Water Heaters Logo
Anonymous Posted on May 14, 2012
I need a replacement remote control for Rinnai 406tr
Kevin Getz
Level 3:
Genius:
  • Master 1,032 Answers
  • Posted on May 15, 2012
Kevin Getz
Master
Level 3:
Genius:
Answers
1032
Questions
Helped
324507
Points
3063
Our hot water will stop coming through the tap until we reset it on the rinnai wall control and then it works again?
trouble shooting section will help https://sahotwater.com.au/specifications/Rinnai/Service%20manual/smV1616W_V2018W_V2020W.pdf
1helpful
I am trying to increase the temperature on the controller and it wont change. I have installed a new one and it still will not increase
[PDF]Operation / Installation Manual - Rinnai
https://www.rinnai.us/.../V_Series_Indoor_25xx_U...
Rinnai America Corp.temperature (shown on the digital remote control) the gas burner will ... Without the connection of a remote controller(s), the Rinnai Water Heater is preset to.
PDF]Tankless Water Heater Service Manual - Rinnai
https://www.rinnai.us/.../100000098_Rev_B.pdf
Rinnai America Corp.Indicates condensing water heater models. ... Rinnai Water Heater Service Manual. 2 ..... Digital manometer or U tube type manometer with 14 inch water column (W.C.) scale, a hose and two .... will flash on the display of the remote controller.
Can I convert a Rinnai natural gas water heater to LP.
A registered gas installer can obtain parts through Rinnai stockists and convert most heaters.
How do I turn it on? I press the "on" button and
The manual says:
http://www.coinwash.com/temp/rinnai.pdf
"For the name of the Authorized Distributor or Installer nearest you, please contact your local HVAC dealer or gas service technician, visit the Rinnai website (www.rinnai.us), call Rinnai at1-800-621-9419 or write to Rinnai, 103 International Drive, Peachtree City, Georgia 30269"
Manual says that the remote is for setting temperature.
When you turn on hot water spigot, tankless water heater will heat the water to the set point temperature.
If water heater is not set up to use remote, then tankless unit will heat to 140 degrees F.
"With the MCC-45-4US remote control installed the water temperature is adjustable from 96
to 180°F. The water temperature cannot be set to a temperature other than 140°F
without the use of the MCC-45-4US remote control unit. If you require a temperature
other than 140°F you must install the MCC-45-4US remote control unit."
"Error messages are displayed on the remote control units, simplifying service calls."
Page 9 of manual shows hot to set temperature using remote.
Water taps must be shut off to set temperature.
Circulating pump must be turned off.
"Simply press the H or C button until desired temperature is displayed"
"green in-use indicator will display"
If your unit is not working, the manual says to contact local plumber.
Fixya has specialists who will talk to you by phone about your problem for a fee.
Want to change water faucets
Centre tap of the rinnai will turn off hot water supply only.
Easiest way is to turn off your mains water supply. This will isolate both hot and cold, no need to turn off anything else
Cant find replacement Rinnai thermostat
Try National Energy they are on line they sell spares they may be able to help .
Hi, our plumber has hooked up a new infinity xr-26 but the existing remotes don't work. He says it's a simple 2 wire connection but ther's no cirrcuit
Check with Rinnai to see if the old remotes are compatible with the new heater. Might mean upgrading the remotes too but the wires should be OK. Double check that he has actually connected the wires to the heater. Rinnai in Australia recentyl changed the connection point for the wiring. I can help further with this if this is the issue (not sure where you are!)
1helpful
How to install rinnai 2532 Continuum Individual temperature control
if you mean additional remotes then go to rinnai.com and enter your model number. go to owners manual and it gives step by step instructions
No power to keypad
I had a similar problem, the water flow control device was bad.
If you disconnect Connector B2 and the unit will start, then that will confirm the problem. Rinnai has a new improved part for replacement.
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
