When printing from the computer the text is off center. The right hand side of the printed material disappears beyond the margin. All letters et al, are printed about two inches off the right. Left margin is OK.
There are two possible culprits for this problem.
1. The wrong driver is being used for your printer.
2. The paper thinks it is printing to different sized paper than it actually is.
To solve the first case:
Verify that the correct driver is being used. Go to the Control Panel (Start, Settings, Control Panel) and open up the Printers and Faxes component by double-clicking on it.
Right-click on your printer and go to Properties.
A new window will pop-up. Go to the Advanced tab and verify next to where it says 'Driver' that it lists your model of printer.
To solve the second case:
Exactly as you did above, under the Advanced tab, click on the 'Printing Defaults' button.
Then click on the Paper/Quality tab on the new window.
Under the Paper/Quality tab click on the 'Advanced' button.
A new window will pop-up. Where it says Paper/output, expand it (click the plus) to list Paper size. Change Paper size to match the size of the paper you are printing (Letter is the default 8.5" x 11").
