Question about Samsung Cameras
Samsung vp-l900 camcorder. when tape inserted, it wont close... comes up with c-emg fault
creeperz
  • 52 Answers
SOURCE: Samsung camcorder
Although my question might sound stupid, but did you charge the battery? The camera should be having a li-ion battery, which does not retain its charge for long(a week or so) which gives the battery a longer life.
If this is not the problem, could you explain the "ticks like a clock" in detail.
I could also be due to the tape getting jammed.
Posted on Mar 19, 2008
ginko
  • 19396 Answers
SOURCE: digital camcorder not charging
You need to test the volts out from the charger with a MultiMeter,
to check if there is power coming out. Your battery may also be faulty, as pointed out from some other expert. In any case the suspect nr.1 remains the adapter.
About the warrantee, you have 12 moths from Samsung , it should be valid even if you register the item right now. Here are details about Samsung 12 months fabrig warrantee in UK. Contact Samsung in your area to get more details.
You are asking help to me and accepted the rubbish solution provided by other expert. Please refuse the other expert solution (unless helpful) accept the right solution in the premium post (the other). Fixya pay the accepted solution only.
Regards
Regards
Posted on Apr 06, 2008
SOURCE: SAMSUNG CAMCORDER wont recorder
My mom is having the same problem. Trying to find a solution for her. Hope someone can help.
Posted on May 21, 2008
SOURCE: samsung VP - U10
the Capstan servo has corroded and needs to be replaced
Posted on Jun 02, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Samsung VP-D103i Mini DV eating tape apon inserting
Have you cleaned the tape deck using a DV tape cleaner?
Posted on Jul 06, 2008
My camera won't record or playback. The code c.emg appears in the viewfinder.
Hi there, just pop a Camera tape cleaner in camera and away it will go.
David
Jun 22, 2010 | Samsung VP-W90U Camcorder
Loaded tape into Samsung VP-L700U 8mm and received 'Emergency Eject' message. Tape now chewed. Repeated & ruined several new & used tapes, including cleaner tape. Camcorder was working a half...
Internal mounting screws for the tape chassis may have come loose and can no longer hold the tape in the correct position. You will need to disassemble the camcorder to access the tape mechanism.
Nov 15, 2017 | Samsung VP-L700U Camcorder
Samsung camcorder vp-d381 eject L fault
YOU CANT CLEAR IT. THIS SOUNDS LIKE THE TAPE TRANSPORT IS BAD. SOMETHING BROKE INSIDE TRANSPORT AND NOW IT WONT ALLOW YOU TO LOAD TAPES
Feb 21, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
There is a tape stuck in my camera.
there may have been a spring that pulled on a tab in these places that will unlock the the tape , and if is not unlocking it will go back to close position
Oct 24, 2008 | Samsung VP-D10 Mini DV Digital Camcorder
Jul 06, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
DOOR WONT EJECT AND ZOOM NOT WORKING
JVC GR-AXM310
Will not eject!!! I have put in a fully charged battery and tried to eject it, it will not open at all. Please help me out if you can.
Thanks Shorty_007
Jun 07, 2008 | JVC GR-AXM310 VHS-C Analog Camcorder
Samsung VP - U10
Mar 13, 2008 | Video Cameras
Tape Won't Load
something is blocking the mechanism and not letting it load or the mode switch is bad and the mechanism dosent know where it is. These camcorders are common for this type of problem and these days Im sorry to say that most places charge an arm and a leg just to look at them. good Luck
May 25, 2006 | Samsung VP-L700U Camcorder
Camcorder not working says 'c-emg' on screen
That error code is telling you hey i've got a mechanical problem because when the microprocessor tells me to move the mode switch is suppose to send signals back to the processor to let the mechanism know where its at and in this case the processors not getting the right codes or signals so it wont let you use it, and thats why it will eject if a tape is inserted. Now unless you have all the special tools ,jigs and adaptors to repair this including a service and a mechanism manual you really should take this unit in as there are really no serviceable parts inside for the consumer to replace. Sorry i couldnet be more helpfull. Good Luck
May 14, 2006 | Samsung VP-D10 Mini DV Digital Camcorder
Error messages
Any of the following Error Messages "D.EMG, C.EMG, R.EMG, L.EMG" indicate a mechanical failure in the camcorder. The following steps may resolve the issue. 1. Eject the tape 2. Set to OFF 3. Detach the battery 4. Reattach the battery
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Cameras Logo
71 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
