Question about Canon Rebel XT / EOS 350D Digital Camera
Manually setting shutter speed and aperture..
I have just started learning about using camera...I bought Canon EOS 450..i would like to know if it has the feature of setting both shutter speed and aperture manually?
    Problem Solver:
  • 9 Answers
Http://web.canon.jp/imaging/eosd/eosdigital4/specifications.html
First off, welcome to the world of photography! Good luck and have fun!!!
Like any slr, you have the option of Manual exposure. I'm not familiar w/ modern Canons (I use Nikon). According to this page, however, you also have aperture priority and shutter priority. I'm pretty sure ALL modern Canons have bracketing modes as well (Use this for HDR).
I couldn't find the 450 manual (I'm assuming Canon's web devs are behind), but I did find the instruction manual for the 400 :
http://gdlp01.c-wss.com/gds/0900000357/EOSDRXTi400DIM-EN.pdf
Should be similar, probably w/o some of the functions. Although you SHOULD have a book w/ your camera ;). Read it thoroughly.
Ok, according to the 400 manual, put your camera into Manual mode, then adjust the regular dial to adjust shutter speed. Then, to adjust aperture, hold in the A/V button while you adjust the same dial.
Like I said, may be a bit different. I think the dial may even be digital buttons rather than analog...
hope this helps!!!
Posted on Nov 22, 2008
I'm trying to find out if the Canon Eos 3000N 35mm SLR camera has manual Aperture, ISO and Shutter speed control's? Can you help?
Although the 3000N relies on batteries for all functions and has various auto exposure and DX film coding modes, you can override and manually select all the exposure functions you have mentioned.
Aug 24, 2011 | Canon EOS 3000 Kit 35mm SLR Camera
I did not get any instructions with my Opteka. Have tried to take photos with it. But they came out all blank. I used a tripod. Would like to know where I can down load instructions. Certainly not as good...
You did not provide enough information to determine what your problem is. For example, were the pictures all light or all dark. Knowing this lens, I will assume that they were all dark. So...
1) This is a very, very slow manual-focus lens. It will not auto focus. It must be manually focused very precisely because it has virtually no depth of field.
2) Depending on your camera, your internal light meter may not work. On my camera (Nikon D-90), it does. If it does not on yours and I suspect that may be your problem, you're going to have to shoot everything manually, i.e. setting the shutter speed and lens opening yourself. You can use your internal light meter to help you get started by taking your light reading before you install the lens...preferably using the aperture only setting where you set the aperture at f8 which I think is the speed of the Opteka and let the camera set the shutter speed. Make a note of the shutter speed then attach the Opteka to the camera and mount the lens on a tripod with the camera attached.
Then set your camera mode to manual and set the aperture to match the lens (f8, I think). Set the shutter speed at the speed you noted earlier. Shoot a picture using a remote shutter release or the self timer. This lens is so slow that unless you're in exceptionally bright conditions you will get fuzzy pictures due to camera movement at full zoom of 1200m and above if you're using the 2X doubler. I would start shooting at minimum zoom of 650 without the 2X doubler. Shoot a picture. and check the result.
You should have an image but it may be too light or too dark.
If its too light you'll need to increase the shutter speed or stop down the aperture to, say, f11...or both. Make the adjustment and shoot another picture. Remember that if you increase the aperture, you increase your depth of field, making focus less critical. If you increase the shutter speed you make camera or subject movement less critical.
If it's too dark, you can only increase the shutter speed because you can't open the lens any wider than f8. Make the adjustment and shoot the picture.
Keep doing this until the pictures are the way you want them.
This is a decent lens for the price and worth the little money they cost if you can't afford $10,000 plus for a high quality telephoto lens of this size. I would forget about the 2X doubler because as others have said, it further reduces the speed of an already very slow lens with such a high rate of magnification that a knat landing on the lens could cause the picture to blur from movement.
Jun 26, 2011 | Opteka 650-2600mm High Definition...
I'm having problems with the settings on my Canon EOS 400D. When I take pictures in AV mode I can get quality pictures but in TV or M modes the pictures always come out so dark even when taking them...
You need to understand the relationship and teractivity of aperture, shutter speed and iso. In Av mod, you choose the aperture and the camera makes thw shutter speed agjustment, In Tv mode, you set the shutter speed and the camera makes the aperture adjustment, In manual, you have to set both shutter speed and aperture manually. If the ISO mode is set to AUTO, the camera chooses the sensors sensitivity to light automatically. Change to specific ISO
(200-400 for daylight and 799-1600 for night). Take a picture in AV mode and note what shutter speed the camera chose. Then switch to TC mode choose the same shutter speed and see if camera chose the same aperture(f-stop) you chose in first shot. Change to Manual and choose same f-stop and shutter speed the camera chose for you in the other modes. Compare all three photos. They should be almost if not exactly the same exposure wise.
In Tv mode choose a dlowers shutter speed, In Manual choose a combo of slower shuuter and wider f-stop(smaller number). Read your manual.
Jan 02, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
I'm using a Canon EOS Rebel X S 35mm SLR What setting should i set my camera for a manual shutter speed?
If your camera is a Rebel XS you should have a dial on the top right with a series of letters and icons. To set your camera so you manually control the shutter speed turn this dial too "TV" (Time Value). This setting will allow you to select the shutter speed and the aperture will open or close to achieve the correct exposure. The "M" is (Manual) where you would select both the shutter speed and aperture "AV" is (Aperture Value) where the user selects the aperture they want and the shutter speed increases or decreases to obtain a proper exposure. The "P" (Program) mode allows the camera to automatically select the shutter speed and aperture
Dec 06, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Cannot adjust aperture or shutter speed in manual modes
Suggestion.... try to reset all settings to default. See what happens then.
Sep 08, 2009 | Canon Cameras
Aperture setting and shutter speed together?
Yes it does. Check your manual. If you don't have a manual you can get a pdf download from canon. This link should get you there. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=214&modelid=9429#DownloadDetailAct
Sep 01, 2009 | Canon EOS Rebel K2 35mm SLR Camera
Action shots
Action shots generally require a fast shutter speed -- to freeze the motion. So you need plenty of light or a "fast" lens. A fast lens is one in which the aperture opens further to let in more of light. The smaller the number of the maximum aperture, the faster the lens, so a 28-105mm f/3.5-4.5 lens is "faster" than a 28-105mm f/4.0-5.6 lens. But usually, faster lenses cost more.
For the settings on the camera, the Rebel K2 has a Sports image mode (silhouette of a runner) on the control dial which should get you appropriate settings for most action shots.
If you want to set the shutter speed yourself use the Tv mode, and with a fixed shutter speed, the camera will set the correct aperture. Watch in the viewfinder -- if the aperture value is flashing, it means the shot will be underexposed. You will have to select a slower shutter speed.
Another way to get action shots with limited light or a "slower" lens is to use film with higher ISO/ASA. ISO 100 film is good for daylight shots, but for inside shots or evening shots, use ISO 400 film. Higher ISO film is "grainier", so enlargements will show less detail.
May 07, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Camera features canon 18-55 digital cmera EOS 350 D
It does different things depending on the camera settings and only works in the creative zone settings not the automatic settings.
In AV mode it changes the aperture
In Tv Mode it changes the shutter speed
In M mode it changes the shutter speed unless the AV button is pressed when it then changes the aperture
Apr 06, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Aperture priority, shutter priority
You might try overriding the white balance by setting it for fluorescent. Those bulbs are the usual cause of the green hue
Feb 12, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
240 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
