Question about Vtech Lands Phones
I have the dect6.0 phones; I cannot set a code for remote access. When I key in the 0000 defalt it gives me wrong pin every time. This is a very important feature for me. Ellen stewart
  • 1 more comment
  • stewartellen Nov 23, 2008
    My problem is I canot set my remote code. When I try to set PIN starting with 0000 it tells me wrong PIN. Ellen Stwart
    My problem is I canot set my remote code. When I try to set PIN starting with 0000 it tells me "wrong PIN"therefore I can never set a PIN of my own. Ellen Stewart
  • stewartellen Nov 24, 2008
    I think you are on the wrong phone. I have the "dect 6.0" and the only menu and scrolling are on the handset. My user's manhal lists 6042, 43, 6052, 53.Never mind. I just did it and I don't know how. If I figure it out I will post it. Ellen Stewart
    Sergeant:
    Champion:
  • 347 Answers
Hello stewartellen,
Have your tried the code 1234?
Posted on Nov 24, 2008
    Sergeant:
  • 276 Answers
Handset Setup
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu.
3. Press cid/vol (3or4) button to scroll to Setup HS.
4. Press menu button to confirm and you may program the following items: Ring Volume, Tones, Auto Talk, Handset Name and Language.
Security code
You can access the answering system from a tone dialing telephone in another (remote) location. The security code is required for remote access, and it prevents unauthorized access to your answering system.
From the Answer machine Menu:
1. Press the cid/vol (3or4) button to scroll to the Security code submenu.
2. Press menu button to show the current security code on the display.
3. Use the number keys to enter your new 3-digit security code. The default setting is 1 2 3.
4. Press menu button to save the setting.
Display Messages
The following messages shows the status of the phone, provides Caller ID information, or helps you set up and use your phone.
BLOCKED Indicates the person is calling from a number which is blocked from transmission.
DELETE ALL? Prompt asking if you want to erase all records.
DELETE? Prompt asking if you want to erase the current record.
END OF LIST Indicates that it is the end of the list.
ENTER NAME Prompt telling you to enter a name.
ENTER NUMBER Prompt telling you to enter a telephone number.
NEW CALLS Indicates call or calls which have not been reviewed.
HANDSET NAME Prompt telling you to enter a user name for the handset.
UNAVAILABLE The handset is not yet registered or is out of range.
No line Indicates that the telephone line is not connected.
Line in use Indicates that the telephone line is in use.
Empty Indicates there are no CID records in memory.
Searching Indicates handset is too far away from the base, and the handset is searching for the base.
Page from base Someone pressed the PAGE button on the base.
RPT Indicates a repeat call message. Indicates a new call from the same number was received more than once.
Unknwon Indicates incoming call is from an area not serviced by CID or the CID information was not sent.
Posted on Nov 23, 2008
    Genius:
  • 1,550 Answers
  • Dial your telephone number.
  • When the system answers, enter your Remote Access Code (preset to 50). The system beeps once and then announces the number of new messages.
  • Enter a remote command
  • Press *0 to exit remote operation.
Posted on Nov 22, 2008
I entered the wrong pin three times i need the PUK code to unlock my phone..
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Jul 20, 2011 | Nokia 5230 Cell Phone
Tip
Getting PUK code
Normally for NOKIA mobiles, the default PIN code is 0000.
When you initially starting to use your mobile,your PIN code wil be '0000' and after you can go to 'access codes' to change the PIN code as you want.
Security code is 12345
For MOTOROLA mobiles, the default PIN code is 1234.
security code is 000000
For SONY ERICSON mobiles, the default PIN code is 0000
As you set up a new PIN code and if you forget your pin code and you already entered your wrong PIN code 3 times ,then this may lock your phone and it wil ask for a 'PUK code'.
If it asks for the PUK code please call your service provider and they wil give you the PUK code.
NOTE:You cannot call from your mobile as your mobile is fully locked. please use any other mobile to call the service providers.
Before giving the PUK code they wil ask for your informations to cross check with the Data base that they have. please give the correct information to them,if they are not satisfied with the information given by you, they may refuse to give you the PUK code.
thanx
on Jul 17, 2010 | Cell Phones
Tip
About PUK code
A PUK code (Pin Unlock Key) is required when you enter an incorrect PIN (Personal Identification Number) 3 times. After entering the wrong PIN 3 times, the card will be locked and you will need to get a PUK code from your service provider to unlock it.
Once your PUK has been send to you, you should enter it into your phone to set a new PIN code, that will be four zeros "0000"
Note: If the wrong PUK code is entered ten times, the SIM card becomes invalid and you will need to get a new SIM Card. The phone will display "PUK blocked call operator". that will cost you money.
So please be carefull before entering PIN and check twice.
Best regards
on Apr 18, 2010 | Cell Phones
I bought one SAMSUNg SGH-J700i. When I am trying to poweron the phone it asks for Phone lock password which is 1234 and opened but immediatly it asks for SIM loack password. But I am not awrae of any SIM...
If u enter PIN code incorrectly 3 times, PIN will be blocked n phone will ask you for PUK(Personal Unblocking Key). This is a 8 digit code. If u enter Incorrect PUK for 10 times Your SIM will be lock permanently.
Your cell phone service provider can(Call from other no. n ask tell them for puk of ur no.) give you the PUK code aft3r answering simple security question.
Later enter PUK than enter new PIN, confirm new pin. Go to -Setting
-Security
-SIM lock
-off
Disable SIM n Later Phone Lock
PS:(You have to block your PIN to get access to PUK,
Default PIN- 0000, 12345)
Apr 18, 2011 | Samsung J700 Cellular Phone
Code of my nokia 7230
basic codes are either 0000 or as many 0s as possible
if you do not know the code contact your network saying your phone is blocked and requires your puk code they will give you this then enter the wrong code too many times block your phone then you enter your puk code then you will be able to enter a new pin of your choice this is the only way
Feb 27, 2011 | Jensen 143307 Remote Control
Cant get remote access working Binatone Symphony 2210 cordless ph
If you have set up the TAM settings correctly then it seems to be a fault with the machine. I've set up my TAM settings with new pin and I still can't remotely access the messages.
Make sure you are pressing the * key before you enter the default code (as far as I can recall).
Apr 05, 2010 | Lands Phones
Locked my phone and forgot code w810i sony ericsson
Try clearing pin code 0000 Manufacturer manual inside cover usually has factory settings Call operator for factory pin setting w/o manual
PUK code in PIN UNLOCKING CODE, which is required when you give PIN number wrongly for 3 times, so be careful with this
This code is OPERATOR specific and not phone specific and you have to call you operator and get PUk if PIN is blocked...
if you provide PUK code wrongly for 7 time, your PUK may be blocked and sim may become useless.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 18, 2009 | Samsung SGH-e315
I accidently did the PIN code request setting. I didnt know the PIN so now it says PUK blocked. How can i fix this?
Try clearing pin code 0000 Manufacturer manual inside cover usually has factory settings Call At&t for factory pin setting w/o manual
Aug 07, 2009 | LG Shine KE970 Cellular Phone
PIN code
enter either 0000 or any four number code your choice .but the other phone will the same code and access the file throught bluethooth and save .
riz.
Apr 08, 2008 | Sony Ericsson T630
Remote access
Call into your unit, press the * key twice, enter your pin and listen to the menu options. If you need the manual, you can go to www.cordlessrepair.com for a free download. Look on the left hand side for user guides and manual link, that will take you to a list of manuals for your model. In the meantime, if you forgot your pin you will need to reset the pin and choose a new one since remote admin will not work with the default pin of 0000. If you need to reset your pin, on your base push Menu, scroll to System Settings, then dial * 6 5 #, that will reset your pin. Then go back into system settings and change the default pin of 0000 to a four digit code you can remember. Once that is done you can call into your machine remotely, and when you hear your greeting playing dial * twice, enter your pin and your in.
Jan 29, 2008 | Siemens Gigaset2420 Cordless Phone
Lands Phones Logo
83 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
