Washing mach makes clunking sounds when spinning
    Novelist:
    Champion:
  • 244 Answers
This is your bearings which will cost from £80 to £150 to replace if its a newish washer then this happens due to overloading the machine try pulling the inner drum upwards by moving it with your fingers if it moves then it is the bearings
Posted on Nov 25, 2008
Loud clunking, banging sound during the spin/drain cycle.
the make , model and year are missing but if it is a top loader unit , it indicates that the tub suspension bar motion absorbers have broken and need replacing
Sep 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
My washing machine makes a cluck sound at the end
Not knowing what model machine you have, I would hazard a guess and say it is your break solenoid or break arm or a variation on a break system.
After the spin cycle, the break solenoid or motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
You can check this by putting the machine on a spin cycle. Once the machine gets up to speed, open the door. You will hear the clunck and then the drum stops abrublty.
If that is the case, it is normal and no need to worry about it. However, it you did not have the noise before, then best to get it checked out by a repairer.
Regards
Ash
Nov 07, 2009 | Washing Machines
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
Washing machine won't spin until open and reclosed the lid
sounds like transmission not resetting for spin properly replace transmission
Nov 20, 2008 | Estate ETW4100SQ Top Load Washer
Whirlpool washer repair
is the belt still attached at the back
Mar 03, 2008 | Washing Machines
Clunking during spin
see if the shocks are not broken. if you spin the wash basket by hand and hear a grinding noise, then your bearing would most likely be bad
Dec 17, 2007 | Frigidaire GLTR1670A Front Load Washer
Makes clunking sounds & throws belt off pulley.
I think you have the answer. I suspect it will be the bearings that have seized up. Or possibly the spyder / drum axle broken
Oct 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
Washing Machines Logo
190 people viewed this question
Top Washing Machines Experts
