Question about West Bend 13500 Coffee Maker
Coffee maker heats but does not ''perk''
We have two Westbend 100-cup coffee makers. Both of them will now heat water, but no water comes up through the center tube to actually wet the grinds and make the coffee. One pot reached this condition months ago, and yesterday the 2nd one (we bought to replace the 1st one) did the same thing. When the perking sounds stopped, we removed the lid and the grinds were dry. We have made sure the tube was properly inserted into the bottom hole.
The sounds when "percolating" are "different" - as if straining. Any ideas? Small appliance repair shops are few and far between anymore.
  • chicbbqsue Nov 22, 2008
    Thanks, we'll try that and get back to let you know how it worked!
  • Anonymous Mar 30, 2014
    12 cup percolator perks a short time. no coffee, the grinds doesn't get wet.
    President:
  • 2,992 Answers
The well at the bottom of the pot where the tube fits in can get coated with mineral deposits from hard water, and this causes the problem you're having.Some brands of coffee makers come with a cleaning tool for this. It's a flat metal piece that fits the well, and you use it to work a piece of steel wool (plain, not a soap pad!) back and forth to scrape off the buildup. If you don't have the tool, you can just cram a wad of steel wool into the well and twist it around by hand. It also helps to pour in Lime-Away (or a similar kind of cleaner) to fill the well and cover the bottom. Let it soak for a while, use the steel wool (wear rubber gloves to save your hands), and finish up with a thorough washing.
Posted on Nov 22, 2008
Also the tube can get bent at the bottom and will not seat properly. If that seems to be the problem, West Bend does sell replacement parts for a reasonable price.
Posted on Jan 12, 2009
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
Do you have to boil water in something else first
No, it's an electric coffee pot, it heats the water and makes the coffee simultaneously.
May 31, 2014 | West Bend (58036) 36-Cup Coffee Maker
When i use my reusable k cup, water comes out all over
Use the $15 reusable Kcup with a rubber seal ring. If the lid is not down and sealed it will over flow with grinds. Press down firmly after filling with grinds. Also, clean tubes Top/Bottom with a paper clip to free them from debris that clog the tubes. Use distilled water also.
Jan 07, 2014 | Keurig Coffee Makers & Espresso Machines
My westbend coffee perculator is tripping my circuit breaker
often happens when using the Westbend and other appliance on the same circuit. Once the coffee is perked heat maintenance is no problem for the circuit, but two heavy users on the same circuit, i.e., coffee maker and microwave or coffee maker and roaster oven is asking too much
Sep 16, 2013 | West Bend 33600 Coffee Maker
How many coffee scoops do i use for 30 cups and 36 cups
The Instruction Manual for your coffee maker can be found here:
http://www.westbend.com/supportdata/L5590A_Coffeemakers_ALL.pdf
Instructions include the following:
Water Level Amount of Ground Coffee
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
Aug 02, 2011 | West Bend (58036) 36-Cup Coffee Maker
How much coffee would it take to make the 55 cups in this coffee maker, and can you use the same coffee as you use for drip machines?
Your model sounds like the West Bend 59055 - Large Coffee Urn, 60 Cup.
The User Manual for your coffer urn can be found here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
Instruction for making coffee can be found on page 5. For 55 cups is would take 3 1/4 cups of coffee.
Use an electric perc or regular grind coffee; if you grind your own this should be a medium to coarse grind.
Do not use 'drip' or finely ground coffee as this could plug the drain holes in the basket and cause the urn to flood.
Mar 24, 2011 | West Bend (59055) Stainless steel 60-Cup...
Where can I replacement filters for a 100 cup West Bend coffee maker?
The West Bend Large Capacity Coffemakers do not use replacement filters. The manual for the West Bend 33600 Large Coffee Urn is available here:
Use an electric perk or regular grind coffee in the percolator basket rather than a 'drip' or finely ground coffee that would require a filter.
If you require a new basket, please see the West Bend on-line replacement part site here:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=946&secid=87&linkon=subcategory&linkid=125
Mar 19, 2011 | West Bend 33600 Coffee Maker
Coffee to water
The Instruction Manual for the West Bend Coffeemaker can be found here:
See page 4 for amount of coffee to use.
42 Cups 2 ½ Cups
36 Cups 2 Cups
30 Cups 1 ¾ Cups
28 Cups 1 2/3 Cups
24 Cups 1 ½ Cups
22 Cups 1 ½ Cups
18 Cups 1 ¼ Cups
12 Cups 1 Cup
Use electric perk grind coffeeror coofee ground for all coffeemakers. Do not use drip or finely ground coffee.
Mar 19, 2011 | West Bend (58036) 36-Cup Coffee Maker
How to measure coffee for 45 cups. Also is a filter needed.
100-CUP MODEL #33600
Water Level Measure of Ground Coffee
100 cups 6 ¼ cups
80 cups 5 cups
60 cups 4 cups
40 cups 2½ cups
Do not make less than 40 or more than 100 cups of coffee at one time. Use electric perk or regular grind coffee; a filter liner is not necessary.
Mar 09, 2011 | West Bend 33600 Coffee Maker
West Bend 13500 Coffee Maker Logo
502 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
