Washing machine: water level is high
After start the water gets in (as usual) but the level of water keep rising
The program is not cont well, (i stopped and activate ''empty and ''sqeeze'')
Bosch wff 1201 front
  • 116 Answers
PRESSURE MAY HAVE KINK OR DEFECTIVE
Posted on Nov 30, 2008
How do I stop the water from over filling
check the small tube from the bowl up to the water level sensor
check the water sensor is operational
check /replace the water control solenoid valve
it works like this
as the water flows into the bowl
it rises and that increases the pressure on a diaphragm in the water level switch buy means of the small tube
when that pressure is equal to the water level setting ( small , medium , large ) it overcomes the spring setting and breaks the circuit to the water solenoid valve which turns off . at the same time the pressure switch progresses the program to start the wash
Oct 07, 2016 | Haier Washing Machines
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
Model no 6.5kg wf7035dn fully automatic from LG water is not stop automatic so what to do
check the level hose on the side of the tub is connected properly as any cracks or leaks will not transfer the rising pressure to the level control switch to stop the water flow into the machine
It could be a faulty control switch as it does 2 things
turns off the water control when the setting is reached ( low to high level)
and at the same time starts the wash action
May 01, 2016 | LG Washing Machines
When i turn on the washer it won't start& water keeps flowing into washing machine. does the water flows or not suppose to flow into the washing machine from the inlet valve?
water into a washing machine is controlled by a tube in the side of the bowl up to a pressure switch
as the water level rises in the bowl, pressure in the switch is built up until it overcomes the setting that you have made for a water level on the wash size selection switch
at this point it turns off the inlet solenoid switch and starts the wash cycle
If the water solenoid is burnt out then water will continue to come in and over flow the bowl but it should be washing as well
If the water is not stopping then check for a disconnected hose to the switch or ma hose full of water
failing all that get a washing machine mechanic in
Apr 18, 2015 | Maytag Neptune MAH5500B Front Load Washer
I have a whirlpool wwi851ew , when I press the necessary buttons to start the machine it starts to fill when I press the start button, the problem is keeps draining the water out of it, does anyone ha
check the vacume pipe ....remove lid.......look for thin black white or clear pipe coming from the drum to a small round plastic part........when water level rises the vacume created closes a switch to stop water and start machine..
cheers
Nov 01, 2014 | Whirlpool Washing Machines
Water pours out from washer
Most washer i know of have a small hose coming from the base of the tub abd going up to a water pressure switch up in the controls. As the water level rises the pressure inside the tube rises. When the water level gets just right the pressure inside the switch kills the water and starts the motor. So what goes wrong? Trash and sediment such as sand gets into the tubing. Removing the tube from the control and blowing it out in most cases fixes the probo. Note: If you do this you need to pump out any water in the machine before you start another wash cycle. So that the pressure will build once again in the tubing and shut off the washer at the correct fill.
Sep 04, 2013 | Washing Machines
Whirl pool top load washing machine directly goes to aqua save mode and disable all other functions?
This is just a setting error. For troubleshooting of this error, just enter in diagnostic mode. Keep pressing Program button and then also press Water Level button. Now release both buttons. Now machine will auto run for wash-rinse-spin. After it finishes, Keep program on Normal, Keep water level low and now Start the machine. It will now work normally as before.
Nov 17, 2012 | Whirlpool Washing Machines
There does not seem to be enough water in machine to wash with
This problem could have a number of different causes. Unless it is a machine specifically designed to operate at reduces water levels, the likely cause is that the sensor that determines how much the machine fills up is somewhat blocked or going bad. The blockage would prevent accurate sensing of the water level. See the explanation below:
The level sensor uses a pressure switch to detect the water level in the tub.
Water level control switch
This switch controls how high the tub fills with water.
Water level control switch plumbing
The big end of the hose connects to the bottom of the tub, while the small end connects to the switch. As the water level in the tub rises, water rises in the hose also; but the air in the hose is trapped, so as the water rises, the air is compressed.
Inside the water level control switch
Inside the housing of this switch is a little piston. The pressure in the hose pushes the piston up. When it is raised far enough, it pops up and closes an electrical contact. This set point, where the contact is lost, is adjustable, and in the picture you can see the cam mechanism that is connected to the adjuster knob on the control panel of the washer. As the cam turns, it presses a spring against the cylinder, making it harder for the cylinder to pop up. This means that the water level will have to rise some more before the pressure in the hose will be high enough to trigger the switch.
Aug 11, 2011 | Washing Machines
Water keep runing into the machine and exceed the required level setting. the machine will not start to washing is it that the water level in to high or does the water level setting control the washing...
put the washer on warm setting,start to fill washer,turn washer off,if it still keeps filling then you have a bad water inlet valve,if it turns off then check the water level hose from the head of the washer to the side of the outer tub,make sure both ends are on-mike
Jan 27, 2010 | Washing Machines
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Apr 02, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
