Question about RCA F27668 TV
RCA TV always start in 'grid' mode -- any way to change that?
Hi -- I have a RCA F27668 TV that always starts in 'grid' mode. My manual is in French, so (since I'm not hip to French) is essentially useless. Is there any way to change the MODE of the screen startup, so that it just tunes in full-screen to the last channel? That mode thing is kinda nice (I guess), but useless to me. Help!
  • bambimaj Aug 17, 2008
    I don't have the original remote and it is stuck in the guide star grid mode
  • HTMRC Sep 05, 2008
    I also have a RCA F27668 TV that now starts in 'grid' mode. It worked just fine for the first few years. Then one day the Grid came up empty without any program listings in the Guide Plus. We reset the Guide Plus System following the instructions in the Users Guide. It worked for a while but then stopped for no apparent reason. After that it started showing th grid mode periodically at start up.
    Now it also pops into grid mode while we're watching it so we keep the remote close by. We once tried leaving it in grid mode and found it will pop out of grid mode after a long while. One night we left it do it's own thing and found it switched into and out of grid mode several times within a few hours. All the TV Repair shops say that they'll look at it but really have no idea what it could be. Help!
bhur
  • 85 Answers
SOURCE: FPA LOCK ON MY RCA TV MODEL 27V513T
go to menu of your remote and unlock the fpa
Posted on Jun 11, 2008
  • 905 Answers
SOURCE: rca 32v432t tv plays,turnsoff,turnson, and stays in autochannel search mode
your going to need to do a resolder of dry looking solder jobs and or poor solder jobs
this could also be your front control board , try disconnecting it and see if the tv stays on
it is possible that the sensor has gone bad or the crystal needs to be replace or worse the EEPROM
my rca 27 in was doing the same thing , i resoldered the board and it worked great for 7 months
so do a resolder of all suspicious solder and heated components
then let me know what happens
also what is your model # for your rca tv ?
also one of rca's kits for repair is some solder and paste , so that should tell you something in its self about rca repairs ( the solder with the paste is supposed to make it handel heat better )
please give a fixya rating so that if you need more help in your tv , I can continue to help you further , thanks
electech
Posted on Nov 08, 2008
  • 346 Answers
SOURCE: RCA F27668 clicks but wont turn on
check cr4108
Posted on Jan 04, 2009
  • 75 Answers
SOURCE: RCA model# P52937SGEO35C5O6E---PTK195M4B Home theatre guide+gold
the buttons switches are leaking more than likely this a comon problem in a lot of tvs they start leaking and send a voltage signal to the ics and tv will start doing funny things. Anyway need to replace these switches probley about six of them in all they are mounted on a board behind where you push the power button. Should replace all just to be on the safe side.
Posted on Mar 05, 2009
maatmartin7
  • 1244 Answers
SOURCE: 27F520T RCA Truflat, won't scan for channels, auto or manual, only blue screen, no channels on tv
You need to replace the microprocessor. GoodLuck there is 52 pins to unsolder and resolder a new one. The price for the chip may bee about $35
Posted on Jun 26, 2009
I have serial #107611268,model # f27668,classic #ctc203aas..i need to change from cable to antennae and can nit get any channels to list
This is an analog tuner tv,there are no OTA analog tv transmissions you need a digital converter box btween your antenna & tv
Aug 02, 2013 | RCA Televison & Video
My rca F27668 tv fell down and the color is off its purple and blue yellow and green in diffrent areas. how do i fix this?
You need to degauss the TV,
This can be accomplished 2 easy ways i knwo of.
1.> If you have or know someone who has an old style soldering gun, the kind that has a pull lever and looks like a gun and buzzes when pushed, this will act like a degauss wand, simply plug it in pull the trigger and wave an inch or so around the affected areas untill the problem goes away.
2.> call a tv repair shop and ask them how much to "degauss" your tv.
Sep 25, 2009 | RCA F27668 TV
RCA 32WR22E startup problem(red LED blink code)
This model (RCA 32WR22E) has a child lock in which the LED flashes 2 then 7. Page GB6 in the user manual :To unlock press any numerical key on the remote control and the TV should start.
Feb 20, 2009 | Televison & Video
My lcd tv takes a long time to come on
When the TV stays on protection with the led on and blinking for a while , then suddenly turns on, that is oftem because of a faulty power board.
Nov 16, 2008 | RCA LCDX2328WD 23 in. TV/DVD Combo
Rca 52 in rear projection... start up menu always on
The setup menu will repeat until it is completed and/or something is hooked up.
On my TV it kept reoccurring until I connected up the wire from the roof antenna, even though I had cable already installed.
Check your manual for setup instructions or if you do not have one, Google the make, model number and "owners manual" to see one online.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
How to enter service mode to resize grid.
Many a good set have been destroyed by stumbling around in the service menu. One wrong thing and boom no more Tv. But we'll try to help you here, turn the set off. hold both the volume down and chanel down on the front of the set. hold them both in till the set turns on Then from this menu go to geomatry and you should be able to adjust from there , and for Gods sakes write down the values before you change them so you have a refrance point should things go terribly wrong
Nov 22, 2007 | RCA Scenium D40W20 40" Rear Projection...
Programming RCA (RCR450)
press and hold TV button. Hold the ON/OFF (both) for 3 seconds until light blinks and stays on. press the on/off button to change codes and when tv turns off, press stop.
Feb 10, 2007 | RCA RCR450 Remote Control
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
RCA F27668 TV Logo
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
