Question about Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool electrice stove storage drawer
Storage door underneath smoothtop range is hard to open and close. Does not pull out easily and when pushed all the way in, looks crooked. Top part of drawer looks to be further in than bottom. Does not look like there's any missing parts. Stove model is F196LXKQ
There is a screw in the bottom of the two back corners that holds the drawer glide in place. Remove the glide and then you'll be able put it back the way it belongs.
Posted on Jul 17, 2011
  • tjn1020
    tjn1020 Jul 06, 2012
    Thank you John!! I just found those screws and fixed simple yet it took forever to figure it out!
  • 171 Answers
Remove the drawer and put back the corret way , It is out of track.
Posted on Dec 06, 2008
  • cmarcuz Mar 29, 2011
    But I cant get the drawer out of the track. Any ideas? Are there clips or something I dont see?
Door closes but stop in close position (jamm}
Has the spring at the top broken or come unwound? The spring helps pull the door open and the unit will not work unless the spring is working. Pull the cord and unlock the door from the opener and try to push it up by hand. If it is hard to push then you know the spring is not working. if its an older door the springs could be on the sides.
Sep 26, 2016 | Building Materials
How does plastic head cover pull off on a head split system Panasonic split system air conditioner
Look for 2/3 small plastic covers for screws just under the louver(s) one at each end of the air discharge opening and one in the centre (maybe). Pry these off gently with a small screwdriver and you will see the screws underneath. Remove the louver first to make access easier. There may also be a screw in the centre just above the louver.
Once all the screws are out, the cover should lift up easily from the bottom and then release from the top clips. If it doesn't come off easily, you may have missed a screw.
Jan 26, 2016 | Panasonic Heating & Cooling
Only one burner doesn't work on my maytag gemini stove
MET8776BS Maytag Gemini Smoothtop Double Oven Range
Rating: 4.5 - ‎94 reviews MET8776BS Maytag Gemini Smoothtop Double Oven Range - Stainless Steel - Reviews ... Really like the features, however one burner doesn't work, after a month.... 2 ovens sure beats the storage bin underneath! the only negative I can think of is ...I bought my double oven a few months ago and am very happy with it.
Oct 16, 2015 | Maytag Kitchen Ranges
Refrigerator isnt cooling, freezer is working fine. Vacuumed out underneath, turned cooling system off, unplugged for some time and plugged back in and reset temps. I can hear the fan running, and have...
light switch could be stuck on, to check that open the door somewhere on the side or bottom, there will be a little button, push it in & hold it, to see if the light goes out, if it does not go out, push it a couple of times more to help it to come unstuck, if the light will not go off the switch has to be replaced
the thermostat could be set to low, adjust to a higher number
check the door seal,; open the door 1/3 way,,& let go of the door,,see if it closes on it's own,, it should be a little hard to open after it's been shut,, also stick a dollar underneath the door seal & close the door,, then pull the dollar bill out & there should be a little drag,,if it pulls out to easy then the door needs adjusting,, or the door seal is bad...
to see if the seal is bad,,open the door,, & look at the seal,., it should not be flat or squashed in places, it should be firm all the way around,,
to adjust the door,, look on top of the frig,,there will be a door hindge on top,, some have a plastic cover & some don't,, if your has one remove it,, there should be 2 screws,,loosen both screws BUT DON'T TAKE SCREWS ALL THE WAY OUT,, grab the door & move it till it's even with the side & top,,,
then tighten the screws back,, then recheck with the dollar bill,,,
there are 10 other problems that would require a service tech to check & fix
hope this is helpful
Aug 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Oven won't ignite
Your range is a Direct spark model.ce00970.jpg8278a1e.pngIf you want a Direct spark manual, let me know. The module gets confirmation from relay on the oven control and sends dc power to the gas valve. I suspect that gas valve be cause the top burners work which is usually and indicator that the module is fine. The terminals ohms should be 216 ohms between each of the 3. If any are open the valve won't work.
Jun 01, 2010 | Whirlpool GS460 Gas Kitchen Range
I am trying to replace a burner on my amana smoothtop electric range. I have removed the three screws above the overn door (inside). The top is loose but something seems to still be holding it. Any...
most ovens usually have 2-3 screws located along bottom edge of the smoothtop in the front..check the far left and far right corners in the front /if all screws are removed,you may need to pull slightly forward then raise
Mar 06, 2010 | Amana AER5715QAS Electric Kitchen Range
Husband removed oven door when fully open instead of when 1/4 open as the manual suggests, now the door clicks a couple times as it is nearly closed, model number 95592 Kenmore electric smoothtop range...
Try removing and refitting it a few times otherwise you will probably have to get new door latching mechanisms. You may just be lucky that they have been dislodged but they are most likely to have been broken. The clicking is the door interlock mechanism trying to lock and unless it succeeds the oven will not work.
Oct 24, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Oven door staying open about 1 inch
your going to have to replace both the door hinges, since they have been over extended past ninety degrees they are not able to close to ninety degrees. that is the only repair, i would also look closely at the inner door panel and make sure that is not "crowned" or bent from the force that might also need replacing
Nov 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool range
Hello dolphin 1 mom
Welcome tofixya.
You said, accidentally removed the door to my range and now it won't go back on. The door won't go back into the slots on the range.
Send me your e-mail address and I'll e-mail the diagram with the door instructions for removal and replacement.
It will not fit in here with the diagrams.
Waiting for you.
Please do not forget to enter a rating when we are done
These are the installation instructions, but with no diagrams
To Remove:
1. Open the oven door. Insert door removal pins, included with
your range, into both hinge hangers. Do not remove the pins
while the door is removed from the range.
2. Slowly close the door until it rests against the door removal
3. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on the inside surface.
4. Pull door straight up, then toward you. Hinge hangers will
slide out of front frame hinge slot. Do not remove door
removal pins until the door is replaced on the range.
To Replace:
1. Grasp the door on the sides with your fingers on the front of
the door and your thumbs on its inside surface.
2. Hold oven door so that the top edge of each hinge hanger is
horizontal. Insert hinge hangers into the front frame hinge
3. Tilt top of door toward range. Slide hinge hangers down onto
front frame support pins. Make sure the hinge hangers are
fully seated and engaged on the support pins.
4. Insert the door stop clip with its angular surface at the top of
the frame hinge slot, then push in the bottom of the clip until
its flanges are flush with the front frame.
5. Open the door completely and remove the door removal pins.
Save door removal pins for future use.
6. Close the door.
The storage drawer can be removed. Before removing, make sure
drawer is cool and empty.
To Remove:
1. Pull the storage drawer straight back past the drawer stop
notch and the end of the side rails.
2. Lift up the back of the drawer and pull the drawer out.
To Replace:
1. Lift up the back of the drawer and place it inside the range in
its fully forward position.
2. Lift up the front of the drawer to a level position.
3. Slowly push the drawer into the range until the drawer side
rails engage with the gap in the drawer glides.
4. Once the drawer is fully engaged on both sides, slide the
drawer back into the closed position.
NOTE: When removing and replacing the storage drawer, a slight
push may be needed to move the drawer stop notch past the
drawer glides.
A. Removal pins
B. Hinge hanger
A. Hinge hanger
B. Door frame hinge
C. Support pins
A. Drawer stop notch
B. End of side rail
A. Engage drawer glide
Sep 09, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Whirlpool GR465LXLS Electric Kitchen Range Logo
1,014 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
