Question about Cooktops
Voltage what is the voltage rating on the Kenmore electric range model # 911.42479890 and the Frigidaire electric oven model # RG94BF*1
    Sergeant:
    Champion:
  • 338 Answers
Voltage should be 240v on either one. however it could go 10v either way
Posted on Nov 26, 2008
I have a frigidaire ples389dcc as soon as i plug it in it give me a pf code
Good Morning Paul, thank you for your post!
Based off what you have described your Frigidaire range, PLES389DCC, is providing you with an error code of "PF" and "F1" as soon as you turn it on. An error code of "PF" stands for power failure this could be a possible problem with your control panel or power cord.
The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F1" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Apr 10, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
How do I reprogram a Frigidaire stove/oven after replacing the eoc?
Thank you for your post, Roy!
Based off the information you have provided you need to reprogram your Frigidaire range because you have replaced the oven control. The best way to reset your range is to disconnect power from it for roughly ten minutes. If that does not help resolve your issue you may need to have another electrical component changed and I would recommend seeking assistance from a professional technician for proper repairs. I hope this information is helpful. -Matt
Mar 28, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Frididaire electric stove the oven has stopped working
Good Afternoon Friend, thank you for allowing me to assist you!
I understand you are experiencing an issue with the oven of your Frigidaire range. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? Do the burners/elements work? With this information I can assist you better in pinpointing the problem.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you! -Z
Sep 05, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
F14 Error
First please get the full model number of the range. Kenmore products are made by other manufacturers and the error codes will depend on the manufacturer.
Most likely, you have a Frigidaire range (for example a 970. model). Then the F14 code could indicate a problem with the P12 ribbon cable connector tail, a bad EOC (control unit), or touchpad. First try disconnecting and reconnecting that cable. Next the EOC should be replaced. Finally the touchpad should be replaced.
If this is a brand new range, contact Sears to get a repair person to fix the range. If you bought it used, see the above possible solutions.
I hope this helps.
Dec 24, 2013 | Kenmore 30" Electric Double Oven...
Frigidaire model fef336fmf troubleshooting
Hi jontherun5 - What is the problem your electric range is having or concern on the product?
Sep 20, 2012 | Frigidaire Gas & Electric Stove/Oven/Range...
Keys on the oven are not working so I can not start oven bake
Thanks for posting to Fixya I will be helping you today. You have posted that you have a Kenmore Elite 44173 electric cooktop with a problem. However, you also mention your are having trouble with the oven not working. This post maybe categorized wrong but I will try to answer you question for both a range and oven control.
Sometimes on a cooktop customers will lockout the controls on accident while cleaning. Usually there is a button on the control that you hold for 4 seconds +/- and there is a little simbol of a padlock next to it or you might have to check the owners manual.
Lastly, Ranges may also have a lock out feature that the customer must press 4 seconds too unlock. On select models controls may also be locked out by putting their oven into sabbath mode. Usually the display will indicate a "SAB" to alert that this feature has been set.
*In general the above instructions should help if your unit is locked out.
Happy Holidays!
"Please rate this information "4 thumbs" if you found informational.
Dec 02, 2010 | Kenmore Elite 44173 30 in. Electric...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktops Logo
100 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
