Question about Kodak EasyShare LS753 Digital Camera
Lens is stuck out
Camera is on but the lens is stuck out, I can retreive the pictures on the camera but I am unable to take photo's. When the camera is switched on the following message appears. Camera error #E45
  • 2 more comments
  • kodijones Jan 08, 2008
    Camera lens does not close when turned off. And when turned on error message # E45 appears and none of the camera functions work.
    I removed battery and charged it, removed the memory card and try to turn camera on, try to turn camera on using the dock, press shutter. None of these worked.
  • Anonymous Feb 16, 2008
    lens stuck. it works when placed on printer. no other steps taken.
  • TIN13 Aug 09, 2008
    Well I do have a camera LS753 as well and same thing, when I turn the camera on right away starts cracking because is not able to use the lens of the camera due that is stock. Pretty much this means that the camera is a piece of **** and you rather get a new one.
    Even though you can force it with your hands because I did it will work for a bit and will start with the same problem again...
    FYI if you want to pay for the repair and you are in US visit:http://www.kodak.com/eknec/PageQuerier.j...
  • Anonymous Aug 10, 2008
    hey did you fix your prblem .. did you push the lens in or you just threw it away? me having the same problem
Posted on Sep 30, 2009
Push up on the inner lens housing,
Posted on Dec 27, 2006
Camera Lens Stuck Outside
power on while pushing on the lens smack the bottom of camera on table top (half hard)
Jul 29, 2010 | Sony Cybershot DSCW370 Digital Camera
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
D90 - unable to shoot photo & remove lens from camera body
you must try to remove the lens that lens have some electric contacts and if you set the lens in wrong position that contacts give to the camera some error message
Feb 28, 2010 | Nikon D90 Digital Camera with 18-105mm...
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
I take out door photos during day time,Iam getting white screen.
First make sure the mode selector dial is set to the red camera without an M next to it (ie you're in Auto mode and NOT in manual mode). If so...
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Now the A410 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Jul 05, 2009 | Canon PowerShot A410 Digital Camera
My sony
I can fix your camera, it is not an easy thing to post because the post would be forever long....
$20 and it would be good as new.
Jul 12, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Digital camera
My problem is similar. The lens moves very slowly and does not fully extend. In addition, photos are now coming out blurred. HELP!!
Thanks
May 04, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Kodak EasyShare LS753 Digital Camera Logo
814 people viewed this question
Top Kodak Cameras Experts
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
