Question about Samsung RS2630SH Side by Side Refrigerator
Samsung american fridgefreezer
The fridge on my side by side fridgefreezer has stopped working!!!!It still dispenses ice but not water!!!!As it is only two years old i would rather repair it than buy a new one!!! Any help would be very welcome!!!! my samsung side by side american style fridge freezer has developed the following problems. No water coming through the dispenser although water is on
  • 1 more comment
  • hellcat13 Nov 24, 2008
    same here! no water, fridge side is warm + i've noticed ice build up inside the fridge
  • dani73 Nov 26, 2008
    Ho lo stesso problema, Samsung rs23fgrs side by side.
    Il display della temperatura del frigo indica 16°C (il frigo non funziona) e dall'erogatore dell'acqua (lato freezer) non esce acqua (il tubo è collegato direttamente al rubinetto).
    Sto aspettando di avere un appuntamento col tecnico autorizzato Samsung ma ho paura che possa fare dei danni, visto che già al telefono, quando gli ho spiegato che la temperatura del frigo sul display è di 16° C la sua risposta è stata: "E che problema c'è, in inverno la temperatura deve essere più alta!"
    Se qualcuno ha già la risposta al problema preferirei sapere in anticipo cosa fare, prima che il tecnico (autorizzato Samsung!) possa fare ulteriori danni.
  • A3Andy Feb 16, 2009
    I have a Samsung RS2556SH Side by Side frig, no water come out from dispenser but the ice machine is work fine.
  • Samsung Master
  • 1,910 Answers
2 years is much too short for starting problems with a refridgerator contact your dealer for a condition because of warranty on the repair you eventual will spend on it. Hidden defects are factory falts are there some holes for melting water are clogged inside the fridge somewhere
An ordinary refrigerator is made for a 17-year life span. like brands as Bosch Siemens Kuppersbusch easely have that lifetime but your dealer is the right point to get your service .
Posted on Aug 18, 2017
SOURCE: Samsung, american style fridge
We had a service tech service our fridge for the same problem. Although the ice that was dispensed was not as fine as crushed ice, mainly chunks. In any case, he said this is a known problem and is typically resolved by ensuring the freezer temp is not set at the maximum setting. Ours is currently now set at 3 bars and is producing cubes. Not sure if reducing the temp was the ultimate fix as he also replaced the ice maker.
Posted on Aug 05, 2007
  • 142 Answers
SOURCE: I have an american fridgefreezer it is set 0n 4 c
fride temp shuld be between 1 and 4 and freezer -18 and -22.
Posted on Sep 14, 2009
  • 117 Answers
SOURCE: temperature light for samsung american
hi dont know what model you have , have alook at this video may help ?
Posted on Nov 11, 2010
heatman101
  • 43501 Answers
SOURCE: We have an american fridge
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Feb 14, 2011
  • 2006 Answers
SOURCE: Samsung american style fridge freezer,
Which fan are you referring to? The interior one or the compressor fan? If you are talking about the compressor fan, that isn't good news. And could mean many things.
If you are talking about the interior fan, then the thermost is sensing that the refrigerator section is not cold enough. Which could me that the cooling tubes are blocked or clogged. The most likely is frost build up behind the rear panel of the freezer, meaning a defrost system failure. Hee are some links that might help you troubleshoot which component it is:
The defrost heater is easy to check with a ohm meter. http://www.acmehowto.com/howto/appliance/freezer/check/defrostheater.php If you have continuity, then it is good.
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html is instructions on how to test the timer.
http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosthermo.php is instruction on how to test the defrost thermostat.
You should also check to make sure the the condenser coils are clean and that air flow is good over it. I.E. the fan is operating, and not a lot of debrie on or around the condenser coils.
Hope this helps.
Posted on Jun 16, 2011
Cannot get rid of "ice off" light. any ideas please
When ICE OFF blinks on the display panel, reinsert the bucket and/or make sure it's installed properly.- When the door is open, the Ice and water dispenser do not work.- If you close the door hard, it may cause water spilling over the ice maker.- To prevent dropping the ice bucket, use both hands when removing it.- To prevent injury, be sure to clean up any ice or water that may have dropped on the fl oor.- Do not let children hang on the ice dispenser or on the bucket. They may get hurt.- Be sure not to put your hand or any object into the ice chute. It may cause personal injury or damage mechanical parts.
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.fridge-manual.com/manuals/samsung/Samsung_RSH7ZNRS.pdf&ved=0ahUKEwiwosOus_DOAhVHKh4KHTsECOEQFggiMAI&usg=AFQjCNFRNinR9EZaKSTZcYUjmD6PwdRcTw&sig2=GIUE1SA4LRL2w84ibu5kEA
Appliance 911 Sea Breeze
Aug 08, 2016 | Samsung RSH7ZNRS Stainless Steel 513L...
I have a Samsung RS21DPSM American Fridge Freezer it has stopped making ice the water dispenser works fine but no water going into ice maker?
check the line that runs up the back of the fridge u have to take the back off sometimes there is something wrong w that line or there could be some water has frozen in the top of the line that goes into ur icemaker inside the freezer
Feb 28, 2015 | Samsung Refrigerators
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost in fridge
you have a defrost problem call service
Mar 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Samsung RS2630SH Side by Side Refrigerator Logo
107 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
