming really hot and noisy. After turning on the computer, everything is good (no noise). Once around 15 minutes passes by or I open up a lot of programs together, my computer starts...
Sounds like the fan is wearing out, as it heats up the fan needs to spin faster and if the bearings are wearing out it will start getting louder and it will also get hotter because the fan cannot keep up the heat being produced. You can replace the fan, most computer shops will carry replacements, also get a can of compressed air and give the inside of the computer a good cleaning. This will help keep things cooler as well. Also make sure that the air vents on the outside of the case are clear as well.
Jan 07, 2010 | Vantec Fan Vibration Dampener Noise...
Ice builds up in freezer, and vibration noise only when freezer is closed. When freezer open vibration noise stops. starts when pressing the switch which turns off the light.
Replace the fan motor AND blade . ( evaporator fan motor ) . This motor is located inside the freezer , behind the rear panel . The switch , is a fan/light switch , when closed , turns on fan , and light off . When open , light on , and fan off . normal operation .
Oct 07, 2009 | Amana Refrigerators
Amana Model MVH210E The unit turns on and starts up normally but it does not heat and seems to make an increased vibrating noise
I'm having the same problem. When I hit start, the light and fan comes on but no heat. There is not a turntable in the MVH210E model. Any ideas how to fix it?
Jun 06, 2009 | Amana AMV4204A Microwave Oven
Some panel in my Neff electric oven is making a loud vibration noise on fan mode. The vibration noise stops if the top part of the front surround (with door open) is pushed in. There is no vibration on...
Update: after using the oven with the grill instead of the fan, the problem sorted itself. With the heating and cooling, obviously some panel had not settled correctly and was causing the vibration. It hasn't happened again so far.
May 19, 2009 | Neff Ovens
Noise vibration
if you take the back panel of the freezer out you can get to the condenser fan they do have a habit of going bad and actually having the fan and shaft move forward on them usually when you start hearing the noise it is not long before it goes out completely.
May 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Fan making loud noise
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
noise you are hearing can be the fans inside with bad bearings and or what im assuming given the info you gave.More likely the motor inside the optics engine (color wheel) is making noise..This will also cause picture problems..very expensive to repair..
Dec 13, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Goodman CLQ36AR49 Air Conditioner Logo
117 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
