Question about Canon PIXMA MP780 All-In-One InkJet Printer
Paper running through printer but not printing. Printer reading error 5200
  • piggotwendy Nov 24, 2008
    The error code is 5200. How does this relate to error code 357? Also in attempting to fix it the machine turned off and will no longer turn on.
  • Anonymous Nov 27, 2008
    THIS DID NOT WORK FOR ME AT ALL DOES ANYONE HAVE ANOTHER SUGGESTION. FAXES ARE COMING OUT PLANK AS WELL AS COPIES. FOLLOWED THE ABOVE STEPS ... ISSUES PERSIST
    Sergeant:
  • 291 Answers
Error code 357 has to do with the print head & waste tank.
You can try and fix it yourself by performing the following:
first check out that all the cartridges are filled with ink if they r empty this will show up and will not get print.
-Turn off the printer.
-Open the top & both doors.
-Manually slide the ink cartridge carrier to the left.
-When you look back where the ink parks you will see a rectangular white assembly with 1 long & 2 short plastic tabs standing vertically.
-clean these carefully with a cotton swab & rubbing alcohol. They don't have to be perfect.
-NOW HERE IS THE HARD PART. Carefully reach around to the back of this assembly & move it forward. It should slide front to back easily. If it doesn't it's probably stuck with some dried ink.
Once this is free, slide the ink tray back, close evedrything up & start your printer.
The problem should disappear
Posted on Nov 23, 2008
Not printing properly
Mainly canon ip printer show 5200 error. It means your printer's hardware may be in trouble. It may be occur in your paper feeder unit. printer head unit or due to various kind of sensor. try to find what kind of unit is in trouble.
Thank you
Jun 01, 2013 | Office Equipment & Supplies
Cannot print legal paper in HP laserjet 5200
Try to set in printer setting.
Select Printer-->Properties-->Advanced-->Printing Preferences-->Paper/Quality
Set it A4 Paper...
Jun 08, 2012 | HP LaserJet 5200 Printer
My printer is not working... on screen it displays error 5200? the orange light flashes eight times. what will i do?
Before doing Resett ,Printer must be Ready (Service mode) , How to service mode;
  • Turn off Printer ( POWER + USB cable attached).
  • Press and hold RESUME button? .
  • Press and hold POWER button then free RESUME button But hold POWER button .
  • Press RESUME button five times (5x). not 4xprinter will turn off, but temporary.
  • Free both of button , the lamp indicator will ready in green /ready (printer will Found new hardware = canon device) Annoy it
  • Service tool v_1074.exe
  • Pairs of paper in the printer.
  • Find CLEAR INK COUNTER colom then click MAIN .
  • Printer will print
  • Turn off printer.
  • Turn on printer .
  • Printer is ready for use.
Reset Canon iP2770 error 5200
1. Turn the printer, and printer will look normal.
2. Run the printer for printing documents or print test, then the 5200 error will appear.
3. Jump unplug the power cord without pressing the on-off
4. Open it and slide it into the middle catridgenya manually (press the white penguncinya hook behind the head, for cartridge can be pulled into the middle)
5. Unplug all cartridges and leave the lid remains open
6. Turn the printer, hit the head will move left and right because the lid was still open and will stop in the middle.
7. Replace the cartridge, and close the correct
8. Your printer will return to normal
download: http://www.ziddu.com/download/14828683/ServiceTool_V1074.rar
Aug 29, 2011 | Canon Pixma iP2700 InkJet Photo Printer
I kept getting service error 5200 when I tried printing something. How do I fix this problem?
Hi there
Service error code 5200 is the print head error. Rub the print head into a plain paper with rubbing alcohol until ink flows and then after that remove all the USB cable connection and power cord and plug it again. Then run the print head cleaning maintenance like print nozzle or print alignment.
It should be fine right now. Please let me know if you need more help
Mar 07, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Canon Mx320 printing error 5200.How do I fix it?
Just remove the ink cartridge from the printer and clean the surface contact using a cotton moistened dipped in an alcohol .
Return back the cartridge and try to print again.
Try also to Press and Hold the STOP/RESET button until printer restart. Release the button when to completely initialize the printer
Aug 20, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Error code 5200...
5200 is an abnormal temp. rise in the printhead. Not related to your other problems, but you need a new printhead. QY6-0063-000. Around $50.00
Apr 15, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
What does error code 5200 means
ok and error 5200 ushally means it has something to do with the printhead but we are going to try this just because it is the easyest and known fix for this error.
First off unplug the printer from the computer
secound turn the printer off
third unplug the printer from the wall
wait a minute
plug the printer into the computer then into the wall then turn the printer on
do a test print
This should have solved your problem but if it didnt please let me know and I will see what other things we can try to help you fix this issue.
Oct 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
99 people viewed this question
old marine
old marine
