Question about Bosch HES 252/ HES 256 Electric Kitchen Range
Oven door remained locked after self clean
Self cleaning was activated in the middle of the night by roaches which have enjoyed crawling across the board on the top of the range - where the display is.
By 3:00pm in the afternoon I heard something pop or crack so I turned off the range at the circuit breaker.
Even after the range cooled down it remained locked for days.
Since then I have taken the range apart and cleaned it fairly thoroughly.
The display on the control panel reads error 43 - and the little "lock" icon displays.
I took off the range top and systematically removed at least five of the eight or so leads to the motor that latches the oven door. The "lock" icon went away. Then I turned on the oven and it would start heating. However, the second the oven sensed it was heating - when the temperature would logically display 110 vs the starting temperature of 100 degrees - the error 43 message would return and the oven shut down - stopped heating.
Even though I kept removing wires from the latch motor the oven would only start to heat for a few seconds and then stops.
The question is which board controls the sensing? and do I need to replace it?
3 Suggested Answers
  • 195 Answers
SOURCE: Error when self-cleaning - oven locked
Here is the error code and things to check on your oven.
Error Code: F41 Cause: Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check that the solder joints in header P24 on the power board are not broken. 5. Check P10 connector and check if latch motor wire is
Regards
Alan Hood
ami-man
Posted on Dec 04, 2009
bbl242003
  • 1637 Answers
SOURCE: I have a Bosch HEI7282U range. Went through self
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut
Posted on Jan 31, 2011
I went to clean my oven last night but my oven door wasn't latched. I started the cleaning and the word "door" flashed on the screen. Sure enough my door was not fully latched but the lock mechanism had...
HELLO,
HERE ARE SOLUTIONS ON HOW TO CLEAN THE OVEN OUR SELF
self cleaning solution
  • 1 Remove oven racks and soak them in soapy water
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    Thanks.
    Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
    After self-clean cycle oven door won't unlock
    your lach might have given out on self clean. change it
    Feb 12, 2010 | GE Profile JTP18 Electric Single Oven
    Oven door remains locked after using the oven cleaning feature
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Dec 12, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
    Oven door locked.
    The F9 code indicates there is a problem with the door lock.
    Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
    Try canceling the clean cycle without putting the control into clean.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$%!!!%!%
    Oct 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Door locked after cancelling self clean option
    Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
    If you need more assistance let me know.
    Mar 29, 2009 | Ovens
    Oven Door Locked
    the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
    Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven door remains locked after completion of self clean cycle
    My oven door stays locked , when I press the clear button I get F1?
    I hold the clear button for a few seconds and still nothing.
    Please,
    Thank You
    Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Self-cleaning gas oven
    Door lock motor has probably failed.....Self clean on many
    ovens can be a self destruct mode. Door latch motors, sensor
    probes and even the electronic controls can be destroyed by
    this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
    Jun 02, 2008 | Frigidaire Ovens
    Self cleaning oven directions
    Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
    Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
    Bosch HES 252/ HES 256 Electric Kitchen Range Logo
    70 people viewed this question
    Top Bosch Kitchen Ranges Experts
    Oloyede Monsuru
    Jim Thurston
    Joseph Hoffmann
    Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
