Question about SanDisk Sansa e260 MP3 Player
It's ot working...:( i need help
I have a e260 sandisk p3-player!!
and my problem is that every time when i plugg it in to the computer it doesnt show me the folders...:(
could u help me??...
i ihave know clew...:(
  • 3 Answers
Maria,
Which type of computer (Windows Vista, Windows XP, MacOS, MacOSX) are you using?
Also, check on your mp3 player for which version you have.
e200 [version 1]
e200R [Rhapsody]
e200v2 [version 2]
(See pictures here... http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=9720)
The solution is different based on which model.
The solutions all center around switching between MTC and MSC mode. You can find this setting under the general "settings" tab.
Depending on the computer system you are using, switching between those modes can sometimes trigger your Sansa to connect again.
Posted on Nov 27, 2008
Hi! My Sansa e260 won't turn on. It charges
try upgrading the firmware...if that doesnt help u'll need to replace the battery here's how to update firmware- http://kb.sandisk.com/app/answers/detail/a_id/306
Aug 14, 2009 | SanDisk Sansa e260 MP3 Player
Sandisk e260 menu not coming
DO NOT CLICK ON THAT MENEW JUST GO TO YOUR COMPUTER ICON AND PLUG IN YOUR SANSA AND IT SHOULD SHOW UP AND THEN U DRAG MUSIC TO IT
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
Computer wom't read my sansa e260
check your computer's user
it needs to be on Admin Mode when u sign in the windows.
if it didnt work then let me know on my email or here
ronidion@gmail.com
Apr 01, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 problem
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Sep 20, 2008 | SanDisk Sansa e260 MP3 Player
I cant get my computer to recognize my sansa e260
I couldn't get my e260 to work at all. Came to fixya and was able to reformat. Comes on now but can't get computer to recognize it and also will not let me set date and time. (time and battery level do not even show up on bottom of e260 screen). Help!
Sep 08, 2008 | SanDisk Sansa e200 MP3 Player
My computer does not detect my mp3 player sansa 4.0 gb
either unplugg it and try again or try a diff usb port
Jul 22, 2008 | SanDisk Sansa e260 MP3 Player
White Screen.
unintall the device from the computer and try to reinstall it again..if that doesnt help you you will have to get a new new device from sandisk...
Jan 03, 2008 | SanDisk Sansa e260 MP3 Player
HELP ME PLEASE!!!
Hi Alina. Seems like oyur Sansa E260 is experiencing some system errors. Here's a procedure you could try -- it's setting your player to the Recovery Mode and re-flashing its firmware. I hope this helps: RECOVERY MODE Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the "Load Main Image Failed" notification in the first place. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try steps 1-4 again
Mar 24, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
