Remove drum paddle from hotpiont wma37 washing machine
Hi does anyone know how to remove a drum paddle from a hotpint wma37 washing machine.
a technician once showed me (as this then allows you easy access to remove things stuck between the drum and casing, which i have now got lol) and i think it was something to do with the small holes on the top but i cant remember now.
  • tino1595 Nov 22, 2008
    thanks for that but still cant find the bra-wire that must be stuck inside.
  • Washing Mach... Master
  • 3,463 Answers
Hi.
Firmly grip the paddle, and pull it towards you, this should release same. When you put it back, locate the paddle in the slots, and push firmly away from you
towards the rear of the drum
Good luck
Posted on Nov 22, 2008
  • Barry Coates
    Barry Coates Nov 22, 2008
    Hi. Re bra wire.
    If you cannot hear it catching as drum is turning, then I would not worry too much, it will probably be stuck around the heater, where it cannot do much harm.
    If you do hear it catching, I would recommend that you do not use trhe washer until you find and remove it.
Hi, My washing machine drum appears to be loose. When the drum is turning slow it seems to go side to side as well as rotating. When the spin initially starts the drum seems to bang on the sides of the...
Sounds like worn drum bearing however check the top spring is not snapped.Remove lid you will see if spring is broken if not and suspect bearing its quite an expensive job,do you know Hotpint have a 5 year warranty on parts only call charge is around £105........Worthwhile considering as the parts would cost around this to buy excluding labour...Good luck
Jun 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
Where can i buy a washing machine drum paddle (for inside the machine) one has snapped off today.
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
Mar 23, 2010 | Indesit W 123 Front Load Washer
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
How to remove and replace the paddle on a Hoover HSE140 Washing M
pull the paddle towards yourself and lift up it should come out to replace reverse instruction
Jun 23, 2009 | Washing Machines
Need to remove drainage pipe, can't remove white plastic clip, is there a knack?
Remove power first! The pump is very easy to remove, ( unlocks from the base ) take the pump apart and check for foreign objects inside the pump assy. The power wires pull off and matters not which way they go back on. Also check the hoses to and from the drain pump for any  foreign objects. The pump is usually at the back right side ( looking at the washer from the front ).
May 07, 2009 | Hotpoint WF430 Front Load Washer
How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Hotpiont washing machine
first check if belt from motor to drum is on, then check to see if motor is running. If not, there maybe a fuse link or fuse that needs replacement. The last time you used did you smell burning, if so could be your motor is gone.
Apr 03, 2008 | Hotpoint Aquarius WD63 Front Load...
Drum Paddle broken Hotpoint Aquarius
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
231 people viewed this question
Top Washing Machines Experts
