Question about Audiovox Televison & Video
Replacement unit for Audiovox VOH681A overhead monitor
The Audiovox VOH681A unit has been discontinued, but I already have an 1187014PL overhead console mounted in my Suburban. Is there a replacement unit out there that will physically fit in the same overhead console?
  • 3 Answers
SOURCE: overhead DVD monitor screen dead but sound plays through stereo
If it's a Rosen dvd player the dvd will need to be put in the unit itself & not the unit in the dashboard! The dvd player mounted in the head ligning is a seperate unit from the stereo system fitted in your dashboard!
Sounds to me like you are putting a dvd into the dashboard stereo system which will play any audio through the car speakers...
Put a dvd into the Rosen unit itself & i am sure you will get a picture on the drop down screen! Remember that as far as i know all Rosen dvd players transmit the sound from the dvd to infra red headphones that should be included! Remember to check the batteries if you still can't hear any sound as they run down quick if the headphones are left on!
Hope this helps....
Posted on Apr 10, 2009
  • 1564 Answers
SOURCE: rear blower not working from overhead or rear
I believe that your vehicle has two large fuse/relay assemblies. One is under the hood and the other"may" be under the drivers side passenger seat. The owners manual will list all, and I mean many" fuses and relays. Check them all with a test light or if you think a relay is at fault just switch to alike relays and see if that fixes your problem.
Posted on Jul 30, 2009
  • 105 Answers
SOURCE: Overhead bulb replacement for 2007 Dodge Grand
You Don't! Take a thin bladed screwdriver along the clear lens and just pop it out (the lens), and voilà! There's the bulb that needs to be replaced. Make sure your screwdriver is not magnetized for your compass will never read correctly when near a magnetic source.
"00 Buck"
Posted on Nov 06, 2009
  • 13 Answers
SOURCE: Audiovox VOD102 : keeps throwing DVD out
bad drive gear needs repair sorry
Posted on May 12, 2010
  • 86 Answers
SOURCE: I have an Audiovox Overhead DVD player in my 2006
You can possibly use the old base but it will depend on the video screen. the new unit will absolutely need to be connected to the radio. Some web sites to ponder on and and these sites have good prices. Hope this helps leave feedback if so. thanks
Posted on Jun 07, 2010
Where to buy a Replacement TouchScreen for my Jensen UV10
You can try going to and see if you can contact them that way. Jensen is now owned by audiovox.
Aug 31, 2012 | Jensen Uv10 7" Lcd In Dash Car Dvd Monitor...
Have a 03 F150 w/moonroof and the compass/temp display has gone out. OEM is not cheap. Any replacement suggestions
It is actually 1 or 2 resistors that have come unsoldered.
If you have a fine point soldering iron, you can repair it. Might want to stop by Radio Shack or the likes and pick up 2 or 3 58 ohm resistors.
Remove the screw from the bottom of the overhead console, and pull down to release the spring clips.
Unscrew the PC Board from the housing, and look at the surface mounted resistors ( they should be marked 580 on them ).
This is what I am talking about on a SuperDuty over head console ( this has 62 ohm resistors / marked 620 )
Missing Surface mounted resistors ( circled in red )
Replaced with 62 ohm resistors from radio shack ( covered in tape after taking picture )
Pat on did a nice write up on this for a F-150 overhead console ( I never got around to taking pictures of a F-150, only the SuperDuty Console ).
Check the Technical Articles / How To forum for a thread titled overhead console repair ( think that is it ).
Nov 11, 2010 | 2003 Ford F150 Regular Cab
Audiovox PVS69701 Dual Screen DVD player monitor has blue screen
I had the same problem, and it seems to be a short in the video cable between the two monitors. I can bend my cable until i see the second screen and then tuck it under the headrest. I am currently looking for a replacement cable. I see it at, but will also check the local radioshack since I need it quickly.
Jul 30, 2010 | Audiovox PVS72901 Portable DVD Player
Digital compass won't work
Is this the overhead console unit that also houses the outside temp reading? If both are dead then it sounds like an internal failure. Dim, intermittent, or dead displays are a common symptom of an internal failure. If the compass is just not reading correctly then it soulds like a sending unit issue.
We offer a reasonable repair service with a lifetime guarantee. Check it out:
Jun 29, 2010 | 2003 Chevrolet Suburban 1500
I have an Audiovox Overhead DVD player in my 2006 Ford Explorer which was installed at time of purchase. It doesnt work at all and I just want to replace it with a better one. My question is, are there...
Jun 06, 2010 | Car Audio & Video
94 suburban PS leak
The brake booster is replaceable a remanned unit cost around 225 dollars and does not include the master cylinder...
Apr 03, 2010 | 1994 Chevrolet Suburban
2002 F-150 supercrew My coumpas-outside tem.quti working.Were is the fuse?
The overhead display is powered by the same circuit for the overhead console, so if the vanity mirrors still work, chances are the fuse is fine.
Just in case, push the button a few times, to make sure the display is not turned off.
The overhead displays have a chance of the surface mounted resistors becoming unsoldered over time.
You can get one at a junk yard, or if you are good with a soldering iron, you can reattach the surface mounted resistors. Pull the overhead console down, and remove the display ( T10 screws holding the display to the console ). There are 2 plastic tabs holding the display together, release these.
On the back of the circuit board, you are looking for a resistor that looks like this :
Feb 23, 2010 | 2002 Ford F150 Regular Cab
Televison & Video Logo
82 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
