Question about Refrigerators
Leaking frig. I have a side by side Hot Point CSH24GR. Every 2 to 3 days there is a puddle of water in front of the frig. I see nothing leaking and if there is a clogged drain - where is it?
Freezer bottom, take out the drawer, There is a gutter in the back elevated with a hole towards left. Somewhere it said stick a chinese chopstick or smt that wouldn't damage insides but that did not work.
I did that for a second time after a week today (it leaked again) and immediately after I put 1 tea-spoon of baking soda and two cups of hot water through that hole, as per ge service site, pdf files 39-6296 p11? and 39-6401, which are users manuals. search with model no. like csh24gr ending with t or x both older models come up anyway.
Drawers brake esy, becareful. No pan back or front undersides for drain or evaporation. There is some schematics to how they engineerd the evaporation.hotptci
Posted on Dec 10, 2008
  • hotptci Dec 10, 2008
    The baking soda and 2 cups of water were recommended to be injected with a turkey-baster. Did not use it this time. Let's see what happens in a week or so.
Hot point no frost CSX22D the frig side is leaking . The ice maker is not hooked up.
drain hole for the evaperator water that accumulates on defrost cycle is probably frozen shut. call a repairman. those side by sides are no fun. if you dont know what you are doing you could be a long time solving your problem
May 26, 2012 | Refrigerators
LEAKING FRIG SOMETIMES SMALL PUDDLE OF WATER IN FRONT OF REFRIG
drain hole is plugged, usually frozen with ice, consult owners manual on how to defrost drain hole. Hot water usually does the trick.
Jun 09, 2010 | Amana ABB1927DE Bottom Freezer...
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
Water is leaking out of the front and back of frigidaire side fre
Clear the bottom of the freezor so you can get at the drain. then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the refrigerator side as well.
Good Luck,
Gilsh
Nov 29, 2009 | Car Audio & Video
GE Profile Side by Side frig leaks
Here is a lot of information on one page so take in the part that will help you stop the problem. Also you can contact me if you still have problems. Thanks Sea Breeze
appliancepartsse@yahoo.com
Click on link below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Mar 01, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Jenn-Air JCD2389G Side by Side... Problem: Leak
very common blocked drain to cure unplug appliance defrost then remuve bottom panel freezer side you will find a silver tray with a drain chnnel unblock the hole that should cure it
Nov 09, 2008 | Jenn-Air JCD2389G Side by Side...
Clear Oil leak on Mitsi Mirage 1989
could the clear oil actually be water?. if it is leaking out in the area around or behind the passenger side front wheel on hot days, it is probably water from your A/C, system. it has an overflow or drainage pipe, as the process of cooling the air dehumidifies it and produces water. just a guess though
Jun 21, 2008 | 1989 Mitsubishi Mirage
Refrigerators Logo
173 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
